Single color for a large bar chart (90 bars)
I have a bar chart with 90 bars.
I want them to be of the same color.
Unfortunately I don't understand the following guide line in the docs.
If you want all the bars to be the same colour, then use the label property instead.
How should my input to the chart be done?
There is a check box in the ui-chart config when you select bar chart
Use first colour for all bars
Also stated here node-red-dashboard/Charts.md at master · node-red/node-red-dashboard · GitHub
that was to easy :wink:
many thanks
