Good Afternoon
I wonder if someone might be able to please point me in the right direction.
I have installed Jens-Uwe Rossbach's Sony-Audio palette version 1.6.
I found the IP address of my Sony UBP-X700 bluray player .
On creating a new connection with in the node I fail to connect.
This happens if i either add the ip address manually and port 10000 or if I use the nodes search for devices which reports that no devices were found.
I have looked at the settings within my Player and remote network control is enabled.
I can ping the device
Below is the error message node red gives me
"FetchError: request to http://192.168.0.180:10000/sony/system failed, reason: connect ECONNREFUSED 192.168.0.180:10000"
Many thanks in advance
