In short i've got this array [73,4,75,2,56,2,58,1,57,1,45,1] and some how i want to manipulate this data into a UI dashboard just to monitor how many times an object appears. In this case 73 is the id in my back end application for a lemon and it appears 4 times and so on. To recap this sequence [0 2 4 6 8 10] contains the id's of my objects and odd sequence in the middle is the count times of the object.
Where do i start for example if my array gives eg [73,45] so to draw in my ui i got 45 lemons?
The screenshot of the debug window, for where the payload is
Your question is not very clear to me. What do you mean by “start” ?
As this is "your backend application" - i strongly suggest you transmit JSON instead if arrays.
JSON (like XML) is extensible and transforms with very little effort into a JS object.
The problem with arrays (like CSV) is that any change in format ruins the whole party where as
"lemons": 4
will ALWAYS be 4 lemons and accessible as a JS object property payload.lemons
even if in the future you change that to
"lemons": 4,
"unit_price": 40,
"stock_no": "L12345",
"description": "Fresh Lemons"
For example i might get a value decoded out of my node, as byte array. Here as [73,45] it means the first number will represent an object id (in this case lemons) and after the comma the population(count) of them. It can be more populated as described above.
@Steve-Mcl
Steve i cant transmit a JSON as my medium is Lora, already sorted, compressed and encoded for getting the payload as minimised as it is. Hence the form of this information.
Is the trade off really worth it? Have you measured and evaluated that transmitting JSON vs a dumb array is the bottleneck? (this might be worth a read)
Anyhow ...
[{"id":"11942aca.455835","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"8652da88.8d7e58","type":"inject","z":"11942aca.455835","name":"test data [73,4,75,2,56,2,58,1,57,1,45,1]","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[73,4,75,2,56,2,58,1,57,1,45,1]","payloadType":"json","x":830,"y":140,"wires":[["f7844f50.7553c"]]},{"id":"f7844f50.7553c","type":"function","z":"11942aca.455835","name":"","func":"var lookup = {\n 73 : \"lemon\",\n 75 : \"pear\",\n 56 : \"apple\",\n 58 : \"orange\",\n 57 : \"kiwi\",\n 45 : \"grapefruit\"\n}\n\nvar result = {};\nfor (let i = 0; i < msg.payload.length - 2; i=i+2) {\n let i1 = msg.payload[i];\n let i2 = msg.payload[i+1];\n let name = lookup[i1] || \"Unknown\" + i1;\n result[name] = {\n id: i1,\n value: i2\n }\n}\n\nmsg.payload = result;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":760,"y":200,"wires":[["ad3a363a.68ba28"]]},{"id":"ad3a363a.68ba28","type":"debug","z":"11942aca.455835","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":950,"y":200,"wires":[]}]
@Steve-Mcl - Afraid so - LORA is really strict on packet sizes so no-one is going to send raw JSON. (You can but it's a total waste when you may have only 20-40 bytes.)
oh well - the solution offered will work so long as the array always has an even number of elements and the spec doesnt change!
I understand that the input is a buffer of hexadecimal values where the first identifies the type (e.g. "Lemon") and the following hexadecimal specified the quantity.
... but I don't understand what you exactly want from us. Where do you need our help ? What do you want to do with that buffer array ?
Steve yes, that database creation of id's inside the function worked, though i cant display the last object. In this case the grapefruit 45,1 or whatever i add to the end of the array and tweak the id's inside the function for injecting it. Thanks a lot Steve
@janvda I want to create a gauge or similar dashboard in order to visualize somehow the generated data. I have a generated JSON file on the other end with those names, but i couldn't relay whole names so i id'ed them to reduce the payload.
change the for loop to length - 1 (instead of length - 2)
[{"id":"8652da88.8d7e58","type":"inject","z":"11942aca.455835","name":"test data [73,4,75,2,56,2,58,1,57,1,45,1]","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[73,4,75,2,56,2,58,1,57,1,45,1]","payloadType":"json","x":330,"y":200,"wires":[["f7844f50.7553c"]]},{"id":"f7844f50.7553c","type":"function","z":"11942aca.455835","name":"","func":"var lookup = {\n 73 : \"lemon\",\n 75 : \"pear\",\n 56 : \"apple\",\n 58 : \"orange\",\n 57 : \"kiwi\",\n 45 : \"grape\"\n}\n\nvar result = {};\nfor (let i = 0; i < msg.payload.length -1; i=i+2) {\n let i1 = msg.payload[i];\n let i2 = msg.payload[i+1];\n let name = lookup[i1] || \"Unknown\" + i1;\n result[name] = {\n id: i1,\n value: i2\n }\n}\n\nmsg.payload = result;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":360,"y":260,"wires":[["95e39192.b6b3e"]]},{"id":"95e39192.b6b3e","type":"split","z":"11942aca.455835","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":490,"y":260,"wires":[["4d4b06e5.dfbee8"]]},{"id":"4d4b06e5.dfbee8","type":"switch","z":"11942aca.455835","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"}],"checkall":"true","repair":false,"outputs":6,"x":610,"y":260,"wires":[["7d360c0f.cc6824"],["b8b84d2c.fa04e"],["42066a9f.915764"],["8adf8ab2.28f938"],["a2f68b42.0cfbb8"],["13ad4094.4e9f7f"]]},{"id":"7d360c0f.cc6824","type":"ui_artlessgauge","z":"11942aca.455835","group":"61e6d4c4.e7619c","order":0,"width":0,"height":0,"name":"","icon":"iconify-whh:lemon","label":"Lemon","unit":"pieces","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload.value","sectors":[{"val":0,"col":"#ff9900","t":"min","dot":0},{"val":10,"col":"#ff9900","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":800,"y":160,"wires":[]},{"id":"b8b84d2c.fa04e","type":"ui_artlessgauge","z":"11942aca.455835","group":"61e6d4c4.e7619c","order":0,"width":0,"height":0,"name":"","icon":"iconify-whh:pear","label":"Pear","unit":"pieces","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload.value","sectors":[{"val":0,"col":"#ff9900","t":"min","dot":0},{"val":10,"col":"#ff9900","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":820,"y":200,"wires":[]},{"id":"832076d9.58b078","type":"ui_template","z":"11942aca.455835","group":"61e6d4c4.e7619c","name":"Iconify","order":2,"width":0,"height":0,"format":"<script src=\"https://code.iconify.design/1/1.0.7/iconify.min.js\"></script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","x":790,"y":120,"wires":[[]]},{"id":"42066a9f.915764","type":"ui_artlessgauge","z":"11942aca.455835","group":"61e6d4c4.e7619c","order":0,"width":0,"height":0,"name":"","icon":"iconify-whh:apple","label":"Apple","unit":"pieces","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload.value","sectors":[{"val":0,"col":"#ff9900","t":"min","dot":0},{"val":10,"col":"#ff9900","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":840,"y":240,"wires":[]},{"id":"8adf8ab2.28f938","type":"ui_artlessgauge","z":"11942aca.455835","group":"61e6d4c4.e7619c","order":0,"width":0,"height":0,"name":"","icon":"iconify-whh:orange","label":"Orange","unit":"pieces","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload.value","sectors":[{"val":0,"col":"#ff9900","t":"min","dot":0},{"val":10,"col":"#ff9900","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":840,"y":280,"wires":[]},{"id":"a2f68b42.0cfbb8","type":"ui_artlessgauge","z":"11942aca.455835","group":"61e6d4c4.e7619c","order":0,"width":0,"height":0,"name":"","icon":"iconify-whh:kiwifruit","label":"Kiwi","unit":"pieces","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload.value","sectors":[{"val":0,"col":"#ff9900","t":"min","dot":0},{"val":10,"col":"#ff9900","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":820,"y":320,"wires":[]},{"id":"13ad4094.4e9f7f","type":"ui_artlessgauge","z":"11942aca.455835","group":"61e6d4c4.e7619c","order":0,"width":0,"height":0,"name":"","icon":"iconify-whh:grapes","label":"Grape","unit":"pieces","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload.value","sectors":[{"val":0,"col":"#ff9900","t":"min","dot":0},{"val":10,"col":"#ff9900","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":800,"y":360,"wires":[]},{"id":"61e6d4c4.e7619c","type":"ui_group","name":"Fruits","tab":"d1f9fcd9.d4fbc","order":1,"disp":true,"width":"6","collapse":false},{"id":"d1f9fcd9.d4fbc","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Looks fancy too!! I'll try your flow too @hotNipi thank you.
@Steve-Mcl Steve thank you, it worked)
