Node Red ist installed in Proxmox CT on an Computer. Time in Proxmox is correct.
In Node Red the time in the head section is correct, as well as in all charts, in nodes like "moon-position" and "sun-position", where I can correct the time with the "Date/Time Formatter".
But it is not correct in nodes like "within time", "eztimer" and in all nodes where date and times are showed. Some have also the UK fomat (AM/PM) instead of local format (de_AT).
I have a node "inject enhanced" - "Date/Time Formatter" which sow the correct time.
From KNX I get the correct time
How can I fix the problem to have in Node Red in all nodes the local time in the local fomat de_AT?
See here a screenshot - you can see the GMT instead of local time:
Further tests show that the time in node "simpletime" is also wrong.
