Well, I think I could have done it easily in REXX which had super strong string processing. But I still got the right answer for today. Though I did, as usual, have to resort to Google a couple of times. Converting "12-15" to a range array was interesting. Though I think that creating range arrays and then comparing them was probably significant overkill. ![]()
I'm firstly completing them using Snap! and then trying to redo them in NR - I don't know if I'll manage to do Day 3 or not but it keeps me off the streets ![]()
Yes ![]()
Feels like maybe a new design discussion could be started so that people could feed in ideas?
Late to the party (busy weekend), but it feels like the batch node ought to help here
Any chance of a demo Dave?
I have never used the batch node & struggle to find a use.
@Steve-Mcl - a simple example like this
[{"id":"a069df4c2d54915d","type":"inject","z":"273b95be5f0a745f","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"abcdef","payloadType":"str","x":110,"y":465,"wires":[["1dd4fa914ea28353"]]},{"id":"1dd4fa914ea28353","type":"split","z":"273b95be5f0a745f","name":"","splt":" 1","spltType":"len","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":250,"y":465,"wires":[["1dab94cb6dc24d86"]]},{"id":"1dab94cb6dc24d86","type":"change","z":"273b95be5f0a745f","name":"","rules":[{"t":"delete","p":"parts","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":465,"wires":[["ca860dff7489fd89"]]},{"id":"ca860dff7489fd89","type":"batch","z":"273b95be5f0a745f","name":"","mode":"count","count":"3","overlap":0,"interval":10,"allowEmptySequence":false,"topics":[],"x":580,"y":465,"wires":[["f6bc94c2c794ee5c"]]},{"id":"f6bc94c2c794ee5c","type":"join","z":"273b95be5f0a745f","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":725,"y":465,"wires":[["a5d91176e36dbaf2"]]},{"id":"a5d91176e36dbaf2","type":"debug","z":"273b95be5f0a745f","name":"split messages","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":895,"y":465,"wires":[]}]
If you actually want two messages with two strings as outputs then remove the change node.
BUT - reading the OP in more detail it seems like the batch size needs to vary - ie to split original string in half - and the batch node doesn't allow the split size to be overridden - so not an exact answer in this instance.
Once split, the split's sequence number can be used in a simple switch node to grab the first x entries to one output and the rest to the other. Then a join node on each output does the rest.
yes true.
[{"id":"f122b814d6465392","type":"inject","z":"273b95be5f0a745f","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"abcdefghijklakl","payloadType":"str","x":140,"y":540,"wires":[["fac0c3dbda45b9af"]]},{"id":"fac0c3dbda45b9af","type":"junction","z":"273b95be5f0a745f","x":240,"y":450,"wires":[["cbb3a65ea57ac006","f414bd7c21411950"]]},{"id":"6b677bd092ac5687","type":"inject","z":"273b95be5f0a745f","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"abcdef","payloadType":"str","x":110,"y":450,"wires":[["fac0c3dbda45b9af"]]},{"id":"06a19c721ea11aac","type":"inject","z":"273b95be5f0a745f","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"abcdefhghic","payloadType":"str","x":130,"y":495,"wires":[["fac0c3dbda45b9af"]]},{"id":"cbb3a65ea57ac006","type":"split","z":"273b95be5f0a745f","name":"","splt":" 1","spltType":"len","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":340,"y":495,"wires":[["c294106f1e604818"]]},{"id":"f414bd7c21411950","type":"change","z":"273b95be5f0a745f","name":"","rules":[{"t":"delete","p":"sec","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":450,"wires":[[]]},{"id":"c294106f1e604818","type":"function","z":"273b95be5f0a745f","name":"function 7","func":"msg.split = msg.parts.count/2\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":485,"y":495,"wires":[["f5ce9a3af5f04486"]]},{"id":"f5ce9a3af5f04486","type":"switch","z":"273b95be5f0a745f","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"lt","v":"split","vt":"msg"},{"t":"else"}],"checkall":"true","repair":true,"outputs":2,"x":640,"y":495,"wires":[["20cc830ca7e93daa"],["0fa681706f955292"]]},{"id":"20cc830ca7e93daa","type":"change","z":"273b95be5f0a745f","name":"","rules":[{"t":"set","p":"sec[msg.payload]","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":860,"y":480,"wires":[[]]},{"id":"0fa681706f955292","type":"switch","z":"273b95be5f0a745f","name":"","property":"sec","propertyType":"flow","rules":[{"t":"hask","v":"payload","vt":"msg"}],"checkall":"true","repair":false,"outputs":1,"x":805,"y":525,"wires":[["2dbaeceb7d530ef8"]]},{"id":"2dbaeceb7d530ef8","type":"debug","z":"273b95be5f0a745f","name":"debug 14","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":945,"y":525,"wires":[]}]
For amusement, here is my over-complex answer to the first part of that challenge:
const range = (start, stop) => {
start = Number(start)
stop = Number(stop)
return Array.from(
{ length: (stop - start + 1) },
(_, i) => {
return start + i
const out = msg.payload.split(' ')
let trueCount = 0
out.forEach( (pair, i) => {
let splitPair = pair.split(',')
splitPair.forEach( (rng, j) => {
const rngSplit = rng.split('-')
// Urm, could have just compared the start/end numbers! 😁
splitPair[j] = range(rngSplit[0], rngSplit[1])
// out[i] = splitPair
const trueContains = {
'pair': pair,
'All of A in B': splitPair[0].every(r => splitPair[1].includes(r)),
'All of B in A': splitPair[1].every(r => splitPair[0].includes(r))
if (trueContains['All of A in B'] || trueContains['All of B in A']) trueCount++
out[i] = trueContains
msg.payload = out
msg.trueCount = trueCount
return msg
where the input was a big multi-line input of paired ranges.
