Some Advise by using "http request" node
ALL
I use the http request node to instruct a system to do something
where single command is used it work fine.
http://192.168.1.11:11111/api/v1/telescope/0/unpark
But the question is how to deal with the following http string
http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinatesasync" -H "accept: application/json" -H "Content-Type: application/x-www-form-urlencoded" -d "RightAscension=0&Declination=90&ClientID=&ClientTransactionID="
the following is not working
[{"id":"4162b8d3.6fadb8","type":"ui_button","z":"55c1b3dc.91214c","name":"Goto ZeroPosition","group":"8e238b13.7c40b8","order":14,"width":0,"height":0,"passthru":false,"label":"<font size=\"+1\">Goto ZeroPosition</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":190,"y":840,"wires":[["8932f8e.c5c8888"]]},{"id":"8932f8e.c5c8888","type":"http request","z":"55c1b3dc.91214c","name":"","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinates  -d \"RightAscension=0&Declination=90\"","tls":"","persist":false,"proxy":"","authType":"","x":390,"y":840,"wires":[[]]},{"id":"8e238b13.7c40b8","type":"ui_group","name":"ALPACA","tab":"dd962aa5.a268f8","order":2,"disp":true,"width":"8","collapse":true},{"id":"dd962aa5.a268f8","type":"ui_tab","name":"OCS","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Hoop some can help or give some advise
Chris
Look at this post where I demonstrate how to break down a curl to a request.
Try
http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinatesasync?RightAscension=0&Declination=90&ClientID=&ClientTransactionID=
thanks
this is working via the command line
curl -X PUT "http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinatesasync" -H "accept: application/json" -H "Content-Type: application/x-www-form-urlencoded" -d "RightAscension=0&Declination=90"
unfortunately this is not working
and what is wrong with the payload below
[{"id":"37d01ae9.869d66","type":"change","z":"55c1b3dc.91214c","name":"","rules":[{"t":"set","p":"headers","pt":"msg","to":"{\"accept\": \"application/json\" }","tot":"json"},{"t":"set","p":"headers","pt":"msg","to":"{\"Content-Type\":\"application/x-www-form-urlencoded\"}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"{\"RightAscension=0&Declination=90\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":900,"wires":[[]]}]
Chris
then try adding the data as the body using msg.payload. and setting the headers.
[{"id":"8cc43cea.d1c7d8","type":"inject","z":"5a245aa1.510164","name":"","props":[{"p":"payload"},{"p":"headers.Content-Type","v":"application/x-www-form-urlencoded","vt":"str"},{"p":"headers.accept","v":"application/json","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"RightAscension=0&Declination=90","payloadType":"str","x":160,"y":3500,"wires":[["c6ad4b46.d17d48"]]},{"id":"c6ad4b46.d17d48","type":"http request","z":"5a245aa1.510164","name":"","method":"PUT","ret":"obj","paytoqs":"ignore","url":"http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinatesasync","tls":"","persist":false,"proxy":"","authType":"","x":350,"y":3500,"wires":[[]]}]
i got in debug
"Invalid 'to' JSON property"
Chris
Here is a demo using what I think you might ultimately need (variable values for the RightAscension and Declination)...
↑ obviously the requests dont work for me.
the demo flows...
[{"id":"8301c88b.e286b8","type":"inject","z":"b872cb4b.5a6448","name":"RightAscension 0 Declination 90","props":[{"p":"payload"},{"p":"payload.RightAscension","v":"0","vt":"num"},{"p":"payload.Declination","v":"90","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{}","payloadType":"json","x":870,"y":740,"wires":[["7a0a8426.78786c"]]},{"id":"9f3f7877.59ad98","type":"function","z":"b872cb4b.5a6448","name":"set headers","func":"msg.headers = {\n    \"accept\": \"application/json\",\n    \"Content-Type\": \"application/x-www-form-urlencoded\",\n}\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1370,"y":760,"wires":[["fa3f2e29.7e9ac","598d20a3.9bea2"]]},{"id":"fa3f2e29.7e9ac","type":"http request","z":"b872cb4b.5a6448","name":"","method":"PUT","ret":"txt","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":1570,"y":760,"wires":[["8d3bfd6c.d8f8"]]},{"id":"7a0a8426.78786c","type":"function","z":"b872cb4b.5a6448","name":"attempt 1 (using payload)","func":"var RightAscension = msg.payload.RightAscension\nvar Declination = msg.payload.Declination\n\nmsg.url = \"http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinatesasync\"\nmsg.payload = `RightAscension=${RightAscension}&Declination=${Declination}`\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1160,"y":760,"wires":[["9f3f7877.59ad98"]]},{"id":"8d3bfd6c.d8f8","type":"debug","z":"b872cb4b.5a6448","name":"V1 result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1720,"y":760,"wires":[]},{"id":"a2750b93.af00f8","type":"inject","z":"b872cb4b.5a6448","name":"RightAscension 90 Declination 30","props":[{"p":"payload"},{"p":"payload.RightAscension","v":"90","vt":"num"},{"p":"payload.Declination","v":"30","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{}","payloadType":"json","x":870,"y":800,"wires":[["7a0a8426.78786c"]]},{"id":"fbd4311b.9c659","type":"function","z":"b872cb4b.5a6448","name":"set headers","func":"msg.headers = {\n    \"accept\": \"application/json\",\n    \"Content-Type\": \"application/x-www-form-urlencoded\",\n}\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1390,"y":880,"wires":[["4ed0cca8.0db5a4","a789f57d.205a78"]]},{"id":"e6aab007.b9b42","type":"function","z":"b872cb4b.5a6448","name":"attempt 2 (using url params)","func":"var RightAscension = msg.payload.RightAscension\nvar Declination = msg.payload.Declination\n\nvar params = `RightAscension=${RightAscension}&Declination=${Declination}`\nmsg.url = \"http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinatesasync?\" + params;\nmsg.payload = \"\";\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1170,"y":880,"wires":[["fbd4311b.9c659"]]},{"id":"4ed0cca8.0db5a4","type":"http request","z":"b872cb4b.5a6448","name":"","method":"PUT","ret":"txt","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":1570,"y":880,"wires":[["f241a6a9.027678"]]},{"id":"c48f3eda.259d6","type":"inject","z":"b872cb4b.5a6448","name":"RightAscension 0 Declination 90","props":[{"p":"payload"},{"p":"payload.RightAscension","v":"0","vt":"num"},{"p":"payload.Declination","v":"90","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{}","payloadType":"json","x":870,"y":860,"wires":[["e6aab007.b9b42"]]},{"id":"6b235dc3.8eb1e4","type":"inject","z":"b872cb4b.5a6448","name":"RightAscension 90 Declination 30","props":[{"p":"payload"},{"p":"payload.RightAscension","v":"90","vt":"num"},{"p":"payload.Declination","v":"30","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{}","payloadType":"json","x":870,"y":920,"wires":[["e6aab007.b9b42"]]},{"id":"f241a6a9.027678","type":"debug","z":"b872cb4b.5a6448","name":"V2 result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1720,"y":880,"wires":[]},{"id":"598d20a3.9bea2","type":"debug","z":"b872cb4b.5a6448","name":"check headers and url and payload","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1300,"y":800,"wires":[]},{"id":"a789f57d.205a78","type":"debug","z":"b872cb4b.5a6448","name":"check headers and url","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1360,"y":920,"wires":[]}]
uncheck return a json object in http request node.
All sorry for the late reaction and special all of you who directly replayed.
i understand its no argument but i was to busy with work. Today i was able to test your suggestions
i like to inform you, that its working, thanks to you all.
[{"id":"4162b8d3.6fadb8","type":"ui_button","z":"55c1b3dc.91214c","name":"Goto ZeroPosition","group":"8e238b13.7c40b8","order":14,"width":0,"height":0,"passthru":false,"label":"<font size=\"+1\">Goto ZeroPosition</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":150,"y":800,"wires":[["37d01ae9.869d66"]]},{"id":"8932f8e.c5c8888","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Telescope-slewtocoordinatesasync","method":"PUT","ret":"obj","paytoqs":"ignore","url":"http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinatesasync","tls":"","persist":false,"proxy":"","authType":"","x":680,"y":800,"wires":[["261e81ee.00f02e"]]},{"id":"37d01ae9.869d66","type":"change","z":"55c1b3dc.91214c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"RightAscension=0&Declination=90","tot":"str"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/x-www-form-urlencoded","tot":"str"},{"t":"set","p":"headers.accept","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":800,"wires":[["8932f8e.c5c8888"]]},{"id":"261e81ee.00f02e","type":"debug","z":"55c1b3dc.91214c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":800,"wires":[]},{"id":"8e238b13.7c40b8","type":"ui_group","name":"ALPACA","tab":"dd962aa5.a268f8","order":2,"disp":true,"width":"8","collapse":true},{"id":"dd962aa5.a268f8","type":"ui_tab","name":"OCS","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
There was also thinking falure which i didn't account when the telescope is parked you cant slew you need first unpark the telescope.
This is is the new way ho to communicated with telescope with Alpaca
ascom alpaca api
#ASCOMALPACA #ALPACA
this are the items i have implemented yet i will share it below so others can use it also.
[{"id":"3096177c.ea0ea8","type":"ui_text","z":"55c1b3dc.91214c","group":"8e238b13.7c40b8","order":5,"width":0,"height":0,"name":"Dome-Shutter-txt","label":"<font size=\"+1\">RoR Shutter :</font>","format":"{{msg.payload}}","layout":"row-spread","x":990,"y":260,"wires":[]},{"id":"a2190f84.12cbf","type":"inject","z":"55c1b3dc.91214c","name":"Dome-Shutterstatus","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":"0","topic":"","payload":"api/v1/dome/0/shutterstatus","payloadType":"str","x":140,"y":260,"wires":[["cf2bce93.449e8"]]},{"id":"cf2bce93.449e8","type":"http request","z":"55c1b3dc.91214c","name":"GET REST-Dome-Shutter-Status","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.9:6800/{{{payload}}}","tls":"","persist":false,"proxy":"","authType":"","x":410,"y":260,"wires":[["cd8ef741.aa72f8"]]},{"id":"cd8ef741.aa72f8","type":"function","z":"55c1b3dc.91214c","name":"","func":"rc = msg.statusCode;\nif ( (rc == \"EHOSTUNREACH\") || (rc == \"ETIMEDOUT\") ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/A</font>\";\n  } else if ( rc == 400 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/C</font>\";\n} else if ( rc == 200 ) {\n  p=JSON.parse(msg.payload)\n  if ( p.Value == 0 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"white\\\">Open</font>\";\n  } else if ( p.Value == 1 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"lime\\\">Closed</font>\";\n  } else if ( p.Value == 2 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"orange\\\">Opening</font>\";\n  } else if ( p.Value == 3 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"orange\\\">Closing</font>\";\n  } else if ( p.Value == 4 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"red\\\">ERROR</font>\";\n  }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":620,"y":260,"wires":[["6dddcf05.0dc41"]]},{"id":"6dddcf05.0dc41","type":"rbe","z":"55c1b3dc.91214c","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":830,"y":260,"wires":[["3096177c.ea0ea8"]]},{"id":"eca3b1c1.d4af6","type":"ui_text","z":"55c1b3dc.91214c","group":"8e238b13.7c40b8","order":9,"width":0,"height":0,"name":"Telescope-Tracking.txt","label":"<font size=\"+1\">Telescope Tracking :</font>","format":"{{msg.payload}}","layout":"row-spread","x":1000,"y":540,"wires":[]},{"id":"87d16c91.ef369","type":"comment","z":"55c1b3dc.91214c","name":"Telescope","info":"","x":180,"y":360,"wires":[]},{"id":"5b4dade.86af454","type":"ui_text","z":"55c1b3dc.91214c","group":"8e238b13.7c40b8","order":7,"width":0,"height":0,"name":"Telescope-Pier.txt","label":"<font size=\"+1\">Telescope PierSide :</font>","format":"{{msg.payload}}","layout":"row-spread","x":990,"y":460,"wires":[]},{"id":"747845ec.c6ecdc","type":"inject","z":"55c1b3dc.91214c","name":"Telescope-SideOfPier","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":"0","topic":"sideofpier","payload":"api/v1/telescope/0/sideofpier","payloadType":"str","x":140,"y":460,"wires":[["d65a9d4f.561a6"]]},{"id":"d65a9d4f.561a6","type":"http request","z":"55c1b3dc.91214c","name":"GET-REST-Telescope-Pier","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/{{{payload}}}","tls":"","persist":false,"proxy":"","authType":"","x":390,"y":460,"wires":[["46dc73ca.b7181c"]]},{"id":"46dc73ca.b7181c","type":"function","z":"55c1b3dc.91214c","name":"","func":"rc = msg.statusCode;\nif ( (rc == \"EHOSTUNREACH\") || (rc == \"ETIMEDOUT\") ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/A</font>\";\n} else if ( rc == 400 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/C</font>\";\n} else if ( rc == 200 ) {\n   p=JSON.parse(msg.payload)\n   msg.payload=\"<font size=\\\"+2\\\" color=\\\"orange\\\">Unknown</font>\";\n   if ( p.Value == 0 ) {\n      msg.payload=\"<font size=\\\"+2\\\" color=\\\"lime\\\">East</font>\";\n   } else if ( p.Value == 1 ) {\n      msg.payload=\"<font size=\\\"+2\\\" color=\\\"lime\\\">West</font>\";\n   }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":620,"y":460,"wires":[["5eaaeccb.f0ac34"]]},{"id":"254a5d6c.74ad12","type":"ui_text","z":"55c1b3dc.91214c","group":"8e238b13.7c40b8","order":6,"width":0,"height":0,"name":"Telescope-AtPark.txt","label":"<font size=\"+1\">Telescope Parked :</font>","format":"{{msg.payload}}","layout":"row-spread","x":1000,"y":420,"wires":[]},{"id":"a4c244f7.06b468","type":"inject","z":"55c1b3dc.91214c","name":"Telescope-AtPark","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":"0","topic":"","payload":"api/v1/telescope/0/atpark","payloadType":"str","x":150,"y":420,"wires":[["8bbe44b9.8eabd8"]]},{"id":"8bbe44b9.8eabd8","type":"http request","z":"55c1b3dc.91214c","name":"GET-REST-Telescope-park","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/{{{payload}}}","tls":"","persist":false,"proxy":"","authType":"","x":400,"y":420,"wires":[["97de4e3d.05ce"]]},{"id":"97de4e3d.05ce","type":"function","z":"55c1b3dc.91214c","name":"","func":"rc = msg.statusCode;\nif ( (rc == \"EHOSTUNREACH\") || (rc == \"ETIMEDOUT\") ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/A</font>\";\n} else if ( rc == 400 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/C</font>\";\n} else if ( rc == 200 ) {\n   p=JSON.parse(msg.payload)\n   msg.payload=\"<font size=\\\"+2\\\" color=red>Yes</font>\";\n   if ( p.Value == false ) {\n      msg.payload=\"<font size=\\\"+2\\\" color=red>No</font>\";\n   }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":620,"y":420,"wires":[["d8f2e7c1.6a2fa8"]]},{"id":"decb3adc.3a2c98","type":"ui_text","z":"55c1b3dc.91214c","group":"8e238b13.7c40b8","order":8,"width":0,"height":0,"name":"Telescope-Slewing.txt","label":"<font size=\"+1\">Telescope Moving :</font>","format":"{{msg.payload}}","layout":"row-spread","x":1000,"y":500,"wires":[]},{"id":"deb9fe9.65317","type":"inject","z":"55c1b3dc.91214c","name":"Telescope-Slewing","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"5","crontab":"","once":true,"onceDelay":"0","topic":"api/v1/telescope/0/slewing","payload":"api/v1/telescope/0/slewing","payloadType":"str","x":150,"y":500,"wires":[["20eea3e8.7befdc"]]},{"id":"20eea3e8.7befdc","type":"http request","z":"55c1b3dc.91214c","name":"GET-REST-Telescope-slew","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/{{{payload}}}","tls":"","persist":false,"proxy":"","authType":"","x":400,"y":500,"wires":[["1e0dbe66.f31c02"]]},{"id":"1e0dbe66.f31c02","type":"function","z":"55c1b3dc.91214c","name":"","func":"rc = msg.statusCode;\nif ( (rc == \"EHOSTUNREACH\") || (rc == \"ETIMEDOUT\") ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/A</font>\";\n} else if ( rc == 400 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/C</font>\";\n} else if ( rc == 200 ) {\n    p=JSON.parse(msg.payload)\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"lime\\\">No</font>\";\n    if ( p.Value == true ) {\n       msg.payload=\"<font size=\\\"+2\\\" color=\\\"orange\\\">Yes</font>\";\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"x":620,"y":500,"wires":[["2c9ad16.607962e"]]},{"id":"8364737b.8b7ea","type":"inject","z":"55c1b3dc.91214c","name":"Telescope-Tracking","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"5","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"api/v1/telescope/0/tracking","payloadType":"str","x":140,"y":540,"wires":[["f9500ac8.79c278"]]},{"id":"f9500ac8.79c278","type":"http request","z":"55c1b3dc.91214c","name":"GET-REST-Telescope-Tracking","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/{{{payload}}}","tls":"","persist":false,"proxy":"","authType":"","x":410,"y":540,"wires":[["1abb18c2.03fd87"]]},{"id":"1abb18c2.03fd87","type":"function","z":"55c1b3dc.91214c","name":"","func":"rc = msg.statusCode;\nif ( (rc == \"EHOSTUNREACH\") || (rc == \"ETIMEDOUT\") ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/A</font>\";\n  } else if ( rc == 400 ) {\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"yellow\\\">N/C</font>\";\n} else if ( rc == 200 ) {\n    p=JSON.parse(msg.payload)\n    msg.payload=\"<font size=\\\"+2\\\" color=\\\"orange\\\">No</font>\";\n    if ( p.Value == true ) {\n       msg.payload=\"<font size=\\\"+2\\\" color=\\\"lime\\\">Yes</font>\";\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":620,"y":540,"wires":[["39c4f7cc.120e68"]]},{"id":"42a6d543.788f6c","type":"catch","z":"55c1b3dc.91214c","name":"HostDown","scope":["d65a9d4f.561a6","8bbe44b9.8eabd8","20eea3e8.7befdc","f9500ac8.79c278"],"uncaught":false,"x":180,"y":800,"wires":[["e50f9d17.12517"]]},{"id":"e50f9d17.12517","type":"debug","z":"55c1b3dc.91214c","name":"","active":true,"tosidebar":false,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":350,"y":800,"wires":[]},{"id":"39c4f7cc.120e68","type":"rbe","z":"55c1b3dc.91214c","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":830,"y":540,"wires":[["eca3b1c1.d4af6"]]},{"id":"2c9ad16.607962e","type":"rbe","z":"55c1b3dc.91214c","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":830,"y":500,"wires":[["decb3adc.3a2c98"]]},{"id":"5eaaeccb.f0ac34","type":"rbe","z":"55c1b3dc.91214c","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":830,"y":460,"wires":[["5b4dade.86af454"]]},{"id":"d8f2e7c1.6a2fa8","type":"rbe","z":"55c1b3dc.91214c","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":830,"y":420,"wires":[["254a5d6c.74ad12"]]},{"id":"d3d202e6.6ad9d8","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Telescope-park","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/api/v1/telescope/0/park","tls":"","persist":false,"proxy":"","authType":"","x":620,"y":580,"wires":[[]]},{"id":"4aa5d844.82e868","type":"ui_button","z":"55c1b3dc.91214c","name":"Park Telescope ","group":"8e238b13.7c40b8","order":10,"width":4,"height":1,"passthru":false,"label":"<font size=\"+1\">Park</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","x":160,"y":580,"wires":[["d3d202e6.6ad9d8"]]},{"id":"30e9ee62.f81dd2","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Dome-shutter-poweron","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.9:6800/api/v1/dome/0/poweron","tls":"","persist":false,"proxy":"","authType":"","x":740,"y":80,"wires":[[]]},{"id":"494b73a9.205c44","type":"ui_button","z":"55c1b3dc.91214c","name":"Ropen","group":"8e238b13.7c40b8","order":3,"width":4,"height":1,"passthru":false,"label":"<font size=\"+1\">Roof 0pen</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":170,"y":180,"wires":[["2f11568d.21a302"]]},{"id":"2f11568d.21a302","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Dome-shutteropen","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.9:6800/api/v1/dome/0/openshutter","tls":"","persist":false,"proxy":"","authType":"","x":410,"y":180,"wires":[[]]},{"id":"582142a3.de27b4","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Dome-shutter-poweroff","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.9:6800/api/v1/dome/0/poweroff","tls":"","persist":false,"proxy":"","authType":"","x":740,"y":120,"wires":[[]]},{"id":"38580415.ca19dc","type":"ui_button","z":"55c1b3dc.91214c","name":"Rclose","group":"8e238b13.7c40b8","order":4,"width":4,"height":1,"passthru":false,"label":"<font size=\"+1\">Roof Close</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":170,"y":220,"wires":[["caca5c71.1e464"]]},{"id":"caca5c71.1e464","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Dome-shutterclose","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.9:6800/api/v1/dome/0/closeshutter","tls":"","persist":false,"proxy":"","authType":"","x":410,"y":220,"wires":[[]]},{"id":"5c358de5.3cbf84","type":"ui_switch","z":"55c1b3dc.91214c","name":"","label":"Roof power off / on","tooltip":"","group":"8e238b13.7c40b8","order":1,"width":5,"height":1,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","x":150,"y":100,"wires":[["4e11a3fb.4d78c4","8a44c5c2.b51148"]]},{"id":"4e11a3fb.4d78c4","type":"switch","z":"55c1b3dc.91214c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":100,"wires":[["30e9ee62.f81dd2"],["11b68e35.d8dcc2"]]},{"id":"11b68e35.d8dcc2","type":"change","z":"55c1b3dc.91214c","name":"o to 1","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":120,"wires":[["582142a3.de27b4"]]},{"id":"2b68f9b7.7457d6","type":"comment","z":"55c1b3dc.91214c","name":"Role of Roof","info":"","x":170,"y":40,"wires":[]},{"id":"8a44c5c2.b51148","type":"function","z":"55c1b3dc.91214c","name":"Color function","func":"switch (msg.payload) {\n\ncase 1 : \n    msg.color = \"Green\";\n    msg.payload = \"Aan\";\n    break;\n    \ncase 0 : \n    msg.color = \"Red\";\n    msg.payload = \"Uit\";\n    break;\n    \ndefault : \n    msg.color = \"Gray\";\n    msg.payload = \"not set\";\n    break;\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":420,"y":40,"wires":[["336a8046.93942"]]},{"id":"336a8046.93942","type":"ui_text","z":"55c1b3dc.91214c","group":"8e238b13.7c40b8","order":2,"width":3,"height":1,"name":"Dak Power Status","label":"STATUS :","format":"<font color= {{msg.color}} > {{msg.payload}} </font>","layout":"row-left","x":630,"y":40,"wires":[]},{"id":"54a887ec.0f59a","type":"ui_button","z":"55c1b3dc.91214c","name":"UnPark Telescope","group":"8e238b13.7c40b8","order":11,"width":4,"height":1,"passthru":false,"label":"<font size=\"+1\">UnPark</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":150,"y":620,"wires":[["a91b65fa.a077a8"]]},{"id":"a91b65fa.a077a8","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Telescope-UnPark","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/api/v1/telescope/0/unpark","tls":"","persist":false,"proxy":"","authType":"","x":630,"y":620,"wires":[[]]},{"id":"e012f7c8.b7d","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Telescope-Tracking","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/api/v1/telescope/0/tracking","tls":"","persist":false,"proxy":"","authType":"","x":630,"y":660,"wires":[[]]},{"id":"8f2b600a.afa79","type":"ui_button","z":"55c1b3dc.91214c","name":"Tracking-On","group":"8e238b13.7c40b8","order":12,"width":4,"height":1,"passthru":false,"label":"<font size=\"+1\">Tracking-On</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":170,"y":660,"wires":[["27f283b.48d91fc"]]},{"id":"4162b8d3.6fadb8","type":"ui_button","z":"55c1b3dc.91214c","name":"Goto ZeroPosition","group":"8e238b13.7c40b8","order":14,"width":0,"height":0,"passthru":false,"label":"<font size=\"+1\">Goto ZeroPosition</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":150,"y":740,"wires":[["37d01ae9.869d66"]]},{"id":"8932f8e.c5c8888","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Telescope-slewtocoordinatesasync","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/api/v1/telescope/0/slewtocoordinatesasync","tls":"","persist":false,"proxy":"","authType":"","x":680,"y":740,"wires":[[]]},{"id":"37d01ae9.869d66","type":"change","z":"55c1b3dc.91214c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"RightAscension=0&Declination=90","tot":"str"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/x-www-form-urlencoded","tot":"str"},{"t":"set","p":"headers.accept","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":740,"wires":[["8932f8e.c5c8888"]]},{"id":"27f283b.48d91fc","type":"change","z":"55c1b3dc.91214c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Tracking=true","tot":"str"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/x-www-form-urlencoded","tot":"str"},{"t":"set","p":"headers.accept","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":660,"wires":[["e012f7c8.b7d"]]},{"id":"51869a66.cb35f4","type":"http request","z":"55c1b3dc.91214c","name":"PUT-REST-Telescope-Tracking","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.11:11111/api/v1/telescope/0/tracking","tls":"","persist":false,"proxy":"","authType":"","x":630,"y":700,"wires":[[]]},{"id":"7f6554cf.274ebc","type":"ui_button","z":"55c1b3dc.91214c","name":"Tracking-Off","group":"8e238b13.7c40b8","order":13,"width":4,"height":1,"passthru":false,"label":"<font size=\"+1\">Tracking-Off</font>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":170,"y":700,"wires":[["fa4a55f2.0a2218"]]},{"id":"fa4a55f2.0a2218","type":"change","z":"55c1b3dc.91214c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Tracking=False","tot":"str"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/x-www-form-urlencoded","tot":"str"},{"t":"set","p":"headers.accept","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":700,"wires":[["51869a66.cb35f4"]]},{"id":"8e238b13.7c40b8","type":"ui_group","name":"ALPACA","tab":"dd962aa5.a268f8","order":2,"disp":true,"width":"8","collapse":true},{"id":"dd962aa5.a268f8","type":"ui_tab","name":"OCS","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Again thanks for your support the excellent explanation
Chris Status Solved
