i have been busting my head with tis issue.
I have input from mqtt and i want some of this input formatted into a url and push it to pvoutput.
I know what the URL has to look like.
Manualy making the url works.
1 piece of data from mqtt and input them into the httprequest with moustache works
But how to get multiple data into the http request?? I have no idea.
See attached flow. the inject is 1 output from the solarpanels.
I deleted my API key so testing is not possible. Sorry
[{"id":"5f00def2.c9ac9","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"bb06f86a.d7d958","type":"debug","z":"5f00def2.c9ac9","name":"WATT","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1010,"y":120,"wires":[]},{"id":"d8270078.6a829","type":"function","z":"5f00def2.c9ac9","name":"Watt","func":"var v2 = { payload: msg.payload.runningInfo.pac.toString() };\nreturn v2;","outputs":1,"noerr":0,"x":290,"y":300,"wires":[["92306094.ce42b"]]},{"id":"4948e055.890ae","type":"http request","z":"5f00def2.c9ac9","name":"PV output","method":"GET","ret":"txt","paytoqs":true,"url":"https://pvoutput.org/service/r2/addstatus.jsp?key=APIKEY&sid=MYID&d=20191025&t=13:40&v2={{v2}}&v5=15.5&v6={{v6}}","tls":"","persist":false,"proxy":"","authType":"","x":840,"y":120,"wires":[["bb06f86a.d7d958"]]},{"id":"64872bec.6c7f94","type":"function","z":"5f00def2.c9ac9","name":"Voltage","func":"var v6 = { payload: msg.payload.runningInfo.vac1.toString() };\nreturn v6;","outputs":1,"noerr":0,"x":300,"y":340,"wires":[["92306094.ce42b"]]},{"id":"4b0742ce.4637cc","type":"inject","z":"5f00def2.c9ac9","name":"","topic":"","payload":"{\"address\":11,\"addressConfirmed\":true,\"idInfo\":{\"firmwareVersion\":\"\",\"function\":130,\"internalVersion\":\"\",\"manufacturer\":\"\",\"modelName\":\"\",\"nominalVpv\":0,\"safetyCountryCode\":0,\"serialNumber\":\"\"},\"inverterType\":3,\"isOnline\":true,\"lastSeen\":1572009709165,\"runningInfo\":{\"eDay\":14.5,\"eTotal\":6709.9,\"errorMessage\":[],\"fac1\":50.01,\"fac2\":50.01,\"fac3\":50.01,\"function\":129,\"gcfiFault\":20,\"hTotal\":3553,\"iac1\":4.4,\"iac2\":4.4,\"iac3\":4.2,\"ipv1\":4.5,\"ipv2\":2.5,\"line1FFault\":60.48,\"line1VFault\":0,\"line2FFault\":30.54,\"line2VFault\":0,\"line3FFault\":0,\"line3VFault\":0,\"pac\":3266,\"pv1Fault\":0,\"pv2Fault\":0.7,\"temp\":37.8,\"tempFault\":151.5,\"timestamp\":\"20191025152149\",\"vac1\":231.5,\"vac2\":230.9,\"vac3\":229.5,\"vpv1\":497.7,\"vpv2\":378.5,\"workMode\":1},\"serial\":\"96000DTU187W0031\",\"serialNumber\":[57,54,48,48,48,68,84,85,49,56,55,87,48,48,51,49],\"settingInfo\":{\"facMax\":0,\"facMin\":0,\"function\":131,\"tStart\":0,\"vacMax\":0,\"vacMin\":0,\"vpvStart\":0}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":160,"wires":[["9999376c.98f9f8","d8270078.6a829","64872bec.6c7f94","8d221d65.7ce16","8793d5cc.e4b648","34737d4f.e299f2","686a239c.ea70ac"]]},{"id":"9999376c.98f9f8","type":"function","z":"5f00def2.c9ac9","name":"Watt&Voltage (as string)","func":"msg.payload = {\n \"v2\": msg.payload.runningInfo.pac.toString(),\n \"v6\": msg.payload.runningInfo.vac1.toString(),\n };\nreturn msg;","outputs":1,"noerr":0,"x":350,"y":120,"wires":[[]]},{"id":"d320de03.aa64b","type":"comment","z":"5f00def2.c9ac9","name":"Inject node","info":"The injectnode gives the output from my solarpanels.\nOutput is every 5 seconds. i do not need all data. Only:\n\npac: (is the current WATT)\nvac1: (current voltage)\ntimestamp: (must be seperated tot date and time)\n","x":120,"y":100,"wires":[]},{"id":"ec87dd4c.8f9ab","type":"comment","z":"5f00def2.c9ac9","name":"PV output & Issues","info":"https://pvoutput.org/service/r2/addstatus.jsp?\nkey=API KEY&\nsid=MYID&\nd=20191025&\nt=13:40&\nv1=v2&\nv2={{{v2}}}&\nv5=15.5&\nv6={{{v6}}}\n\nAbove is the url with API it works when i input the numbers manually.\n\nd=date, but the format from my panels is different\nBut it doe snot have to be the dat from the panels, it can be system date. date from the upload.\nSame with time.\nv1=v2 no changes here.\nv2 the data from pac\nv5 the temperature, nice to have, but data comes from other mqtt\nv6 is the vac1 not nescesary ","x":690,"y":60,"wires":[]},{"id":"8d221d65.7ce16","type":"function","z":"5f00def2.c9ac9","name":"Watt&Voltage (numbers)","func":"msg.payload = {\n \"v2\": msg.payload.runningInfo.pac,\n \"v6\": msg.payload.runningInfo.vac1,\n };\nreturn msg;","outputs":1,"noerr":0,"x":350,"y":160,"wires":[[]]},{"id":"8793d5cc.e4b648","type":"function","z":"5f00def2.c9ac9","name":"Watt&Voltage (not working)","func":"var v2 = { payload: msg.payload.runningInfo.pac };\nvar v6 = { payload: msg.payload.runningInfo.vac1 };\nreturn v2,v6;","outputs":1,"noerr":0,"x":360,"y":200,"wires":[[]]},{"id":"d9c8e7a7.188bf8","type":"delay","z":"5f00def2.c9ac9","name":"Upload every 5 minutes","pauseType":"delay","timeout":"300","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":630,"y":120,"wires":[[]]},{"id":"1c8d2c0.25d6bd4","type":"inject","z":"5f00def2.c9ac9","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":80,"y":420,"wires":[[]]},{"id":"92306094.ce42b","type":"debug","z":"5f00def2.c9ac9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":770,"y":360,"wires":[]},{"id":"34737d4f.e299f2","type":"moment","z":"5f00def2.c9ac9","name":"datum","topic":"","input":"payload.runningInfo.timestamp,","inputType":"msg","inTz":"Europe/Amsterdam","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYYMMDD","locale":"nl_NL","output":"","outputType":"msg","outTz":"Europe/Amsterdam","x":290,"y":380,"wires":[["92306094.ce42b"]]},{"id":"686a239c.ea70ac","type":"moment","z":"5f00def2.c9ac9","name":"tijd","topic":"","input":"payload.runningInfo.timestamp,","inputType":"msg","inTz":"Europe/Amsterdam","adjAmount":0,"adjType":"days","adjDir":"add","format":"HH:mm","locale":"nl_NL","output":"","outputType":"msg","outTz":"Europe/Amsterdam","x":290,"y":420,"wires":[["92306094.ce42b"]]},{"id":"5057ee19.4ce5c","type":"join","z":"5f00def2.c9ac9","name":"","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":590,"y":240,"wires":[["92306094.ce42b"]]}]
But output has to look like this:
https://pvoutput.org/service/r2/addstatus.jsp?key=API KEY&sid=MYID&d=20191025&t=13:40&v1=v2&v2={{{v2}}}&v5=15.5&v6={{{v6}}}
Where between the moustache has to be numbers, and the formatting of the dates has to be like in the url.
