Some usage issues with Node-Red1.3.3
Recently I had a problem. My interface was always disconnected. I don't know what caused this phenomenon, and I don't know if anyone else had similar problems.
I use PM2 to control Node-red on a centos7 system. I see in the list that Node-red is online, but the page (IP :port) cannot be opened. To be exact, it cannot be opened after a period of time, not at the beginning.I need to execute "PM2 start" before the node-red page can open again. My program flow on the other machine is version 1.0.2 and it works without any exceptions.
Sounds like node-red is crashing.
Check the PM2 logs.
[TAILING] Tailing last 15 lines for [node-red] process (change the value with --lines option)
/root/.pm2/logs/node-red-error.log last 15 lines:
0|node-red | (node:10879) ExperimentalWarning: queueMicrotask() is experimental.
0|node-red | (node:10898) ExperimentalWarning: queueMicrotask() is experimental.
Thank you very much for your reply: I saw a post on the Internet saying that I need to upgrade Node. I upgraded Node from 11 to 12, but the problem is still there. Do I need to upgrade to 14.17.1 (the latest version of Node.js) and Node-red to the latest version?Or if you have other solutions, please give us some guidance. Thank you very much.
There must be more logs than that? I would expect to see a crash log somewhere.
what does pm2 log --lines 1000 give you?
Also, PM2 error logs are saved to $HOME/.pm2/logs/XXX-error.log or ~/.pm2/logs/XXX-error.log
and PM2 out logs are saved to $HOME/.pm2/logs/XXX-out.log or ~/.pm2/logs/XXX-access.log .
Where XXX is the name of your app.
Thank you again for your reply. In the "node-red-error.log" file, it is all "(node: XXXX) experimentalWarning: queueCricroTask () is experimental."
After I upgraded Node.js, there was no crash on 23rd. I don't know whether the problem has been solved or not. It seems to be normal for the moment
在 “node-red-error.log”文件中:
Welcome to Node-RED
22 Jun 18:01:11 - [info] Node-RED version: v1.3.3
22 Jun 18:01:11 - [info] Node.js version: v11.0.0
22 Jun 18:01:11 - [info] Linux 3.10.0-1160.21.1.el7.x86_64 x64 LE
22 Jun 18:01:12 - [info] Loading palette nodes
22 Jun 18:01:16 - [info] +-----------------------------------------------------
22 Jun 18:01:16 - [info] | uibuilder initialised:
22 Jun 18:01:16 - [info] | root folder: /root/.node-red/uibuilder
22 Jun 18:01:16 - [info] | version . .: 3.2.1
22 Jun 18:01:16 - [info] | packages . : socket.io
22 Jun 18:01:16 - [info] Settings file : /root/.node-red/settings.js
22 Jun 18:01:16 - [info] Context store : 'default' [module=localfilesystem]
22 Jun 18:01:16 - [info] User directory : /root/.node-red
22 Jun 18:01:16 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 Jun 18:01:16 - [info] Flows file : /root/.node-red/flows_iZm5eh99wjptdpgrj7deknZ.json
22 Jun 18:01:16 - [info] Server now running at http://127.0.0.1:2345/
your credentials.
22 Jun 18:01:16 - [info] Starting flows
22 Jun 18:01:17 - [info] Started flows
23 Jun 00:00:00 - [error] [function:20e45c08.bb60e4] TypeError: Cannot read property 'MeterWater' of null
23 Jun 08:52:03 - [info] Stopping modified flows
23 Jun 08:52:03 - [info] Stopped modified flows
23 Jun 08:52:03 - [info] Starting modified flows
23 Jun 08:52:03 - [info] Started modified flows
23 Jun 08:52:03 - [info] [tcp in:cb41eeda.90954] listening on port 8028
23 Jun 08:52:03 - [info] [mqtt-broker:6645678.6cbae98] Connected to broker: mqtt://47.105.87.234:1883
23 Jun 08:52:08 - [error] [function:生成校验码(去除风速)] TypeError: Cannot read property 'length' of undefined
23 Jun 08:52:18 - [warn]
Sorry, I can't upload my file due to insufficient permissions, so I can only copy part of it.I have tried to close the Node-red running in PM2 and directly command to run Node-red, which runs normally and redeployments the stream, but once the page crashes, there is no output, and the page can not be opened by reloading, so I need to close the program and execute Node-red again.
Are you sure you actually updated node-js?
The next post shows...
I would try to get onto nodejs 14 LTS
I'm sorry for not replying to your message in time.
Yes, I updated Node.js. I just didn't update it to the latest version. Here is the updated version
''[root@iZm5eh99wjptdpgrj7deknZ ~]# node -v
v12.22.1
[root@iZm5eh99wjptdpgrj7deknZ ~]# ''
The log information at around 10 o 'clock on 23rd:
Welcome to Node-RED
23 Jun 09:58:04 - [info] node-red version: v1.3.3
23 Jun 09:58:04 - [info] Node.js version: v11.0.0
This is from 11.41 on the 23rd and has been upgraded to 12
Welcome to Node-RED
23 Jun 11:41:48 - [info] node-red version: v1.3.3
23 Jun 11:41:48 - [info] node.js version: v12.22.1
I also have a question for you. What command should Node-red use to upgrade to the specified version?
I used "sudo NPM install -g --unsafe-perm node-red" to upgrade to the latest version every time, however, it wasn't what I wanted, I wanted to use the specified version, but when I used something like:"Sudo NPM install -g --unsafe-perm node-red v1.2.8",I found the order to be wrong.I remember trying to write something like this, or "npm install node-red vx.x.x". I can't remember what it was, but it didn't work.
sudo npm install -g --unsafe-perm node-red@1.2.8
Thank you very much
