Yea, I found out that the mock node will be empty once I deploy everything. I switched to deploying only what changed, but that didn't seem to help.
With your flow example I was able to get the three arrays, but the mock nodes still seem to be having an empty payload. The node itself is not empty, it says "Object", but payload is empty?
Here is what I have so far. Maybe someone can point me to what I am doing wrong with the mock nodes.
The function to add the values to the third array is not ready yet. ![]()
[{"id":"a5cb0f26a080725b","type":"http request","z":"457f9988695be7c4","name":"Solcast API - get Live+Forecast JSON EAST","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.solcast.com.au/rooftop_sites/eb16","tls":"","persist":false,"proxy":"","authType":"basic","senderr":false,"x":630,"y":440,"wires":[["786e5f423ffa7593"]]},{"id":"c0e0319e8b59c5ca","type":"debug","z":"457f9988695be7c4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1210,"y":740,"wires":[]},{"id":"786e5f423ffa7593","type":"switch","z":"457f9988695be7c4","name":"StatusCode","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":930,"y":440,"wires":[["265829a5ea960730"],["c0e0319e8b59c5ca","43c89b64564876f0"]]},{"id":"43c89b64564876f0","type":"change","z":"457f9988695be7c4","name":"timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"},{"t":"delete","p":"statusCode","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1210,"y":440,"wires":[["e132cc1dd6f953de"]]},{"id":"e132cc1dd6f953de","type":"delay","z":"457f9988695be7c4","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1400,"y":440,"wires":[[]]},{"id":"5783efa521601e69","type":"inject","z":"457f9988695be7c4","name":"forecasts","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"forecasts","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"forecasts","payload":"","payloadType":"date","x":106,"y":1015,"wires":[["cbda7ba3f1b5dd8c"]]},{"id":"6fba0be572ad1fcc","type":"change","z":"457f9988695be7c4","name":"reset counter","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"topic.reset","pt":"msg","to":"reset","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":899,"wires":[["cbda7ba3f1b5dd8c"]]},{"id":"647d5a3b47463e70","type":"switch","z":"457f9988695be7c4","name":"counter","property":"count","propertyType":"msg","rules":[{"t":"btwn","v":"1","vt":"num","v2":"50","v2t":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":880,"y":740,"wires":[["2dc5dceec8bc5fe5"],["c0e0319e8b59c5ca"]]},{"id":"c8a0bcb16c3e26a7","type":"change","z":"457f9988695be7c4","name":"","rules":[{"t":"delete","p":"reset","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":907,"y":899,"wires":[["647d5a3b47463e70"]]},{"id":"6c397fa8917f9a86","type":"inject","z":"457f9988695be7c4","name":"tägl. 02:00Uhr","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"Counter_Reset","vt":"str"}],"repeat":"","crontab":"00 02 * * *","once":false,"onceDelay":0.1,"topic":"Counter_Reset","payload":"","payloadType":"date","x":127,"y":861,"wires":[["ec6877f94fdbf330"]]},{"id":"2dc5dceec8bc5fe5","type":"switch","z":"457f9988695be7c4","name":"topic","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"estimated_actuals","vt":"str"},{"t":"eq","v":"forecasts","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":480,"wires":[[],["a5cb0f26a080725b","62e234f625a2a02a"]]},{"id":"b1f52ecbb1c743c5","type":"inject","z":"457f9988695be7c4","name":"estimated_actuals","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"estimated_actuals","payload":"","payloadType":"date","x":135,"y":1073,"wires":[[]]},{"id":"39febf8dd840c45e","type":"comment","z":"457f9988695be7c4","name":"Manuelle Abfragen","info":"","x":126,"y":975,"wires":[]},{"id":"58231316133afbbb","type":"comment","z":"457f9988695be7c4","name":"Zeitgesteuerte Abfragen","info":"","x":120,"y":300,"wires":[]},{"id":"3e4d03c3c94e9d0d","type":"comment","z":"457f9988695be7c4","name":"API abfragen","info":"","x":630,"y":480,"wires":[]},{"id":"b1a608779bbca9bf","type":"comment","z":"457f9988695be7c4","name":"50 API-Calls pro Tag möglich","info":"","x":865,"y":860,"wires":[]},{"id":"2e79f304435b99b2","type":"comment","z":"457f9988695be7c4","name":"Reset counter","info":"","x":110,"y":820,"wires":[]},{"id":"817124037088499e","type":"inject","z":"457f9988695be7c4","name":"Counter_Reset","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Counter_Reset","payload":"","payloadType":"date","x":126,"y":898,"wires":[["6fba0be572ad1fcc"]]},{"id":"4feaa555ebe704cb","type":"debug","z":"457f9988695be7c4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"count","targetType":"msg","statusVal":"count","statusType":"auto","x":880,"y":960,"wires":[]},{"id":"cbda7ba3f1b5dd8c","type":"counter","z":"457f9988695be7c4","name":"Counter","init":"0","step":"1","lower":null,"upper":null,"mode":"increment","outputs":"1","x":719,"y":899,"wires":[["c8a0bcb16c3e26a7","4feaa555ebe704cb"]]},{"id":"69982da8785adefe","type":"time-inject","z":"457f9988695be7c4","name":"forecasts","nameInt":"Sonnenaufgang Beginn↶ - Sonnenuntergang Ende↷ =... ↻150min","positionConfig":"8c7609ce.dd5798","props":[{"p":"","pt":"msgPayload","v":"","vt":"date","o":"1","oT":"none","oM":"60000","f":0,"fS":0,"fT":"Millisekunden UNIX-Zeit","fI":"0","next":true,"days":"*","months":"*","onlyOddDays":false,"onlyEvenDays":false,"onlyOddWeeks":false,"onlyEvenWeeks":false},{"p":"","pt":"msgTopic","v":"forecasts","vt":"str","o":"1","oT":"none","oM":"60000","f":0,"fS":0,"fT":"Millisekunden UNIX-Zeit","fI":"0","next":false,"days":"*","months":"*","onlyOddDays":false,"onlyEvenDays":false,"onlyOddWeeks":false,"onlyEvenWeeks":false}],"injectTypeSelect":"interval-time","intervalCount":"150","intervalCountType":"num","intervalCountMultiplier":60000,"time":"sunriseStart","timeType":"pdsTime","offset":"-15","offsetType":"num","offsetMultiplier":60000,"timeEnd":"sunsetEnd","timeEndType":"pdsTime","timeEndOffset":"15","timeEndOffsetType":"num","timeEndOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeOnlyOddWeeks":false,"timeOnlyEvenWeeks":false,"timeMonths":"*","timedatestart":"","timedateend":"","property":"","propertyType":"none","propertyCompare":"true","propertyThreshold":"","propertyThresholdType":"num","timeAlt":"","timeAltType":"entered","timeAltDays":"*","timeAltOnlyOddDays":false,"timeAltOnlyEvenDays":false,"timeAltOnlyOddWeeks":false,"timeAltOnlyEvenWeeks":false,"timeAltMonths":"*","timeAltOffset":0,"timeAltOffsetType":"none","timeAltOffsetMultiplier":60000,"once":false,"onceDelay":0.1,"recalcTime":2,"x":100,"y":380,"wires":[[]]},{"id":"a6859388b3b826d8","type":"time-inject","z":"457f9988695be7c4","name":"estimated_actuals","nameInt":"Sonnenaufgang Beginn↷ - Sonnenuntergang Ende↷ =... ↻4h","positionConfig":"8c7609ce.dd5798","props":[{"p":"","pt":"msgPayload","v":"","vt":"date","o":"1","oT":"none","oM":"60000","f":0,"fS":0,"fT":"Millisekunden UNIX-Zeit","fI":"0","next":true,"days":"*","months":"*","onlyOddDays":false,"onlyEvenDays":false,"onlyOddWeeks":false,"onlyEvenWeeks":false},{"p":"","pt":"msgTopic","v":"estimated_actuals","vt":"str","o":"1","oT":"none","oM":"60000","f":0,"fS":0,"fT":"Millisekunden UNIX-Zeit","fI":"0","next":false,"days":"*","months":"*","onlyOddDays":false,"onlyEvenDays":false,"onlyOddWeeks":false,"onlyEvenWeeks":false}],"injectTypeSelect":"interval-time","intervalCount":"4","intervalCountType":"num","intervalCountMultiplier":3600000,"time":"sunriseStart","timeType":"pdsTime","offset":"90","offsetType":"num","offsetMultiplier":60000,"timeEnd":"sunsetEnd","timeEndType":"pdsTime","timeEndOffset":"60","timeEndOffsetType":"num","timeEndOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeOnlyOddWeeks":false,"timeOnlyEvenWeeks":false,"timeMonths":"*","timedatestart":"","timedateend":"","property":"","propertyType":"none","propertyCompare":"true","propertyThreshold":"","propertyThresholdType":"num","timeAlt":"","timeAltType":"entered","timeAltDays":"*","timeAltOnlyOddDays":false,"timeAltOnlyEvenDays":false,"timeAltOnlyOddWeeks":false,"timeAltOnlyEvenWeeks":false,"timeAltMonths":"*","timeAltOffset":0,"timeAltOffsetType":"none","timeAltOffsetMultiplier":60000,"once":false,"onceDelay":0.1,"recalcTime":2,"x":130,"y":344,"wires":[[]]},{"id":"ec6877f94fdbf330","type":"within-time-switch","z":"457f9988695be7c4","name":"neuer Tag?","nameInt":"","positionConfig":"8c7609ce.dd5798","startTime":"sunriseStart","startTimeType":"pdsTime","startOffset":"-15","startOffsetType":"num","startOffsetMultiplier":60000,"endTime":"sunsetEnd","endTimeType":"pdsTime","endOffset":"60","endOffsetType":"num","endOffsetMultiplier":60000,"timeRestrictions":"","timeRestrictionsType":"none","timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeOnlyOddWeeks":false,"timeOnlyEvenWeeks":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"withinTimeValue":"","withinTimeValueType":"msgInput","outOfTimeValue":"","outOfTimeValueType":"msgInput","tsCompare":"0","x":310,"y":760,"wires":[["cbda7ba3f1b5dd8c"],["6fba0be572ad1fcc"]]},{"id":"62e234f625a2a02a","type":"http request","z":"457f9988695be7c4","name":"Solcast API - get Live+Forecast JSON WEST","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.solcast.com.au/rooftop_sites/304b-3a2f-9df3","tls":"","persist":false,"proxy":"","authType":"basic","senderr":false,"x":630,"y":520,"wires":[["50f9f1260a2a3cab"]]},{"id":"50f9f1260a2a3cab","type":"switch","z":"457f9988695be7c4","name":"StatusCode","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":930,"y":520,"wires":[["7abdec93c3917d24"],["96fb7138c35bd826","c0e0319e8b59c5ca"]]},{"id":"96fb7138c35bd826","type":"change","z":"457f9988695be7c4","name":"timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"},{"t":"delete","p":"statusCode","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1230,"y":620,"wires":[["5e61daf7a3b261cc"]]},{"id":"5e61daf7a3b261cc","type":"delay","z":"457f9988695be7c4","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1400,"y":620,"wires":[[]]},{"id":"9b87473e30525c73","type":"function","z":"457f9988695be7c4","name":"","func":"var pl = msg.payload;\n\n// check if both east and west forecasts are present, otherwise\n// return null;\n\nif (pl[1].forecasts_east == null) \n return null;\n\nfor (var i = 0; i < pl[1].forecasts_east.length; i++) {\n pl[3].forecasts_sum[i].pv_estimate = pl[1].forecasts_east[i].pv_estimate + pl[2].forecasts_west[i].pv_estimate;\n pl[3].forecasts_sum[i].pv_estimate10 = pl[1].forecasts_east[i].pv_estimate10 + pl[2].forecasts_west[i].pv_estimate10;\n pl[3].forecasts_sum[i].pv_estimate90 = pl[1].forecasts_east[i].pv_estimate90 + pl[2].forecasts_west[i].pv_estimate90;\n}\n\n\nmsg.payload = pl;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1920,"y":520,"wires":[[]]},{"id":"97018d3b633cf398","type":"change","z":"457f9988695be7c4","name":"move forecasts to east","rules":[{"t":"move","p":"payload.forecasts","pt":"msg","to":"payload.east","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1400,"y":360,"wires":[["2cfafacddcd55a7a","ce02c767e8a8b238"]]},{"id":"2cfafacddcd55a7a","type":"join","z":"457f9988695be7c4","name":"","mode":"custom","build":"merged","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1810,"y":440,"wires":[["14907db5abceeee3"]]},{"id":"36bcb8e0090dfe99","type":"change","z":"457f9988695be7c4","name":"move forecasts to west","rules":[{"t":"move","p":"payload.forecasts","pt":"msg","to":"payload.west","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1400,"y":540,"wires":[["2cfafacddcd55a7a"]]},{"id":"14907db5abceeee3","type":"debug","z":"457f9988695be7c4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2050,"y":440,"wires":[]},{"id":"ce02c767e8a8b238","type":"change","z":"457f9988695be7c4","name":"copy east to sum","rules":[{"t":"set","p":"payload.sum","pt":"msg","to":"payload.east","tot":"msg"},{"t":"delete","p":"payload.east","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1690,"y":360,"wires":[["2cfafacddcd55a7a"]]},{"id":"265829a5ea960730","type":"mock","z":"457f9988695be7c4","name":"","x":1190,"y":360,"wires":[["97018d3b633cf398"]]},{"id":"7abdec93c3917d24","type":"mock","z":"457f9988695be7c4","name":"","x":1190,"y":540,"wires":[["36bcb8e0090dfe99"]]},{"id":"8c7609ce.dd5798","type":"position-config","name":"DACH-1","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":99,"timeZoneDST":0,"stateTimeFormat":"3","stateDateFormat":"12","contextStore":""}]
What I also tried was moving the mock node between the API call and the Statuscode node. When I then did an API call and afterwards used the mock node, the Statuscall node went into the delay part, because statusCode != 200. So somehow the mock node doesn't store the message correctly.
