Snapshot tool to update UI table, last missing piece: implement timer/stopwatch problems
Dear all.
Before I begin my question, first a big thanks to @Christian-Me who helped me intensively with making this flow.
Introduction to the question.
I run experiments (I am a chemist and teacher). In these experiments one needs to monitor:
  • Total duration of the experiment,
  • Temperature during the experiment
  • power setting during the experiment
  • Change of events
The total duration will be kept track of by using the stopwatch in the flow
Temperature sensor is a DS18B20 sensor
Power is regulated by PWM and SSR
The change of events is the main topic of this forum thread.
The one thing that does not do what I want it to do is the addition of the time (coming from the stopwatch) each time the "data snapshot" button is pressed.
The problem for me lies in that the stopwatch keeps sending messages and will therefore update the table every second.
My question!
Could someone assist in a solution to this problem so that every time I press data snapshot, all cells are filled?
[{"id":"a7ceb75ea06b966e","type":"sensor-ds18b20","z":"900b27bde2f7f3ae","name":"Sensor 1","topic":"","sensorid":"28-00000003f09c","timer":"2","repeat":false,"x":620,"y":1120,"wires":[["23c413ac74544660"]]},{"id":"8dc53bc322cd8e03","type":"sensor-ds18b20","z":"900b27bde2f7f3ae","name":"Sensor 1","topic":"","sensorid":"28-00000003f09c","timer":"2","repeat":false,"x":600,"y":1380,"wires":[["fd83c655392b441c"]]},{"id":"23c413ac74544660","type":"switch","z":"900b27bde2f7f3ae","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"limit","vt":"global"},{"t":"eq","v":"limit","vt":"global"},{"t":"gt","v":"limit","vt":"global"}],"checkall":"true","repair":false,"outputs":3,"x":810,"y":1060,"wires":[[],[],["38f1cc8a2f77a80a"]]},{"id":"e840ca44b9f8e341","type":"change","z":"900b27bde2f7f3ae","name":"","rules":[{"t":"set","p":"limit","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":600,"wires":[[]]},{"id":"38f1cc8a2f77a80a","type":"change","z":"900b27bde2f7f3ae","name":"power to 0","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":1060,"wires":[["8306dfd612226c07","04d2dfaf92a34cef","ebfc4f9cd6092a28","6de5b9713b17f209"]]},{"id":"52a5ce6e17a83f74","type":"change","z":"900b27bde2f7f3ae","name":"blocked sends \"false\" message","rules":[{"t":"set","p":"blocked","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1770,"y":1100,"wires":[["ef1f8d9632fdaf92"]]},{"id":"8306dfd612226c07","type":"change","z":"900b27bde2f7f3ae","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":1060,"wires":[["911a72de169a526b","f79af8d70ab84648"]]},{"id":"fe7ff9d19b9d39c1","type":"change","z":"900b27bde2f7f3ae","name":"unblocked sends \"true\" message","rules":[{"t":"set","p":"blocked","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1780,"y":1020,"wires":[[]]},{"id":"55dfd592d78dc97e","type":"ui_led","z":"900b27bde2f7f3ae","order":7,"group":"d34a34f75373b4ad","width":1,"height":1,"label":"","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#ff0000","value":"false","valueType":"bool"},{"color":"#ff0000","value":"0","valueType":"str"},{"color":"#008000","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":1630,"y":1060,"wires":[]},{"id":"b0600c7a97720c1a","type":"ui_text","z":"900b27bde2f7f3ae","group":"d34a34f75373b4ad","order":1,"width":6,"height":1,"name":"global shut off  temperature value","label":"global shut off  temperature value","format":"{{msg.payload}}","layout":"row-left","className":"","x":360,"y":560,"wires":[]},{"id":"dd6e4febb9424d73","type":"ui_text","z":"900b27bde2f7f3ae","group":"d34a34f75373b4ad","order":6,"width":3,"height":1,"name":"Power","label":"Power","format":"{{msg.payload}}","layout":"row-spread","className":"","x":1770,"y":580,"wires":[]},{"id":"fd66b06304985014","type":"ui_button","z":"900b27bde2f7f3ae","name":"Data snapshot","group":"d34a34f75373b4ad","order":24,"width":0,"height":0,"passthru":false,"label":"Data snapshot","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":320,"y":1380,"wires":[["8dc53bc322cd8e03","309d66d5f207083c"]]},{"id":"e0246ced281bd0e2","type":"inject","z":"900b27bde2f7f3ae","name":"every 1 second","props":[{"p":"payload"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1780,"y":860,"wires":[["da0f333d4b468fcf"]]},{"id":"da0f333d4b468fcf","type":"switch","z":"900b27bde2f7f3ae","name":"flow.clock_state == \"run\" ?","property":"clock_state","propertyType":"flow","rules":[{"t":"eq","v":"run","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":2040,"y":860,"wires":[["b689f487e9a49b33"]]},{"id":"5fd4dff1a1456918","type":"change","z":"900b27bde2f7f3ae","name":"set clock_value to 0","rules":[{"t":"set","p":"clock_value","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"clock_state","pt":"flow","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2010,"y":940,"wires":[["7932ca360e4ffac8"]]},{"id":"b689f487e9a49b33","type":"function","z":"900b27bde2f7f3ae","name":"decrement flow.clock_value","func":"let clock_value = flow.get(\"clock_value\") || 0;\n\nclock_value++; \n\nif (clock_value < 0) clock_value = 0;\n\nflow.set(\"clock_value\", clock_value);\n\nmsg.payload = clock_value;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2340,"y":860,"wires":[["7932ca360e4ffac8"]]},{"id":"7932ca360e4ffac8","type":"function","z":"900b27bde2f7f3ae","name":"seconds to minute:seconds","func":"let secsDecimal = msg.payload;\n\nlet mins = Math.floor(secsDecimal/60);\nlet secs = secsDecimal % 60;\n\nmsg.payload = (mins + (secs / 100.0)).toFixed(2)\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2660,"y":940,"wires":[["4104ece8085cefa3","a176351c49b17c8a"]]},{"id":"fab99f47bc50b057","type":"function","z":"900b27bde2f7f3ae","name":"toggle flow.clock_state","func":"let clock_state = flow.get(\"clock_state\") || \"stop\";\n\nclock_state = clock_state === \"stop\" ? \"run\" : \"stop\";\n\nflow.set(\"clock_state\", clock_state );\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2360,"y":900,"wires":[["7932ca360e4ffac8"]]},{"id":"ddf6a33775a62eee","type":"switch","z":"900b27bde2f7f3ae","name":"Timer function starting point","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1740,"y":920,"wires":[["2365ea4d963af544"],["5fd4dff1a1456918"]]},{"id":"2365ea4d963af544","type":"change","z":"900b27bde2f7f3ae","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"run","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2000,"y":900,"wires":[["fab99f47bc50b057"]]},{"id":"4104ece8085cefa3","type":"ui_text","z":"900b27bde2f7f3ae","group":"3e0d8616af34c894","order":16,"width":8,"height":1,"name":"Distillation timer ","label":"Distillation timer ","format":"{{msg.payload}}","layout":"row-spread","className":"","x":2920,"y":940,"wires":[]},{"id":"04d2dfaf92a34cef","type":"ui_gauge","z":"900b27bde2f7f3ae","name":"Current power gauge","group":"d34a34f75373b4ad","order":15,"width":6,"height":6,"gtype":"gage","title":"Current power","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#ff0000","#00ff00","#ff0000"],"seg1":"40","seg2":"60","className":"","x":1380,"y":740,"wires":[]},{"id":"ebfc4f9cd6092a28","type":"rpi-gpio out","z":"900b27bde2f7f3ae","name":"","pin":"22","set":"","level":"0","freq":"1","out":"pwm","bcm":true,"x":1340,"y":780,"wires":[]},{"id":"a242cfe671501a9f","type":"switch","z":"900b27bde2f7f3ae","name":"","property":"blocked","propertyType":"global","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":1130,"y":760,"wires":[["04d2dfaf92a34cef","ebfc4f9cd6092a28"]]},{"id":"d03a996e434c386d","type":"change","z":"900b27bde2f7f3ae","name":"Reset powervalue at power On and Off","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1930,"y":1060,"wires":[["881c7a15dec9b590"]]},{"id":"6de5b9713b17f209","type":"ui_text_input","z":"900b27bde2f7f3ae","name":"Power Setting","label":"Power Setting","tooltip":"","group":"d34a34f75373b4ad","order":13,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"payload","sendOnBlur":true,"className":"","topicType":"msg","x":920,"y":760,"wires":[["a242cfe671501a9f","54ec53ac701cadb6"]]},{"id":"b2a9169d2a64a0ac","type":"ui_text_input","z":"900b27bde2f7f3ae","name":"global shut off  temperature value","label":"","tooltip":"","group":"d34a34f75373b4ad","order":2,"width":3,"height":1,"passthru":true,"mode":"text","delay":300,"topic":"topic","sendOnBlur":true,"className":"","topicType":"msg","x":360,"y":600,"wires":[["e840ca44b9f8e341"]]},{"id":"3b5f5e10d9509ec8","type":"inject","z":"900b27bde2f7f3ae","name":"shut off test (temperature simulation)","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"103","payloadType":"num","x":580,"y":1060,"wires":[["23c413ac74544660"]]},{"id":"881c7a15dec9b590","type":"link out","z":"900b27bde2f7f3ae","name":"Send 0 At Power Off","mode":"link","links":["536f8c623c7ac1ba"],"x":2155,"y":1060,"wires":[]},{"id":"536f8c623c7ac1ba","type":"link in","z":"900b27bde2f7f3ae","name":"Receive 0 At Power Off","links":["c70b9649e1d671e4","881c7a15dec9b590"],"x":755,"y":760,"wires":[["6de5b9713b17f209"]]},{"id":"ef1f8d9632fdaf92","type":"link out","z":"900b27bde2f7f3ae","name":"Send geblokkeerd geeft false bericht","mode":"link","links":["a5fd7b22da3d78dc"],"x":1955,"y":1100,"wires":[]},{"id":"a5fd7b22da3d78dc","type":"link in","z":"900b27bde2f7f3ae","name":"Receive geblokkeerd geeft false bericht","links":["ef1f8d9632fdaf92","986765faa98821ab","9a73bda45141f2f8"],"x":925,"y":1140,"wires":[["38f1cc8a2f77a80a"]]},{"id":"be32c5c562e86daf","type":"function","z":"900b27bde2f7f3ae","name":"add new snapshot (snapshot trigger)","func":"// get last counter or initialize to 0 from flow because we will need the last counter for your other measuremnts\nvar counter = flow.get('counter') || 0;\ncounter++; // increment counter by one;\n\n// add id and timestamp to the payload and keep existing properties\nmsg.payload.id = counter;\nmsg.payload.time = Date.now();\n\n\nflow.set('counter',counter); // store counter flow context;\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2810,"y":1220,"wires":[[]]},{"id":"230caf65f2dbbc3f","type":"function","z":"900b27bde2f7f3ae","name":"update or add to table","func":"msg.payload={\n    command:\"updateOrAddData\",\n    arguments: [\n        [\n            msg.payload // simply pass all proerties of the payload\n        ]\n    ],\n    returnPromise: true\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3500,"y":1380,"wires":[["4a23fdddc5ae1613"]]},{"id":"4a23fdddc5ae1613","type":"ui_table","z":"900b27bde2f7f3ae","group":"d34a34f75373b4ad","name":"","order":12,"width":26,"height":8,"columns":[{"field":"id","title":"Fraction","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"time","title":"Time","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"temperature","title":"Temperature","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"setPower","title":"Power","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}}],"outputs":1,"cts":true,"x":3710,"y":1380,"wires":[[]]},{"id":"1f1b5b0ae002f698","type":"change","z":"900b27bde2f7f3ae","name":"Set msg.topic to setPower","rules":[{"t":"set","p":"topic","pt":"msg","to":"setPower","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2430,"y":1340,"wires":[["040a6dc3655b31d5"]]},{"id":"a176351c49b17c8a","type":"change","z":"900b27bde2f7f3ae","name":"Set msg.topic to time","rules":[{"t":"set","p":"topic","pt":"msg","to":"time","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2300,"y":1300,"wires":[["7b2a1f299c1749a6"]]},{"id":"48068729b6de3c29","type":"inject","z":"900b27bde2f7f3ae","name":"ui_control","props":[{"p":"ui_control","v":"{\"tabulator\":{\"columns\":[{\"field\":\"time\",\"formatter\":\"datetime\",\"formatterParams\":{\"inputFormat\":\"x\",\"outputFormat\":\"HH:mm.ss.S\"}},{\"field\":\"temperature\",\"formatterParams\":{\"precision\":2,\"unit\":\"°C\"},\"formatter\":\"function (cell, formatterParams, onRendered) {     let result = Number(cell.getValue());     if (Number.isNaN(result)) return cell.getValue();     result = result.toFixed(formatterParams.precision);     result += (formatterParams.unit) ? formatterParams.unit : '';     return result; }\",\"topCalc\":\"avg\"},{\"formatterParams\":{\"field\":\"power\",\"formatter\":\"value\",\"topCalc\":\"avg\"}}]}}","vt":"json"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.5","topic":"","x":3540,"y":1440,"wires":[["4a23fdddc5ae1613"]]},{"id":"25fc5c5a72f7cecb","type":"change","z":"900b27bde2f7f3ae","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{\"id\":0,\"power\":0}]","tot":"json"},{"t":"set","p":"counter","pt":"flow","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":3520,"y":1320,"wires":[["4a23fdddc5ae1613"]]},{"id":"36d18a2c01386c20","type":"ui_button","z":"900b27bde2f7f3ae","name":"restart","group":"d34a34f75373b4ad","order":4,"width":1,"height":1,"passthru":true,"label":"","tooltip":"","color":"","bgcolor":"","className":"","icon":"restore","payload":"restart","payloadType":"str","topic":"control","topicType":"str","x":3330,"y":1340,"wires":[["25fc5c5a72f7cecb"]]},{"id":"f268fb5a45c6be01","type":"ui_ui_control","z":"900b27bde2f7f3ae","name":"","events":"change","x":3320,"y":1300,"wires":[["25fc5c5a72f7cecb"]]},{"id":"f35b20d65e8c0b53","type":"change","z":"900b27bde2f7f3ae","name":"add last counter","rules":[{"t":"set","p":"payload.id","pt":"msg","to":"counter","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":2900,"y":1380,"wires":[["818857a10a9680fd"]]},{"id":"5b9ce9155c66e437","type":"function","z":"900b27bde2f7f3ae","name":"Format For Table","func":"var tableRow = {\n    command: \"updateOrAddData\",\n    arguments: [\n        [\n            {\n                priority: msg.payload.priority,                \n                loadName: msg.payload.name,\n                type: msg.payload.type,\n                ratedPower: msg.payload.ratedPower,\n                powerUsage: msg.payload.powerUsage,\n                state: msg.payload.state\n            }  \n        ]\n    ],\n    returnPromise: true\n};\n\n// Replace the status strings with icons to go in the table\nif (tableRow.arguments[0][0].state == \"active\")\n    tableRow.arguments[0][0].state = '<i class=\"material-icons icon-2x\" style=\"color: navy;\">check_circle</i>';\nelse if (tableRow.arguments[0][0].state == \"inactive\")\n    tableRow.arguments[0][0].state = '<i class=\"material-icons icon-2x\" style=\"color: gray;\">check_circle_outline</i>';\nelse if (tableRow.arguments[0][0].state == \"disabled\")\n    tableRow.arguments[0][0].state = '<i class=\"material-icons icon-2x\" style=\"color: red;\">dnd_forwardslash</i>';\nelse\n    tableRow.arguments[0][0].state = '<i class=\"material-icons icon-2x\" style=\"color: gray;\">radio_button_unchecked</i>';\n    \nmsg.payload = tableRow;\nnode.warn(tableRow.arguments[0][0].priority);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3130,"y":1240,"wires":[[]]},{"id":"040a6dc3655b31d5","type":"join","z":"900b27bde2f7f3ae","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":2710,"y":1380,"wires":[["f35b20d65e8c0b53"]]},{"id":"911a72de169a526b","type":"ui_button","z":"900b27bde2f7f3ae","name":"Off","group":"d34a34f75373b4ad","order":22,"width":0,"height":0,"passthru":false,"label":"Off","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"false","payloadType":"bool","topic":"topic","topicType":"msg","x":1470,"y":1100,"wires":[["55dfd592d78dc97e","d03a996e434c386d","52a5ce6e17a83f74","ddf6a33775a62eee"]]},{"id":"f79af8d70ab84648","type":"ui_button","z":"900b27bde2f7f3ae","name":"ON","group":"d34a34f75373b4ad","order":23,"width":0,"height":0,"passthru":false,"label":"ON","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"true","payloadType":"bool","topic":"topic","topicType":"msg","x":1470,"y":1020,"wires":[["55dfd592d78dc97e","ddf6a33775a62eee","fe7ff9d19b9d39c1","d03a996e434c386d"]]},{"id":"fd83c655392b441c","type":"change","z":"900b27bde2f7f3ae","name":"set msg.topic to temperature for table","rules":[{"t":"set","p":"topic","pt":"msg","to":"temperature","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":1380,"wires":[["040a6dc3655b31d5"]]},{"id":"89df341ee491b9ad","type":"inject","z":"900b27bde2f7f3ae","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":1470,"y":1060,"wires":[["55dfd592d78dc97e","ddf6a33775a62eee"]]},{"id":"c439b40aed5eb226","type":"inject","z":"900b27bde2f7f3ae","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":870,"y":980,"wires":[["38f1cc8a2f77a80a"]]},{"id":"b74927892128db58","type":"inject","z":"900b27bde2f7f3ae","name":"ui_control","props":[{"p":"ui_control","v":"{\"tabulator\":{\"columns\":[{\"field\":\"time\",\"formatter\":\"datetime\",\"formatterParams\":{\"inputFormat\":\"x\",\"outputFormat\":\"HH:mm.ss\",\"invalidPlaceholder\":\"(invalid date)\"}},{\"field\":\"temperature\",\"formatterParams\":{\"precision\":2,\"unit\":\"°C\"},\"formatter\":\"function (cell, formatterParams, onRendered) {     let result = Number(cell.getValue());     if (Number.isNaN(result)) return cell.getValue();     result = result.toFixed(formatterParams.precision);     result += (formatterParams.unit) ? formatterParams.unit : '';     return result; }\"}]}}","vt":"json"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","x":3320,"y":1060,"wires":[[]]},{"id":"791356f19c40d6d1","type":"inject","z":"900b27bde2f7f3ae","name":"ui_control","props":[{"p":"ui_control","v":"{\"tabulator\":{\"columns\":[{\"field\":\"time\",\"formatter\":\"datetime\",\"formatterParams\":{\"inputFormat\":\"x\",\"outputFormat\":\"HH:mm.ss.S\",\"invalidPlaceholder\":\"take snapshot\"}},{\"field\":\"temperature\",\"formatterParams\":{\"precision\":2,\"unit\":\"°C\"},\"formatter\":\"function (cell, formatterParams, onRendered) {     let result = Number(cell.getValue());     if (Number.isNaN(result)) return cell.getValue();     result = result.toFixed(formatterParams.precision);     result += (formatterParams.unit) ? formatterParams.unit : '';     return result; }\",\"topCalc\":\"avg\"},{\"formatterParams\":{\"target\":\"_blank\",\"min\":0,\"max\":100,\"color\":[\"blue\",\"green\",\"red\"],\"legend\":\"function (value) {return '&nbsp;&nbsp;'+Number(value).toFixed(1)+' %';}\",\"legendColor\":\"#FFFFFF\",\"legendAlign\":\"left\"},\"field\":\"power\",\"formatter\":\"progress\",\"topCalc\":\"avg\"}]}}","vt":"json"},{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.5","topic":"","payload":"","payloadType":"str","x":3300,"y":1020,"wires":[[]]},{"id":"4ece490235a0da41","type":"inject","z":"900b27bde2f7f3ae","name":"ui_control","props":[{"p":"ui_control","v":"{\"tabulator\":{\"columns\":[{\"field\":\"time\",\"formatter\":\"datetime\",\"formatterParams\":{\"inputFormat\":\"x\",\"outputFormat\":\"HH:mm.ss.S\",\"invalidPlaceholder\":\"take snapshot\"}},{\"field\":\"temperature\",\"formatterParams\":{\"precision\":2,\"unit\":\"°C\"},\"formatter\":\"function (cell, formatterParams, onRendered) {     let result = Number(cell.getValue());     if (Number.isNaN(result)) return cell.getValue();     result = result.toFixed(formatterParams.precision);     result += (formatterParams.unit) ? formatterParams.unit : '';     return result; }\"}]}}","vt":"json"},{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.5","topic":"","payload":"","payloadType":"str","x":3280,"y":980,"wires":[[]]},{"id":"54ec53ac701cadb6","type":"link out","z":"900b27bde2f7f3ae","name":"Send power setting","mode":"link","links":["9c3a53f908f530b3"],"x":1045,"y":800,"wires":[]},{"id":"9c3a53f908f530b3","type":"link in","z":"900b27bde2f7f3ae","name":"Receive power setting","links":["54ec53ac701cadb6"],"x":2115,"y":1340,"wires":[["1f1b5b0ae002f698"]]},{"id":"309d66d5f207083c","type":"link out","z":"900b27bde2f7f3ae","name":"Send data snapshot trigger","mode":"link","links":["76e7f23d6ebff6d9","b7c7ca777e512c2a","b7526058c85463f0","7294beba04a96d6f"],"x":505,"y":1420,"wires":[]},{"id":"818857a10a9680fd","type":"function","z":"900b27bde2f7f3ae","name":"add new snapshot (snapshot trigger)","func":"// get last counter or initialize to 0 from flow because we will need the last counter for your other measuremnts\nvar counter = flow.get('counter') || 0;\ncounter++; // increment counter by one;\n\n// add id and timestamp to the payload and keep existing properties\nmsg.payload.id = counter;\n//msg.payload.time = Date.now();\n\n\nflow.set('counter',counter); // store counter flow context;\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3190,"y":1380,"wires":[["230caf65f2dbbc3f"]]},{"id":"b7c7ca777e512c2a","type":"link in","z":"900b27bde2f7f3ae","name":"","links":["309d66d5f207083c"],"x":2115,"y":1300,"wires":[["a176351c49b17c8a"]]},{"id":"7b2a1f299c1749a6","type":"join","z":"900b27bde2f7f3ae","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":2490,"y":1300,"wires":[["040a6dc3655b31d5"]]},{"id":"1dac3346dee676e1","type":"inject","z":"900b27bde2f7f3ae","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":2020,"y":1220,"wires":[[]]},{"id":"d34a34f75373b4ad","type":"ui_group","name":"Table tester","tab":"0264230475e6a091","order":2,"disp":true,"width":"26","collapse":false,"className":""},{"id":"3e0d8616af34c894","type":"ui_group","name":"Calculations","tab":"0264230475e6a091","order":1,"disp":true,"width":9,"collapse":false,"className":""},{"id":"0264230475e6a091","type":"ui_tab","name":"Table tester","icon":"dashboard","disabled":false,"hidden":false}]
Additional info:
The rules of the flow are as followed:
The timer must start when "on" is pressed.
The timer must clear when "off" is pressed.
The power setting must turn to 0 when "off" is pressed (safety)
The power must be set to 0 when "on" is pressed (safety)
change power value = update table (including the current live readings from temperature and time)
pressing data snapshot = update the table (including the current live readings from temperature and time and power setting)
Is any additional info required?
So do you only want to update the table when the ‘Data Snapshot’ button is pressed?
Yes! That -or- the power value is changed :smiley:
First off instead of an 'On'/'Off' buttons, I would replace them with a switch. As it is, if you press 'ON' and enter a value and press 'ON' again, it resets the power value. A switch shows the definate state. You will need to make some changes to the flow but it would seem like a better
Second, I would get rid of the 'Power Setting' text node and replace it with a slides (set to a width of 1 and a height of 4 or 5).
Have you thought about sending the data to a database?
I thought that would be smart as a safety feature
If you put power to off and then dial in a power value, the power will be set when power is then switched on. One might accidentally press “on” with a value dialed in.
Oh! Why? I thought providing my students with mouse and keyboard was better as we already have that in the classroom!
No, I did not think about a data base. And i think that would complicate things alot more (for me)
You can build is the way you think is best, I was just offering some ideas.
I would store what you want to display in the table in flow variables and when an event occurs that will cause a line to be written, grab the data from the flow variable and send it to the table.
I think your idea is better :slight_smile:
No idea how… could you show that with my flow?
Just create a JavaScript object with the data you need and store it in a flow variable. I’ll send you an example tomorrow but for now I’m hitting the sack.
i'll be looking forward to it!
This sound like the solution
I've been thinking about what you are doing and have some suggestions/questions. You are reporting
Fraction (Is this just a counter starting at 0 of events?)
Time (elapsed)
Temperature (does the sensor-DS18B20 node you are using send back the reading only when you query it? With node-red-contrib-sensor-ds18b20 you can set an interval to do reading. I would go with this node so you could get a automatic periodic set of readings)
Power
My ideas are this:
1 - Have a entry item to set the period you want to take readings
2 - When you press 'ON', set flow.starttime to the current time - this will be the basis for elapsed time
3 - add a 'GO' button which can only be pressed when the system is 'On' and "Power' is set
(should power be changeable while it is running?)
4 - when 'Power' is set, write it to flow.power
4 - when a temperature reading is taken (via the interval or by the snapshot button being pushed) in the msg, set msg.time to a timestamp (this value minus flow.starttime will give you the elapsed time) and set msg.power to flow.power.
at this point in the msg you have the time, temperature and power reading and you can sent this to a function node to calculate the elapsed time and the 'fraction'. Format and send it to the table.
In addition, for every reading I would write it out to a database or ar least to a file so you have a record of the data.
Since you said you are using this for teaching, you could add a field for the students name and also add that to the DB or file.
p.s. sorry this took so long, had some work aroung the house to finish up :wink:
Yes. Fractions will be physical fractions, liquid collected in glass beakers.
both, I can either trigger a reading or set it on an interval
This needs to be a self-pressed trigger like the snapshot button =D
interesting! (not sure how yet)
Yes! and this needs to update the table as this is important =D
Dear lord... this will be quite difficult for me
brilliant idea!
Ahh, currently it looks like that is just a counter. How will you be getting that data?
what data?
Sorry, the fractions?
The liquid is collected in beakers from a constant flow. A fraction is finished when you observe a change in events. One needs to remember when and with what settings this happened.
The product that is collected is a fraction :slight_smile:
First snapshot goes as planned
Second snapshot not... as the power value is missing
Strange enough, when i change the power setting, the other values DO show up...!
This is what the flow looks like:
Somehow the power setting from the text node isn't remembered after the first message is sent
I can't check this box (red circle) as the stopwatch will trigger the table each second haha
No worries! =D
