Smooth counting up
smooth_counting
I intend to get the display at left similar (ui-text node) to the gauge (smooth updating from previous value to next value, without jumping to the next value directly. i had asked the question already in the above query, but i could not understand the solution provided. any other hint please ...
Something like this might work, except it's integers only. You could multiply by 10 at the start and divide by 10 at the end to get 1 decimal place.
The rate limit node regulates how quickly the text output catches up with the latest input.
A lower input than is currently in context storage will reset to 0 but it will finish counting up before restarting.
[{"id":"1f95199e774389dc","type":"function","z":"cf400f7f1844d87c","name":"Accumulate total","func":"let start = context.get('total') || 0\nif (msg.payload < start) {\n    start = 0\n}\nconst stop = msg.payload\nfor (msg.payload = start + 1; msg.payload <= stop; msg.payload ++) {\n    context.set ('total', msg.payload)\n    node.send (msg)\n}\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":160,"wires":[["4afb22a5c06fdd78"]]},{"id":"f366e5e5a184cbb3","type":"inject","z":"cf400f7f1844d87c","name":"n = 19","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"19","payloadType":"num","x":130,"y":160,"wires":[["1f95199e774389dc"]]},{"id":"5a5b2dfcf9a12ece","type":"inject","z":"cf400f7f1844d87c","name":"n = 14","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"14","payloadType":"num","x":130,"y":120,"wires":[["1f95199e774389dc"]]},{"id":"be42348f9b7f4d80","type":"inject","z":"cf400f7f1844d87c","name":"n = 45","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"45","payloadType":"num","x":130,"y":200,"wires":[["1f95199e774389dc"]]},{"id":"7a74b8e1b0aafc1d","type":"debug","z":"cf400f7f1844d87c","name":"debug 474","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":630,"y":160,"wires":[]},{"id":"4afb22a5c06fdd78","type":"delay","z":"cf400f7f1844d87c","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"5","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":470,"y":160,"wires":[["7a74b8e1b0aafc1d"]]}]
This is not as simple as it might seem, I would recommend an external library like countUp with a template node
this is exactly what i was needing, now i see the logic, the function node quickly goes through the counting, but the limit node gives out smoothly. excellent.
I did lookup the countUp js but getting it in a template node, was not in my skill list. thanks for the input.
the msg.payload is giving in random steps of 4 to 5 liters jump, but the display is going through liter by liter smoothly... exactly like i wanted... just need to set the limit to suit my inflow speed so that it catches up, which can be easily done. thanks again @jbudd
smooth_counting1
