I would ignore vendor.js & red.min.js but that's what is taking the 20-50 seconds. I went down the tree as you mentioned only vendor.js and red.min.js seem to be involved in things that are slow.
Again, please excuse my ignorance in digging thru this. I have never used these tools before or know how to translate.
This line is the source code of vendor.js takes 28.501s:
"undefined"==typeof jQuery.migrateMute&&(jQuery.migrateMute=!0),function(t){"use strict";"function"==typeof define&&define.amd?define(["jquery"],function(e){return t(e,window)}):"object"==typeof module&&module.exports?module.exports=t(require("jquery"),window):t(jQuery,window)}(function(s,n){"use strict";function e(e){return 0<=function(e,t){var r,n=/^(\d+)\.(\d+)\.(\d+)/,i=n.exec(e)||[],o=n.exec(t)||[];for(r=1;r<=3;r++){if(+i[r]>+o[r])return 1;if(+i[r]<+o[r])return-1}return 0}(s.fn.jquery,e)}s.migrateVersion="3.3.0",n.console&&n.console.log&&(s&&e("3.0.0")||n.console.log("JQMIGRATE: jQuery 3.0.0+ REQUIRED"),s.migrateWarnings&&n.console.log("JQMIGRATE: Migrate plugin loaded multiple times"),n.console.log("JQMIGRATE: Migrate is installed"+(s.migrateMute?"":" with logging active")+", version "+s.migrateVersion));var r={};function u(e){var t=n.console;s.migrateDeduplicateWarnings&&r[e]||(r[e]=!0,s.migrateWarnings.push(e),t&&t.warn&&!s.migrateMute&&(t.warn("JQMIGRATE: "+e),s.migrateTrace&&t.trace&&t.trace()))}function t(e,t,r,n){Object.defineProperty(e,t,{configurable:!0,enumerable:!0,get:function(){return u(n),r},set:function(e){u(n),r=e}})}function i(e,t,r,n){e[t]=function(){return u(n),r.apply(this,arguments)}}s.migrateDeduplicateWarnings=!0,s.migrateWarnings=[],void 0===s.migrateTrace&&(s.migrateTrace=!0),s.migrateReset=function(){r={},s.migrateWarnings.length=0},"BackCompat"===n.document.compatMode&&u("jQuery is not compatible with Quirks Mode");var o,a={},c=s.fn.init,d=s.find,l=/\[(\s*[-\w]+\s*)([~|^$*]?=)\s*([-\w#]*?#[-\w#]*)\s*\]/,p=/\[(\s*[-\w]+\s*)([~|^$*]?=)\s*([-\w#]*?#[-\w#]*)\s*\]/g,f=/^[\s\uFEFF\xA0]+|[\s\uFEFF\xA0]+$/g;for(o in s.fn.init=function(e){var t=Array.prototype.slice.call(arguments);return"string"==typeof e&&"#"===e&&(u("jQuery( '#' ) is not a valid selector"),t[0]=[]),c.apply(this,t)},s.fn.init.prototype=s.fn,s.find=function(t){var r=Array.prototype.slice.call(arguments);if("string"==typeof t&&l.test(t))try{n.document.querySelector(t)}catch(e){t=t.replace(p,function(e,t,r,n){return"["+t+r+'"'+n+'"]'});try{n.document.querySelector(t),u("Attribute selector with '#' must be quoted: "+r[0]),r[0]=t}catch(e){u("Attribute selector with '#' was not fixed: "+r[0])}}return d.apply(this,r)},d)Object.prototype.hasOwnProperty.call(d,o)&&(s.find[o]=d[o]);if(i(s.fn,"size",function(){return this.length},"jQuery.fn.size() is deprecated and removed; use the .length property"),i(s,"parseJSON",function(){return JSON.parse.apply(null,arguments)},"jQuery.parseJSON is deprecated; use JSON.parse"),i(s,"holdReady",s.holdReady,"jQuery.holdReady is deprecated"),i(s,"unique",s.uniqueSort,"jQuery.unique is deprecated; use jQuery.uniqueSort"),t(s.expr,"filters",s.expr.pseudos,"jQuery.expr.filters is deprecated; use jQuery.expr.pseudos"),t(s.expr,":",s.expr.pseudos,"jQuery.expr[':'] is deprecated; use jQuery.expr.pseudos"),e("3.1.1")&&i(s,"trim",function(e){return null==e?"":(e+"").replace(f,"")},"jQuery.trim is deprecated; use String.prototype.trim"),e("3.2.0")&&i(s,"nodeName",function(e,t){return e.nodeName&&e.nodeName.toLowerCase()===t.toLowerCase()},"jQuery.nodeName is deprecated"),e("3.3.0")&&(i(s,"isNumeric",function(e){var t=typeof e;return("number"==t||"string"==t)&&!isNaN(e-parseFloat(e))},"jQuery.isNumeric() is deprecated"),s.each("Boolean Number String Function Array Date RegExp Object Error Symbol".split(" "),function(e,t){a["[object "+t+"]"]=t.toLowerCase()}),i(s,"type",function(e){return null==e?e+"":"object"==typeof e||"function"==typeof e?a[Object.prototype.toString.call(e)]||"object":typeof e},"jQuery.type is deprecated"),i(s,"isFunction",function(e){return"function"==typeof e},"jQuery.isFunction() is deprecated"),i(s,"isWindow",function(e){return null!=e&&e===e.window},"jQuery.isWindow() is deprecated"),i(s,"isArray",Array.isArray,"jQuery.isArray is deprecated; use Array.isArray")),s.ajax){var y=s.ajax;s.ajax=function(){var e=y.apply(this,arguments);return e.promise&&(i(e,"success",e.done,"jQXHR.success is deprecated and removed"),i(e,"error",e.fail,"jQXHR.error is deprecated and removed"),i(e,"complete",e.always,"jQXHR.complete is deprecated and removed")),e}}var m=s.fn.removeAttr,g=s.fn.toggleClass,h=/\S+/g;function v(e){return e.replace(/-([a-z])/g,function(e,t){return t.toUpperCase()})}s.fn.removeAttr=function(e){var r=this;return s.each(e.match(h),function(e,t){s.expr.match.bool.test(t)&&(u("jQuery.fn.removeAttr no longer sets boolean properties: "+t),r.prop(t,!1))}),m.apply(this,arguments)};var j,Q=!(s.fn.toggleClass=function(t){return void 0!==t&&"boolean"!=typeof t?g.apply(this,arguments):(u("jQuery.fn.toggleClass( boolean ) is deprecated"),this.each(function(){var e=this.getAttribute&&this.getAttribute("class")||"";e&&s.data(this,"__className__",e),this.setAttribute&&this.setAttribute("class",e||!1===t?"":s.data(this,"__className__")||"")}))}),b=/^[a-z]/,w=/^(?:Border(?:Top|Right|Bottom|Left)?(?:Width|)|(?:Margin|Padding)?(?:Top|Right|Bottom|Left)?|(?:Min|Max)?(?:Width|Height))$/;s.swap&&s.each(["height","width","reliableMarginRight"],function(e,t){var r=s.cssHooks[t]&&s.cssHooks[t].get;r&&(s.cssHooks[t].get=function(){var e;return Q=!0,e=r.apply(this,arguments),Q=!1,e})}),s.swap=function(e,t,r,n){var i,o,a={};for(o in Q||u("jQuery.swap() is undocumented and deprecated"),t)a[o]=e.style[o],e.style[o]=t[o];for(o in i=r.apply(e,n||[]),t)e.style[o]=a[o];return i},e("3.4.0")&&"undefined"!=typeof Proxy&&(s.cssProps=new Proxy(s.cssProps||{},{set:function(){return u("JQMIGRATE: jQuery.cssProps is deprecated"),Reflect.set.apply(this,arguments)}})),s.cssNumber||(s.cssNumber={}),j=s.fn.css,s.fn.css=function(e,t){var r=this;return"string"!=typeof e&&s.each(e,function(e,t){s.fn.css.call(r,e,t)}),"number"!=typeof t||function(e){return b.test(e)&&w.test(e[0].toUpperCase()+e.slice(1))}(v(e))||u("Use of number-typed values is deprecated in jQuery.fn.css"),j.apply(this,arguments)};var x=s.data;if(s.data=function(e,t,r){var n,i,o;if(t&&"object"==typeof t&&2===arguments.length){for(o in n=s.hasData(e)&&x.call(this,e),i={},t)o!==v(o)?(u("jQuery.data() always sets/gets camelCased names: "+o),n[o]=t[o]):i[o]=t[o];return x.call(this,e,i),t}return t&&"string"==typeof t&&t!==v(t)&&(n=s.hasData(e)&&x.call(this,e))&&t in n?(u("jQuery.data() always sets/gets camelCased names: "+t),2<arguments.length&&(n[t]=r),n[t]):x.apply(this,arguments)},s.fx){var A,k,M=s.Tween.prototype.run,S=function(e){return e};s.Tween.prototype.run=function(){1<s.easing[this.easing].length&&(u("'jQuery.easing."+this.easing.toString()+"' should use only one argument"),s.easing[this.easing]=S),M.apply(this,arguments)},A=s.fx.interval||13,k="jQuery.fx.interval is deprecated",n.requestAnimationFrame&&Object.defineProperty(s.fx,"interval",{configurable:!0,enumerable:!0,get:function(){return n.document.hidden||u(k),A},set:function(e){u(k),A=e}})}var H=s.fn.load,R=s.event.add,N=s.event.fix;s.event.props=[],s.event.fixHooks={},t(s.event.props,"concat",s.event.props.concat,"jQuery.event.props.concat() is deprecated and removed"),s.event.fix=function(e){var t,r=e.type,n=this.fixHooks[r],i=s.event.props;if(i.length){u("jQuery.event.props are deprecated and removed: "+i.join());while(i.length)s.event.addProp(i.pop())}if(n&&!n._migrated_&&(n._migrated_=!0,u("jQuery.event.fixHooks are deprecated and removed: "+r),(i=n.props)&&i.length))while(i.length)s.event.addProp(i.pop());return t=N.call(this,e),n&&n.filter?n.filter(t,e):t},s.event.add=function(e,t){return e===n&&"load"===t&&"complete"===n.document.readyState&&u("jQuery(window).on('load'...) called after load event occurred"),R.apply(this,arguments)},s.each(["load","unload","error"],function(e,t){s.fn[t]=function(){var e=Array.prototype.slice.call(arguments,0);return"load"===t&&"string"==typeof e[0]?H.apply(this,e):(u("jQuery.fn."+t+"() is deprecated"),e.splice(0,0,t),arguments.length?this.on.apply(this,e):(this.triggerHandler.apply(this,e),this))}}),s.each("blur focus focusin focusout resize scroll click dblclick mousedown mouseup mousemove mouseover mouseout mouseenter mouseleave change select submit keydown keypress keyup contextmenu".split(" "),function(e,r){s.fn[r]=function(e,t){return u("jQuery.fn."+r+"() event shorthand is deprecated"),0<arguments.length?this.on(r,null,e,t):this.trigger(r)}}),s(function(){s(n.document).triggerHandler("ready")}),s.event.special.ready={setup:function(){this===n.document&&u("'ready' event is deprecated")}},s.fn.extend({bind:function(e,t,r){return u("jQuery.fn.bind() is deprecated"),this.on(e,null,t,r)},unbind:function(e,t){return u("jQuery.fn.unbind() is deprecated"),this.off(e,null,t)},delegate:function(e,t,r,n){return u("jQuery.fn.delegate() is deprecated"),this.on(t,e,r,n)},undelegate:function(e,t,r){return u("jQuery.fn.undelegate() is deprecated"),1===arguments.length?this.off(e,"**"):this.off(t,e||"**",r)},hover:function(e,t){return u("jQuery.fn.hover() is deprecated"),this.on("mouseenter",e).on("mouseleave",t||e)}});function C(e){var t=n.document.implementation.createHTMLDocument("");return t.body.innerHTML=e,t.body&&t.body.innerHTML}function T(e){var t=e.replace(P,"<$1></$2>");t!==e&&C(e)!==C(t)&&u("HTML tags must be properly nested and closed: "+e)}var P=/<(?!area|br|col|embed|hr|img|input|link|meta|param)(([a-z][^\/\0>\x20\t\r\n\f]*)[^>]*)\/>/gi,q=s.htmlPrefilter;s.UNSAFE_restoreLegacyHtmlPrefilter=function(){s.htmlPrefilter=function(e){return T(e),e.replace(P,"<$1></$2>")}},s.htmlPrefilter=function(e){return T(e),q(e)};var D=s.fn.offset;if(s.fn.offset=function(){var e,t=this[0];if(t&&t.nodeType)return e=(t.ownerDocument||n.document).documentElement,s.contains(e,t)?D.apply(this,arguments):(u("jQuery.fn.offset() requires an element connected to a document"),{top:0,left:0});u("jQuery.fn.offset() requires a valid DOM element")},s.ajax){var E=s.param;s.param=function(e,t){var r=s.ajaxSettings&&s.ajaxSettings.traditional;return void 0===t&&r&&(u("jQuery.param() no longer uses jQuery.ajaxSettings.traditional"),t=r),E.call(this,e,t)}}var _=s.fn.andSelf||s.fn.addBack;if(s.fn.andSelf=function(){return u("jQuery.fn.andSelf() is deprecated and removed, use jQuery.fn.addBack()"),_.apply(this,arguments)},s.Deferred){var F=s.Deferred,O=[["resolve","done",s.Callbacks("once memory"),s.Callbacks("once memory"),"resolved"],["reject","fail",s.Callbacks("once memory"),s.Callbacks("once memory"),"rejected"],["notify","progress",s.Callbacks("memory"),s.Callbacks("memory")]];s.Deferred=function(e){var o=F(),a=o.promise();return o.pipe=a.pipe=function(){var i=arguments;return u("deferred.pipe() is deprecated"),s.Deferred(function(n){s.each(O,function(e,t){var r="function"==typeof i[e]&&i[e];o[t[1]](function(){var e=r&&r.apply(this,arguments);e&&"function"==typeof e.promise?e.promise().done(n.resolve).fail(n.reject).progress(n.notify):n[t[0]+"With"](this===a?n.promise():this,r?[e]:arguments)})}),i=null}).promise()},e&&e.call(o,o),o},s.Deferred.exceptionHook=F.exceptionHook}return s});
It's the 4th line in the code
