Split array in 2 or 3 arrays
Hi, i have been working on a dashboard with a table to copy paste values i will put a picture of the result payload when i do the paste of values is an array with 8 or more objects, and inside this objects there is 3 strings with the values that i paste so basically i want to split it and grouping the values like in 3 strings for example string 1 will be: col1 = ["1","2","3","4","5","6","7"]; and the same with the values of column2 and 3.
i will put the code that i have afer the function of the table i put the action what i'm trying to to with this values like a delayed msg with the respective values on the table.
copypaste
[{"id":"44274c4b.5c88a4","type":"change","z":"562890f7.12e7c","name":"ui_control & placeholder","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"customHeight\":20,\"tabulator\":{\"layout\":\"fitColumns\",\"clipboard\":true,\"clipboardCopySelector\":\"table\",\"clipboardCopyStyled\":false,\"clipboardPasteAction\":\"function(rowData){     this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});     return this.table.replaceData(rowData); }\",\"columns\":[{\"field\":\"col1\",\"title\":\"Delay\"},{\"field\":\"col2\",\"title\":\"delayed msg1\"},{\"field\":\"col3\",\"title\":\"delayed msg2\"}]}}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"[{\"col1\":\"click here & CTRL+v\",\"col2\":\"or click here & CTRL+v\",\"col3\":\"or click here & CTRL+v\"},{\"col1\":\" or on any other cell\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":360,"wires":[["4a09af46.57b2b"]]},{"id":"acfe497e.363b58","type":"debug","z":"562890f7.12e7c","name":"clipboardPasteAction","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1009,"y":343,"wires":[]},{"id":"4a09af46.57b2b","type":"ui_table","z":"562890f7.12e7c","group":"465d8685.705e18","name":"Copy & Paste","order":1,"width":16,"height":7,"columns":[],"outputs":1,"cts":true,"x":632,"y":360,"wires":[["934e8b28.585508"]]},{"id":"ea363619.991058","type":"function","z":"562890f7.12e7c","name":"clipboardPasteAction Callback","func":"// callback: clipboardPasteAction\n// DO NOT USE IN A FLOW!\n\nclipboardPasteAction = \n// copy from here\nfunction(rowData){\n    this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});\n    return this.table.replaceData(rowData);\n}\n// until here\n// use the Visual Editor!\n// paste into ui_table JSON \"clipboardPasteAction\":\"function(....\"\n\n// technical details\n//\n// the example function ends with\n//\n// return this.table.updateData(rows);\n// \n// but that's not updating the data (because it does try to update data through\n// the index field (default \"id\")\n// replaceData simply erase all existing rowData and fills in the pasted data\n// that's what we want","outputs":1,"noerr":0,"x":410,"y":309,"wires":[[]]},{"id":"ea8d6c95.7abe6","type":"ui_ui_control","z":"562890f7.12e7c","name":"on tab change","events":"change","x":180,"y":360,"wires":[["44274c4b.5c88a4"]]},{"id":"934e8b28.585508","type":"switch","z":"562890f7.12e7c","name":"","property":"ui_control.callback","propertyType":"msg","rules":[{"t":"eq","v":"clipboardPasteAction","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":806,"y":360,"wires":[["acfe497e.363b58"],[]]},{"id":"ab5cfe0e.3301f","type":"ui_template","z":"562890f7.12e7c","group":"a6f95c80.0b168","name":"Clock Toolbar","order":2,"width":"0","height":"0","format":"<script id=\"titleScript\" type=\"text/javascript\">\n\n$(function() {\n    if($('.md-toolbar-tools').length != 0){\n        loadClock();\n    }else setTimeout(loadClock, 500)\n});\n\nfunction loadClock(){\n    $('#clock').remove();\n    var toolbar = $('.md-toolbar-tools');\n    \n    var div = $('<div/>');\n    var p = $('<p/ id=\"clock\">');\n    \n    div.append(p);\n    div[0].style.margin = '5px 5px 5px auto';\n    toolbar.append(div);\n\n    function displayTitle(lh) {\n        p.text(lh); \n    }\n    \n    function upTime() {\n        var d = new Date();\n        p.text(d.toLocaleString());\n    }\n\n    if(document.clockInterval){ \n            clearInterval(document.clockInterval);\n            document.clockInterval = null;\n    }\n        \n    document.clockInterval = setInterval(upTime,1000);\n}\n\n</script>","storeOutMessages":false,"fwdInMessages":false,"templateScope":"global","x":180,"y":240,"wires":[[]]},{"id":"1b21414e.266e6f","type":"dsm","z":"562890f7.12e7c","name":"timer","sm_config":"{\n    \"data\": {\n        \"delay1\": 1000,\n        \"delay2\": 2000\n    },\n    \"methods\": {\n        \"delay1\": {\n            \"name\": \"setData\"\n        },\n        \"delay2\": {\n            \"name\": \"setData\"\n        },\n        \"timer1\": {\n            \"name\": \"timer\",\n            \"param\": \"delay1\"\n        },\n        \"timer2\": {\n            \"name\": \"timer\",\n            \"param\": \"delay2\"\n        },\n        \"status\": {\n            \"fill\": \"blue\",\n            \"shape\": \"dot\",\n            \"text\": {\n                \"get\": \"msg.topic\"\n            }\n        }\n    }\n}\n","x":580,"y":480,"wires":[["c1201b84.2bdb08","db26b3b2.04b65"]]},{"id":"2ab63a45.666476","type":"inject","z":"562890f7.12e7c","name":"","topic":"delay1","payload":"10000","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":460,"wires":[["1b21414e.266e6f"]]},{"id":"2a605c38.c41f94","type":"inject","z":"562890f7.12e7c","name":"","topic":"delay2","payload":"30000","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":331,"y":498,"wires":[["1b21414e.266e6f"]]},{"id":"c1201b84.2bdb08","type":"debug","z":"562890f7.12e7c","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":730,"y":480,"wires":[]},{"id":"fc283a2e.d3e7d8","type":"inject","z":"562890f7.12e7c","name":"","topic":"timer1","payload":"delayed msg 1","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":360,"y":540,"wires":[["1b21414e.266e6f"]]},{"id":"1c01c842.f7ecd8","type":"inject","z":"562890f7.12e7c","name":"","topic":"timer2","payload":"delayed msg 2","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":360,"y":580,"wires":[["1b21414e.266e6f"]]},{"id":"db26b3b2.04b65","type":"debug","z":"562890f7.12e7c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":740,"y":580,"wires":[]},{"id":"465d8685.705e18","type":"ui_group","name":"Group 2","tab":"44f356f.ed141a8","order":2,"disp":true,"width":16},{"id":"a6f95c80.0b168","type":"ui_group","z":"","name":"hidden_group","tab":"33a639e4.55f2c6","disp":false,"width":"6","collapse":false},{"id":"44f356f.ed141a8","type":"ui_tab","z":"","name":"copypaste","icon":"dashboard","disabled":false,"hidden":false},{"id":"33a639e4.55f2c6","type":"ui_tab","z":"","name":"Zooland Sys","icon":"home","order":1,"disabled":false,"hidden":false}]
Ok, now I know what you mean. I would do it in a function node.
  • loop trough the rows
  • loop through the keys in one row (Object.keys(row))
  • push each value in a separate array
    That‘s only the layout
hi, i'm trying with this but i don't know what is wrong.
[{"id":"6df85d21.d47644","type":"change","z":"67846756.6cbc48","name":"ui_control & placeholder","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"customHeight\":20,\"tabulator\":{\"layout\":\"fitColumns\",\"clipboard\":true,\"clipboardCopySelector\":\"table\",\"clipboardCopyStyled\":false,\"clipboardPasteAction\":\"function(rowData){     this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});     return this.table.replaceData(rowData); }\",\"columns\":[{\"field\":\"col1\",\"title\":\"Time\"},{\"field\":\"col2\",\"title\":\"Setpoint\"},{\"field\":\"col3\",\"title\":\"Column #3\"}]}}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"[{\"col1\":\"click here & CTRL+v\",\"col2\":\"or click here & CTRL+v\",\"col3\":\"or click here & CTRL+v\"},{\"col1\":\" or on any other cell\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"there is a issue with small or empty tables\",\"col2\":\"will be dixed soon\",\"col3\":\"\"},{\"col1\":\"Untill then we have\",\"col2\":\"to fill in some\",\"col3\":\"dummy lines\"}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":400,"wires":[["d87259eb.100a18"]]},{"id":"40fe2c63.3573a4","type":"debug","z":"67846756.6cbc48","name":"clipboardPasteAction","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1209,"y":383,"wires":[]},{"id":"d87259eb.100a18","type":"ui_table","z":"67846756.6cbc48","group":"465d8685.705e18","name":"Copy & Paste","order":1,"width":16,"height":7,"columns":[],"outputs":1,"cts":true,"x":832,"y":400,"wires":[["9a640db1.6b1bd"]]},{"id":"81974a32.b55048","type":"function","z":"67846756.6cbc48","name":"clipboardPasteAction Callback","func":"// callback: clipboardPasteAction\n// DO NOT USE IN A FLOW!\n\nclipboardPasteAction = \n// copy from here\nfunction(rowData){\n    this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});\n    return this.table.replaceData(rowData);\n}\n// until here\n// use the Visual Editor!\n// paste into ui_table JSON \"clipboardPasteAction\":\"function(....\"\n\n// technical details\n//\n// the example function ends with\n//\n// return this.table.updateData(rows);\n// \n// but that's not updating the data (because it does try to update data through\n// the index field (default \"id\")\n// replaceData simply erase all existing rowData and fills in the pasted data\n// that's what we want","outputs":1,"noerr":0,"x":610,"y":349,"wires":[[]]},{"id":"c371d935.665a98","type":"ui_ui_control","z":"67846756.6cbc48","name":"on tab change","events":"change","x":380,"y":400,"wires":[["6df85d21.d47644"]]},{"id":"9a640db1.6b1bd","type":"switch","z":"67846756.6cbc48","name":"","property":"ui_control.callback","propertyType":"msg","rules":[{"t":"eq","v":"clipboardPasteAction","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1006,"y":400,"wires":[["40fe2c63.3573a4","514f7107.98993"],[]]},{"id":"f6995aad.cadbc8","type":"ui_template","z":"67846756.6cbc48","group":"a6f95c80.0b168","name":"Clock Toolbar","order":2,"width":"0","height":"0","format":"<script id=\"titleScript\" type=\"text/javascript\">\n\n$(function() {\n    if($('.md-toolbar-tools').length != 0){\n        loadClock();\n    }else setTimeout(loadClock, 500)\n});\n\nfunction loadClock(){\n    $('#clock').remove();\n    var toolbar = $('.md-toolbar-tools');\n    \n    var div = $('<div/>');\n    var p = $('<p/ id=\"clock\">');\n    \n    div.append(p);\n    div[0].style.margin = '5px 5px 5px auto';\n    toolbar.append(div);\n\n    function displayTitle(lh) {\n        p.text(lh); \n    }\n    \n    function upTime() {\n        var d = new Date();\n        p.text(d.toLocaleString());\n    }\n\n    if(document.clockInterval){ \n            clearInterval(document.clockInterval);\n            document.clockInterval = null;\n    }\n        \n    document.clockInterval = setInterval(upTime,1000);\n}\n\n</script>","storeOutMessages":false,"fwdInMessages":false,"templateScope":"global","x":380,"y":280,"wires":[[]]},{"id":"514f7107.98993","type":"function","z":"67846756.6cbc48","name":"","func":"var key = Object.keys( msg.payload.col1);\nmsg.payload = key;\nreturn msg;\n","outputs":1,"noerr":0,"x":1170,"y":300,"wires":[["237f0ccb.c08954"]]},{"id":"237f0ccb.c08954","type":"debug","z":"67846756.6cbc48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1380,"y":320,"wires":[]},{"id":"465d8685.705e18","type":"ui_group","name":"Group 2","tab":"44f356f.ed141a8","order":2,"disp":true,"width":16},{"id":"a6f95c80.0b168","type":"ui_group","z":"","name":"hidden_group","tab":"33a639e4.55f2c6","disp":false,"width":"6","collapse":false},{"id":"44f356f.ed141a8","type":"ui_tab","z":"","name":"copypaste","icon":"dashboard","disabled":false,"hidden":false},{"id":"33a639e4.55f2c6","type":"ui_tab","z":"","name":"Zooland Sys","icon":"home","order":1,"disabled":false,"hidden":false}]
now i tried with this one but the output appears like undefined.
[{"id":"6df85d21.d47644","type":"change","z":"67846756.6cbc48","name":"ui_control & placeholder","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"customHeight\":20,\"tabulator\":{\"layout\":\"fitColumns\",\"clipboard\":true,\"clipboardCopySelector\":\"table\",\"clipboardCopyStyled\":false,\"clipboardPasteAction\":\"function(rowData){     this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});     return this.table.replaceData(rowData); }\",\"columns\":[{\"field\":\"col1\",\"title\":\"Time\"},{\"field\":\"col2\",\"title\":\"Setpoint\"},{\"field\":\"col3\",\"title\":\"Column #3\"}]}}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"[{\"col1\":\"click here & CTRL+v\",\"col2\":\"or click here & CTRL+v\",\"col3\":\"or click here & CTRL+v\"},{\"col1\":\" or on any other cell\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"there is a issue with small or empty tables\",\"col2\":\"will be dixed soon\",\"col3\":\"\"},{\"col1\":\"Untill then we have\",\"col2\":\"to fill in some\",\"col3\":\"dummy lines\"}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":400,"wires":[["d87259eb.100a18"]]},{"id":"40fe2c63.3573a4","type":"debug","z":"67846756.6cbc48","name":"clipboardPasteAction","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1209,"y":383,"wires":[]},{"id":"d87259eb.100a18","type":"ui_table","z":"67846756.6cbc48","group":"465d8685.705e18","name":"Copy & Paste","order":1,"width":16,"height":7,"columns":[],"outputs":1,"cts":true,"x":832,"y":400,"wires":[["9a640db1.6b1bd"]]},{"id":"81974a32.b55048","type":"function","z":"67846756.6cbc48","name":"clipboardPasteAction Callback","func":"// callback: clipboardPasteAction\n// DO NOT USE IN A FLOW!\n\nclipboardPasteAction = \n// copy from here\nfunction(rowData){\n    this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});\n    return this.table.replaceData(rowData);\n}\n// until here\n// use the Visual Editor!\n// paste into ui_table JSON \"clipboardPasteAction\":\"function(....\"\n\n// technical details\n//\n// the example function ends with\n//\n// return this.table.updateData(rows);\n// \n// but that's not updating the data (because it does try to update data through\n// the index field (default \"id\")\n// replaceData simply erase all existing rowData and fills in the pasted data\n// that's what we want","outputs":1,"noerr":0,"x":610,"y":349,"wires":[[]]},{"id":"c371d935.665a98","type":"ui_ui_control","z":"67846756.6cbc48","name":"on tab change","events":"change","x":380,"y":400,"wires":[["6df85d21.d47644"]]},{"id":"9a640db1.6b1bd","type":"switch","z":"67846756.6cbc48","name":"","property":"ui_control.callback","propertyType":"msg","rules":[{"t":"eq","v":"clipboardPasteAction","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1006,"y":400,"wires":[["40fe2c63.3573a4","514f7107.98993"],[]]},{"id":"f6995aad.cadbc8","type":"ui_template","z":"67846756.6cbc48","group":"a6f95c80.0b168","name":"Clock Toolbar","order":2,"width":"0","height":"0","format":"<script id=\"titleScript\" type=\"text/javascript\">\n\n$(function() {\n    if($('.md-toolbar-tools').length != 0){\n        loadClock();\n    }else setTimeout(loadClock, 500)\n});\n\nfunction loadClock(){\n    $('#clock').remove();\n    var toolbar = $('.md-toolbar-tools');\n    \n    var div = $('<div/>');\n    var p = $('<p/ id=\"clock\">');\n    \n    div.append(p);\n    div[0].style.margin = '5px 5px 5px auto';\n    toolbar.append(div);\n\n    function displayTitle(lh) {\n        p.text(lh); \n    }\n    \n    function upTime() {\n        var d = new Date();\n        p.text(d.toLocaleString());\n    }\n\n    if(document.clockInterval){ \n            clearInterval(document.clockInterval);\n            document.clockInterval = null;\n    }\n        \n    document.clockInterval = setInterval(upTime,1000);\n}\n\n</script>","storeOutMessages":false,"fwdInMessages":false,"templateScope":"global","x":380,"y":280,"wires":[[]]},{"id":"514f7107.98993","type":"function","z":"67846756.6cbc48","name":"","func":"var keyt = msg.col1;\nmsg.payload = keyt;\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1170,"y":300,"wires":[["237f0ccb.c08954"]]},{"id":"237f0ccb.c08954","type":"debug","z":"67846756.6cbc48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1380,"y":320,"wires":[]},{"id":"465d8685.705e18","type":"ui_group","name":"Group 2","tab":"44f356f.ed141a8","order":2,"disp":true,"width":16},{"id":"a6f95c80.0b168","type":"ui_group","z":"","name":"hidden_group","tab":"33a639e4.55f2c6","disp":false,"width":"6","collapse":false},{"id":"44f356f.ed141a8","type":"ui_tab","z":"","name":"copypaste","icon":"dashboard","disabled":false,"hidden":false},{"id":"33a639e4.55f2c6","type":"ui_tab","z":"","name":"Zooland Sys","icon":"home","order":1,"disabled":false,"hidden":false}]
When you share „only“ JavaScript code it is better to share the code and not the flow. Than people who have no access to Node-RED or enough time can take a direct look without the need of importing your flow.
Don’t forget to use the code function.
Where in your latest flow are you trying to do work?
show an example of what you want the final result to look like.
So perhaps try something like this
var msgOut = {payload:{}};
msg.payload.forEach((row) => { // loop through all rows
    Object.keys(row).forEach((key) => { // loop trough all collumns in a row
        if (!msgOut.payload.hasOwnProperty(key)) msgOut.payload[key]=[]; // create new column array if not extisting
        msgOut.payload[key].push(row[key]); // push value on column array
return msgOut;
pasted table:
col1 col2 col3
1 A Text 1
2 B Text 2
3 C Text 3
4 D Text 4
5 E Text 5
[{"id":"f7adbeb6.d76f1","type":"change","z":"ab797823.3396a8","name":"ui_control & placeholder","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"customHeight\":20,\"tabulator\":{\"layout\":\"fitColumns\",\"clipboard\":true,\"clipboardCopySelector\":\"table\",\"clipboardCopyStyled\":false,\"clipboardPasteAction\":\"function(rowData){     this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});     return this.table.replaceData(rowData); }\",\"columns\":[{\"field\":\"col1\",\"title\":\"Time\"},{\"field\":\"col2\",\"title\":\"Setpoint\"},{\"field\":\"col3\",\"title\":\"Column #3\"}]}}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"[{\"col1\":\"click here & CTRL+v\",\"col2\":\"or click here & CTRL+v\",\"col3\":\"or click here & CTRL+v\"},{\"col1\":\" or on any other cell\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"there is a issue with small or empty tables\",\"col2\":\"will be dixed soon\",\"col3\":\"\"},{\"col1\":\"Untill then we have\",\"col2\":\"to fill in some\",\"col3\":\"dummy lines\"}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":416,"y":578,"wires":[["3867401c.fa1c7"]]},{"id":"c1d3a47a.f44448","type":"debug","z":"ab797823.3396a8","name":"clipboardPasteAction","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1035,"y":561,"wires":[]},{"id":"3867401c.fa1c7","type":"ui_table","z":"ab797823.3396a8","group":"a67c03c2.f7729","name":"Copy & Paste","order":1,"width":16,"height":7,"columns":[],"outputs":1,"cts":true,"x":658,"y":578,"wires":[["cd153ef7.9523d"]]},{"id":"e8089623.901488","type":"function","z":"ab797823.3396a8","name":"clipboardPasteAction Callback","func":"// callback: clipboardPasteAction\n// DO NOT USE IN A FLOW!\n\nclipboardPasteAction = \n// copy from here\nfunction(rowData){\n    this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});\n    return this.table.replaceData(rowData);\n}\n// until here\n// use the Visual Editor!\n// paste into ui_table JSON \"clipboardPasteAction\":\"function(....\"\n\n// technical details\n//\n// the example function ends with\n//\n// return this.table.updateData(rows);\n// \n// but that's not updating the data (because it does try to update data through\n// the index field (default \"id\")\n// replaceData simply erase all existing rowData and fills in the pasted data\n// that's what we want","outputs":1,"noerr":0,"x":436,"y":527,"wires":[[]]},{"id":"5eacef1e.27f56","type":"ui_ui_control","z":"ab797823.3396a8","name":"on tab change","events":"change","x":206,"y":578,"wires":[["f7adbeb6.d76f1"]]},{"id":"cd153ef7.9523d","type":"switch","z":"ab797823.3396a8","name":"","property":"ui_control.callback","propertyType":"msg","rules":[{"t":"eq","v":"clipboardPasteAction","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":832,"y":578,"wires":[["c1d3a47a.f44448","453d4f15.9b8d7"],[]]},{"id":"453d4f15.9b8d7","type":"function","z":"ab797823.3396a8","name":"rows 2 columns","func":"var msgOut = {payload:{}};\nmsg.payload.forEach((row) => { // loop through all rows\n    Object.keys(row).forEach((key) => { // loop trough all collumns in a row\n        if (!msgOut.payload.hasOwnProperty(key)) msgOut.payload[key]=[]; // create new column array if not extisting\n        msgOut.payload[key].push(row[key]); // push value on column array\n    })\n})\nreturn msgOut;\n\n","outputs":1,"noerr":0,"x":1015,"y":493,"wires":[["c05c5d0e.b228d"]]},{"id":"c05c5d0e.b228d","type":"debug","z":"ab797823.3396a8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1209,"y":493,"wires":[]},{"id":"a67c03c2.f7729","type":"ui_group","name":"Group 2","tab":"6c190871.57d428","order":2,"disp":true,"width":16},{"id":"6c190871.57d428","type":"ui_tab","z":"","name":"copypaste","icon":"dashboard","disabled":false,"hidden":false}]
thank you so much that's exactly what i need it, my final flow is this one.
can you reconmend me some page or course to learn to do that?
[{"id":"7a34b7cd.fd3a68","type":"change","z":"9651fe9e.18efd","name":"ui_control & placeholder","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"customHeight\":20,\"tabulator\":{\"layout\":\"fitColumns\",\"clipboard\":true,\"clipboardCopySelector\":\"table\",\"clipboardCopyStyled\":false,\"clipboardPasteAction\":\"function(rowData){     this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});     return this.table.replaceData(rowData); }\",\"columns\":[{\"field\":\"col1\",\"title\":\"Time\"},{\"field\":\"col2\",\"title\":\"Setpoint\"},{\"field\":\"col3\",\"title\":\"Column #3\"}]}}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"[{\"col1\":\"click here & CTRL+v\",\"col2\":\"or click here & CTRL+v\",\"col3\":\"or click here & CTRL+v\"},{\"col1\":\" or on any other cell\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"there is a issue with small or empty tables\",\"col2\":\"will be dixed soon\",\"col3\":\"\"},{\"col1\":\"Untill then we have\",\"col2\":\"to fill in some\",\"col3\":\"dummy lines\"}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":340,"wires":[["973f156b.3c68c8"]]},{"id":"5862606d.43bc3","type":"debug","z":"9651fe9e.18efd","name":"clipboardPasteAction","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":909,"y":323,"wires":[]},{"id":"973f156b.3c68c8","type":"ui_table","z":"9651fe9e.18efd","group":"8897a1f9.d11ff","name":"Copy & Paste","order":1,"width":16,"height":7,"columns":[],"outputs":1,"cts":true,"x":532,"y":340,"wires":[["a5c96042.6f3e8"]]},{"id":"20054fdf.90b55","type":"function","z":"9651fe9e.18efd","name":"clipboardPasteAction Callback","func":"// callback: clipboardPasteAction\n// DO NOT USE IN A FLOW!\n\nclipboardPasteAction = \n// copy from here\nfunction(rowData){\n    this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});\n    return this.table.replaceData(rowData);\n}\n// until here\n// use the Visual Editor!\n// paste into ui_table JSON \"clipboardPasteAction\":\"function(....\"\n\n// technical details\n//\n// the example function ends with\n//\n// return this.table.updateData(rows);\n// \n// but that's not updating the data (because it does try to update data through\n// the index field (default \"id\")\n// replaceData simply erase all existing rowData and fills in the pasted data\n// that's what we want","outputs":1,"noerr":0,"x":310,"y":289,"wires":[[]]},{"id":"a4c6ee28.55171","type":"ui_ui_control","z":"9651fe9e.18efd","name":"on tab change","events":"change","x":80,"y":340,"wires":[["7a34b7cd.fd3a68"]]},{"id":"a5c96042.6f3e8","type":"switch","z":"9651fe9e.18efd","name":"","property":"ui_control.callback","propertyType":"msg","rules":[{"t":"eq","v":"clipboardPasteAction","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":706,"y":340,"wires":[["5862606d.43bc3","713d3ce0.f42714"],[]]},{"id":"713d3ce0.f42714","type":"function","z":"9651fe9e.18efd","name":"rows 2 columns","func":"var msgOut = {payload:{}};\nmsg.payload.forEach((row) => { // loop through all rows\n    Object.keys(row).forEach((key) => { // loop trough all collumns in a row\n        if (!msgOut.payload.hasOwnProperty(key)) msgOut.payload[key]=[]; // create new column array if not extisting\n        msgOut.payload[key].push(row[key]); // push value on column array\n    })\n})\nreturn msgOut;\n\n","outputs":1,"noerr":0,"x":889,"y":255,"wires":[["1039d18a.8b94be","e3ee6be.c487798","e97147d8.e19df8","115c61be.13bf9e"]]},{"id":"1039d18a.8b94be","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1083,"y":255,"wires":[]},{"id":"115c61be.13bf9e","type":"function","z":"9651fe9e.18efd","name":"","func":"var col3 = msg.payload.col3;\nmsg.payload = col3;\nreturn msg;","outputs":1,"noerr":0,"x":1090,"y":140,"wires":[["d895419e.45b4e"]]},{"id":"e97147d8.e19df8","type":"function","z":"9651fe9e.18efd","name":"","func":"var col2 = msg.payload.col2;\nmsg.payload = col2;\nreturn msg;","outputs":1,"noerr":0,"x":1090,"y":100,"wires":[["bb98ed3d.deb57"]]},{"id":"e3ee6be.c487798","type":"function","z":"9651fe9e.18efd","name":"","func":"var col1 = msg.payload.col1;\nmsg.payload = col1;\nreturn msg;","outputs":1,"noerr":0,"x":1080,"y":60,"wires":[["89575adc.a7b8d8"]]},{"id":"89575adc.a7b8d8","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1230,"y":60,"wires":[]},{"id":"bb98ed3d.deb57","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1250,"y":100,"wires":[]},{"id":"d895419e.45b4e","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1270,"y":140,"wires":[]},{"id":"8897a1f9.d11ff","type":"ui_group","name":"Group 2","tab":"1418efe4.abb68","order":2,"disp":true,"width":16},{"id":"1418efe4.abb68","type":"ui_tab","z":"","name":"copypaste","icon":"dashboard","disabled":false,"hidden":false}]
hey guys i have some issues with a function that i want to do. i will put my flow and thing is that i'm trying to make a timer and it will have a msg to send on payload and the delay what i will choose.
[{"id":"7a34b7cd.fd3a68","type":"change","z":"9651fe9e.18efd","name":"ui_control & placeholder","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"customHeight\":20,\"tabulator\":{\"layout\":\"fitColumns\",\"clipboard\":true,\"clipboardCopySelector\":\"table\",\"clipboardCopyStyled\":false,\"clipboardPasteAction\":\"function(rowData){     this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});     return this.table.replaceData(rowData); }\",\"columns\":[{\"field\":\"col1\",\"title\":\"Time\"},{\"field\":\"col2\",\"title\":\"Setpoint\"},{\"field\":\"col3\",\"title\":\"Column #3\"}]}}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"[{\"col1\":\"click here & CTRL+v\",\"col2\":\"or click here & CTRL+v\",\"col3\":\"or click here & CTRL+v\"},{\"col1\":\" or on any other cell\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"\",\"col2\":\"\",\"col3\":\"\"},{\"col1\":\"there is a issue with small or empty tables\",\"col2\":\"will be dixed soon\",\"col3\":\"\"},{\"col1\":\"Untill then we have\",\"col2\":\"to fill in some\",\"col3\":\"dummy lines\"}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":340,"wires":[["973f156b.3c68c8"]]},{"id":"5862606d.43bc3","type":"debug","z":"9651fe9e.18efd","name":"clipboardPasteAction","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":900,"y":380,"wires":[]},{"id":"973f156b.3c68c8","type":"ui_table","z":"9651fe9e.18efd","group":"8897a1f9.d11ff","name":"Copy & Paste","order":1,"width":16,"height":7,"columns":[],"outputs":1,"cts":true,"x":532,"y":340,"wires":[["a5c96042.6f3e8"]]},{"id":"20054fdf.90b55","type":"function","z":"9651fe9e.18efd","name":"clipboardPasteAction Callback","func":"// callback: clipboardPasteAction\n// DO NOT USE IN A FLOW!\n\nclipboardPasteAction = \n// copy from here\nfunction(rowData){\n    this.send({ui_control:{callback:'clipboardPasteAction'},payload:rowData});\n    return this.table.replaceData(rowData);\n}\n// until here\n// use the Visual Editor!\n// paste into ui_table JSON \"clipboardPasteAction\":\"function(....\"\n\n// technical details\n//\n// the example function ends with\n//\n// return this.table.updateData(rows);\n// \n// but that's not updating the data (because it does try to update data through\n// the index field (default \"id\")\n// replaceData simply erase all existing rowData and fills in the pasted data\n// that's what we want","outputs":1,"noerr":0,"x":310,"y":289,"wires":[[]]},{"id":"a4c6ee28.55171","type":"ui_ui_control","z":"9651fe9e.18efd","name":"on tab change","events":"change","x":80,"y":340,"wires":[["7a34b7cd.fd3a68"]]},{"id":"a5c96042.6f3e8","type":"switch","z":"9651fe9e.18efd","name":"","property":"ui_control.callback","propertyType":"msg","rules":[{"t":"eq","v":"clipboardPasteAction","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":706,"y":340,"wires":[["5862606d.43bc3","713d3ce0.f42714"],[]]},{"id":"713d3ce0.f42714","type":"function","z":"9651fe9e.18efd","name":"rows 2 columns","func":"var msgOut = {payload:{}};\nmsg.payload.forEach((row) => { // loop through all rows\n    Object.keys(row).forEach((key) => { // loop trough all collumns in a row\n        if (!msgOut.payload.hasOwnProperty(key)) msgOut.payload[key]=[]; // create new column array if not extisting\n        msgOut.payload[key].push(row[key]); // push value on column array\n    })\n})\nreturn msgOut;\n\n","outputs":1,"noerr":0,"x":889,"y":255,"wires":[["1039d18a.8b94be","e97147d8.e19df8","115c61be.13bf9e","e3ee6be.c487798"]]},{"id":"1039d18a.8b94be","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1070,"y":300,"wires":[]},{"id":"115c61be.13bf9e","type":"function","z":"9651fe9e.18efd","name":"","func":"var col3 = msg.payload.col3;\nmsg.payload = col3;\nreturn msg;","outputs":1,"noerr":0,"x":1090,"y":260,"wires":[["d895419e.45b4e"]]},{"id":"e97147d8.e19df8","type":"function","z":"9651fe9e.18efd","name":"","func":"var col2 = msg.payload.col2;\nmsg.payload = col2;\nreturn msg;","outputs":1,"noerr":0,"x":1090,"y":200,"wires":[["bb98ed3d.deb57"]]},{"id":"e3ee6be.c487798","type":"function","z":"9651fe9e.18efd","name":"","func":"var col1 = (msg.payload.col1);\n//var setpoint1 = Number(global.get(\"presion1\"));\nmsg.payload = col1;\nreturn msg;","outputs":1,"noerr":0,"x":1090,"y":140,"wires":[["23957d7b.740a32"]]},{"id":"bb98ed3d.deb57","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1250,"y":200,"wires":[]},{"id":"d895419e.45b4e","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1250,"y":260,"wires":[]},{"id":"23957d7b.740a32","type":"split","z":"9651fe9e.18efd","name":"","splt":"\\n","spltType":"str","arraySplt":"1","arraySpltType":"len","stream":false,"addname":"","x":1230,"y":120,"wires":[["4b8bf995.895d08"]]},{"id":"3b0530e8.1f152","type":"dsm","z":"9651fe9e.18efd","name":"timer","sm_config":"{\n    \"data\": {\n        \"delay1\": 1000,\n        \"delay2\": 2000\n    },\n    \"methods\": {\n        \"delay1\": {\n            \"name\": \"setData\"\n        },\n        \"delay2\": {\n            \"name\": \"setData\"\n        },\n        \"timer1\": {\n            \"name\": \"timer\",\n            \"param\": \"delay1\"\n        },\n        \"timer2\": {\n            \"name\": \"timer\",\n            \"param\": \"delay2\"\n        },\n        \"status\": {\n            \"fill\": \"blue\",\n            \"shape\": \"dot\",\n            \"text\": {\n                \"get\": \"msg.topic\"\n            }\n        }\n    }\n}\n","x":1760,"y":40,"wires":[["dbf6fa43.680a58","959352eb.2c3cb"]]},{"id":"dbf6fa43.680a58","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1950,"y":20,"wires":[]},{"id":"959352eb.2c3cb","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1970,"y":80,"wires":[]},{"id":"d4395555.5a7b48","type":"inject","z":"9651fe9e.18efd","name":"","topic":"delay1","payload":"10000","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":1430,"y":40,"wires":[["3b0530e8.1f152"]]},{"id":"7bd69d09.2d3714","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1610,"y":140,"wires":[]},{"id":"4b8bf995.895d08","type":"change","z":"9651fe9e.18efd","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":120,"wires":[["7bd69d09.2d3714","b9286e17.f4983"]]},{"id":"b9286e17.f4983","type":"function","z":"9651fe9e.18efd","name":"","func":"var timer1 = msg.payload; //get payload\nmsg.topic = timer1;\nreturn msg;","outputs":1,"noerr":0,"x":1590,"y":80,"wires":[["3b0530e8.1f152"]]},{"id":"8897a1f9.d11ff","type":"ui_group","name":"Group 2","tab":"1418efe4.abb68","order":2,"disp":true,"width":16},{"id":"1418efe4.abb68","type":"ui_tab","z":"","name":"copypaste","icon":"dashboard","disabled":false,"hidden":false}]
the function is this one but i don't found the issue.
[{"id":"947f26cb.678908","type":"inject","z":"9651fe9e.18efd","name":"","topic":"delay2","payload":"30000","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":331,"y":518,"wires":[["94edd52.6c0ce28"]]},{"id":"f84f8738.798a68","type":"inject","z":"9651fe9e.18efd","name":"","topic":"delay1","payload":"10000","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":480,"wires":[["94edd52.6c0ce28"]]},{"id":"94edd52.6c0ce28","type":"dsm","z":"9651fe9e.18efd","name":"timer","sm_config":"{\n    \"data\": {\n        \"delay1\": 1000,\n        \"delay2\": 2000\n    },\n    \"methods\": {\n        \"delay1\": {\n            \"name\": \"setData\"\n        },\n        \"delay2\": {\n            \"name\": \"setData\"\n        },\n        \"timer1\": {\n            \"name\": \"timer\",\n            \"param\": \"delay1\"\n        },\n        \"timer2\": {\n            \"name\": \"timer\",\n            \"param\": \"delay2\"\n        },\n        \"status\": {\n            \"fill\": \"blue\",\n            \"shape\": \"dot\",\n            \"text\": {\n                \"get\": \"msg.topic\"\n            }\n        }\n    }\n}\n","x":580,"y":500,"wires":[["6cee6802.511128","a3b547d6.78de18"]]},{"id":"6cee6802.511128","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":730,"y":500,"wires":[]},{"id":"c1106273.41917","type":"inject","z":"9651fe9e.18efd","name":"","topic":"timer1","payload":"delayed msg 1","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":360,"y":560,"wires":[["94edd52.6c0ce28"]]},{"id":"fc4510a3.7a532","type":"inject","z":"9651fe9e.18efd","name":"","topic":"timer2","payload":"delayed msg 2","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":360,"y":600,"wires":[["94edd52.6c0ce28"]]},{"id":"a3b547d6.78de18","type":"debug","z":"9651fe9e.18efd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":740,"y":600,"wires":[]}]
