Some help needed Influx DB
Hello all.
Just created an Influx database called "test" and I want to do some tests from a simple flow. I'm new with Influx so I wonder if someone can guide me how to write the value "123" to the database. As far as I know Infux adds a timestamp. Copied from the debug frame the path is "payload" and the value is "123". Below the flow export and the relevant part of the screen.
[{"id":"c42bf290.cdbc1","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"bdc59a12.a6afb8","type":"inject","z":"c42bf290.cdbc1","name":"","topic":"","payload":"123","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":790,"y":120,"wires":[["bb2566cc.032158"]]},{"id":"bb2566cc.032158","type":"debug","z":"c42bf290.cdbc1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":990,"y":120,"wires":[]}]
Your code snippet isn't importable. please re-paste and wrap it in ``` at the start and end. Also, so far as the influx input node goes, be sure you're specifying a measurement in the node config.
Hope the code below is okay now, I have added it with the preformatted text button </> from the forum which adds ``` automatic.
The value "123" in my test will later be replaced with the value of the measurement which is an integer between 100 and 500. Do you have enough info?
You can use node-red-contrib-influxdb.
I know Colin, but no idea how to fill in the fields (except the database) :roll_eyes:
Possibly you could have said that in the original question.
Do you understand about Measurements, Tags and Fields in Influx? If not then start here:
Thanks Colin.
If you can work out the line syntax, you can simply use the http-request node to send the data. The InfluxDB node simply tries to let you send a more structured object whereas using the request node means you have to form the query string yourself - not at all hard and in some ways easier than using the node.
Have a look at this You tube video
