SOLVED
Sorry.
Forgot to set filemode to 1
Sorry folks. I'm stuck with this.
This is the crux of the flow:
The idea is that the picture is taken with the name being determined by the date.
So a picture taken now (Local time: 2018/11/18 08:37:00) would be something like:
But it isn't.
I am setting up the variables for the name and sending it to the camera node as documented.
[{"id":"f0954cb4.ac8a98","type":"inject","z":"d57de863.41484","name":"","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":120,"wires":[["8eb6bc88.a38f6"]]},{"id":"8eb6bc88.a38f6","type":"switch","z":"d57de863.41484","name":"Check if this is the one","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"}],"checkall":"true","outputs":1,"x":320,"y":200,"wires":[["76de7ecd.99f2e"]]},{"id":"76de7ecd.99f2e","type":"function","z":"d57de863.41484","name":"Time Stamp","func":"//msg.payload = new.Datre().toString();\nmsg.payload = new Date();\nreturn msg;\n","outputs":1,"noerr":0,"x":510,"y":200,"wires":[["903f31a1.8bbdf8","583464b7.480ff4"]]},{"id":"903f31a1.8bbdf8","type":"moment","z":"d57de863.41484","name":"Time format","topic":"","input":"","inputType":"msg","inTz":"Australia/Sydney","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYYMMDD-HHmmss.png","locale":"en_AU","output":"","outputType":"msg","outTz":"Australia/Sydney","x":690,"y":200,"wires":[["6510828d.aaae54"]]},{"id":"6510828d.aaae54","type":"change","z":"d57de863.41484","name":"","rules":[{"t":"set","p":"filepath","pt":"msg","to":"/home/pi/Pictures/Local_Camera/","tot":"str"},{"t":"set","p":"filename","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":120,"y":260,"wires":[["86adab98.09c0f","ed9b32bf.7cfd78","ca3dda73.a1df68"]]},{"id":"ca3dda73.a1df68","type":"camerapi-takephoto","z":"d57de863.41484","filemode":"2","filename":"","filedefpath":"1","filepath":"","fileformat":"jpeg","resolution":"5","rotation":"0","fliph":"0","flipv":"0","brightness":"50","contrast":"0","sharpness":"0","imageeffect":"none","name":"","x":370,"y":260,"wires":[["e90f6be1.bc247","87bbd11b.e59a08","6c63e369.b7f124"]]}]
But I am getting this as the filename:
"/home/pi/Pictures/pic_529b13a1-bd03-4ac4-baea-11854bf0ff17.jpg"
I am probably missing an elephant - somewhere.
Someone mind taking a peep at the flow?
