Join node automatic mode without Split node
I am trying to join 4 messages into one object with the automatic mode of the join node but without a split node.
I constructed msg.parts into each message and the join works in manual mode but i want a certain order on the output, i assume the msg.parts.index should help that.
If i switch the mode to automatic in the join mode i get no output (and no error either)
I am out of ideas ( although might be a typo somewhere, it happened before).
Or did i misunderstood the help description? join strictly works only with split?
Thanks in advance;
        "id": "5a0ca714aee31411",
        "type": "change",
        "z": "691d0babb80c900b",
        "name": "SigPrep",
        "rules": [
                "t": "set",
                "p": "pressureval",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
                "t": "delete",
                "p": "_msgid",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 840,
        "y": 240,
                "c919b02f4fbda282"
        "id": "a814a91eff79d8ec",
        "type": "change",
        "name": "SigPrep",
        "rules": [
                "t": "set",
                "p": "currentscaled",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
                "t": "delete",
                "p": "_msgid",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 840,
        "y": 160,
                "25ab5b287455ad51"
        "id": "89207abdc0e95323",
        "type": "switch",
        "name": "StsMsg",
        "property": "payload.Pressure01.Status",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "0",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 840,
        "y": 560,
                "1846f4b1544abffc"
        "id": "ec3dacfabbb9b2cc",
        "type": "switch",
        "name": "StsMsg",
        "rules": [
                "t": "btwn",
                "v": "0.1",
                "vt": "num",
                "v2": "4",
                "v2t": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 840,
        "y": 480,
                "ab2603bb0fddf316"
        "id": "eb68ecc6b5a25d49",
        "type": "switch",
        "name": "StsMsg",
        "rules": [
                "t": "gt",
                "v": "20.2",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 840,
        "y": 400,
                "49e70bcbdf12a386"
        "id": "54e0f9392a34f8b8",
        "type": "switch",
        "name": "StsMsg",
        "rules": [
                "t": "btwn",
                "v": "4.1",
                "vt": "num",
                "v2": "20.1",
                "v2t": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 840,
        "y": 320,
                "f59cf71a5a69f431"
        "id": "a8e1976c66f4a15f",
        "type": "change",
        "name": "CurrentRaw",
        "rules": [
                "t": "set",
                "p": "payload.Pressure01.CurrentRaw",
                "pt": "msg",
                "to": "currentraw",
                "tot": "msg"
                "t": "delete",
                "p": "currentraw",
                "pt": "msg"
                "t": "set",
                "p": "parts.id",
                "pt": "msg",
                "to": "Join03",
                "tot": "str"
                "t": "set",
                "p": "parts.type",
                "pt": "msg",
                "to": "object",
                "tot": "str"
                "t": "set",
                "p": "parts.key",
                "pt": "msg",
                "to": "Pressure01",
                "tot": "str"
                "t": "set",
                "p": "parts.index",
                "pt": "msg",
                "to": "2",
                "tot": "num"
                "t": "set",
                "p": "parts.count",
                "pt": "msg",
                "to": "4",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1090,
        "y": 80,
                "ad466e7ee358d6eb"
        "id": "c919b02f4fbda282",
        "type": "change",
        "name": "PressureGauge",
        "rules": [
                "t": "set",
                "p": "payload.Pressure01.Value",
                "pt": "msg",
                "to": "pressureval",
                "tot": "msg"
                "t": "delete",
                "p": "pressureval",
                "pt": "msg"
                "t": "set",
                "p": "parts.id",
                "pt": "msg",
                "to": "Join01",
                "tot": "str"
                "t": "set",
                "p": "parts.type",
                "pt": "msg",
                "to": "object",
                "tot": "str"
                "t": "set",
                "p": "parts.key",
                "pt": "msg",
                "to": "Pressure01",
                "tot": "str"
                "t": "set",
                "p": "parts.index",
                "pt": "msg",
                "to": "0",
                "tot": "num"
                "t": "set",
                "p": "parts.count",
                "pt": "msg",
                "to": "4",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1100,
        "y": 240,
                "ad466e7ee358d6eb"
        "id": "25ab5b287455ad51",
        "type": "change",
        "name": "CurrentScaled",
        "rules": [
                "t": "set",
                "p": "payload.Pressure01.CurrentScaled",
                "pt": "msg",
                "to": "currentscaled",
                "tot": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "set",
                "p": "parts.id",
                "pt": "msg",
                "to": "Join02",
                "tot": "str"
                "t": "set",
                "p": "parts.type",
                "pt": "msg",
                "to": "object",
                "tot": "str"
                "t": "set",
                "p": "parts.key",
                "pt": "msg",
                "to": "Pressure01",
                "tot": "str"
                "t": "set",
                "p": "parts.index",
                "pt": "msg",
                "to": "1",
                "tot": "num"
                "t": "set",
                "p": "parts.count",
                "pt": "msg",
                "to": "4",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1100,
        "y": 160,
                "ad466e7ee358d6eb"
        "id": "1846f4b1544abffc",
        "type": "change",
        "name": "WireBreak",
        "rules": [
                "t": "set",
                "p": "payload.Pressure01.Status",
                "pt": "msg",
                "to": "Wire Break",
                "tot": "str"
                "t": "set",
                "p": "parts.id",
                "pt": "msg",
                "to": "Join04",
                "tot": "str"
                "t": "set",
                "p": "parts.type",
                "pt": "msg",
                "to": "object",
                "tot": "str"
                "t": "set",
                "p": "parts.key",
                "pt": "msg",
                "to": "Pressure01",
                "tot": "str"
                "t": "set",
                "p": "parts.index",
                "pt": "msg",
                "to": "3",
                "tot": "num"
                "t": "set",
                "p": "parts.count",
                "pt": "msg",
                "to": "4",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1090,
        "y": 560,
                "ad466e7ee358d6eb"
        "id": "ab2603bb0fddf316",
        "type": "change",
        "name": "UnderRange",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "Under Range",
                "tot": "str"
                "t": "set",
                "p": "parts.id",
                "pt": "msg",
                "to": "Join04",
                "tot": "str"
                "t": "set",
                "p": "parts.type",
                "pt": "msg",
                "to": "object",
                "tot": "str"
                "t": "set",
                "p": "parts.key",
                "pt": "msg",
                "to": "Pressure01",
                "tot": "str"
                "t": "set",
                "p": "parts.index",
                "pt": "msg",
                "to": "3",
                "tot": "num"
                "t": "set",
                "p": "parts.count",
                "pt": "msg",
                "to": "4",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1090,
        "y": 480,
                "ad466e7ee358d6eb"
        "id": "49e70bcbdf12a386",
        "type": "change",
        "name": "OverRange",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "Over Range",
                "tot": "str"
                "t": "set",
                "p": "parts.id",
                "pt": "msg",
                "to": "Join04",
                "tot": "str"
                "t": "set",
                "p": "parts.type",
                "pt": "msg",
                "to": "object",
                "tot": "str"
                "t": "set",
                "p": "parts.key",
                "pt": "msg",
                "to": "Pressure01",
                "tot": "str"
                "t": "set",
                "p": "parts.index",
                "pt": "msg",
                "to": "3",
                "tot": "num"
                "t": "set",
                "p": "parts.count",
                "pt": "msg",
                "to": "4",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1090,
        "y": 400,
                "ad466e7ee358d6eb"
        "id": "f59cf71a5a69f431",
        "type": "change",
        "name": "OK",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "OK",
                "tot": "str"
                "t": "set",
                "p": "parts.id",
                "pt": "msg",
                "to": "Join04",
                "tot": "str"
                "t": "set",
                "p": "parts.type",
                "pt": "msg",
                "to": "object",
                "tot": "str"
                "t": "set",
                "p": "parts.key",
                "pt": "msg",
                "to": "Pressure01",
                "tot": "str"
                "t": "set",
                "p": "parts.index",
                "pt": "msg",
                "to": "3",
                "tot": "num"
                "t": "set",
                "p": "parts.count",
                "pt": "msg",
                "to": "4",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1070,
        "y": 320,
                "ad466e7ee358d6eb"
        "id": "ad466e7ee358d6eb",
        "type": "join",
        "name": "SigJoin",
        "mode": "auto",
        "build": "merged",
        "property": "payload.Pressure01",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "4",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "num",
        "reduceFixup": "",
        "x": 1360,
        "y": 240,
                "aa06e3d861b7d61f"
        "id": "ab6cb3ca7d846838",
        "type": "change",
        "name": "SigPrep",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "status",
                "tot": "msg"
                "t": "delete",
                "p": "status",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 600,
        "y": 320,
                "eb68ecc6b5a25d49",
                "54e0f9392a34f8b8"
        "id": "c6567136ac1ddd09",
        "type": "change",
        "name": "SigPrep",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "status",
                "tot": "msg"
                "t": "delete",
                "p": "status",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 600,
        "y": 480,
                "89207abdc0e95323",
                "ec3dacfabbb9b2cc"
        "id": "aa06e3d861b7d61f",
        "type": "debug",
        "name": "debug 6",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "targetType": "full",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1600,
        "y": 240,
        "id": "84bf6317bb615996",
        "type": "change",
        "name": "SigPrep",
        "rules": [
                "t": "set",
                "p": "currentraw",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
                "t": "delete",
                "p": "_msgid",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 840,
        "y": 80,
                "a8e1976c66f4a15f"
        "id": "6119dbbe08835516",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "16",
        "payloadType": "num",
        "x": 110,
        "y": 80,
                "84bf6317bb615996"
        "id": "1d6d9a1c2fc546b5",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "13",
        "x": 110,
        "y": 160,
                "a814a91eff79d8ec"
        "id": "41bd5f8f1fae0613",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "5",
        "x": 110,
        "y": 240,
                "5a0ca714aee31411"
        "id": "7a0387b6fa84ea9e",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "9",
        "x": 110,
        "y": 320,
                "d6b239c1bfbf9120",
                "546a302e8246b55b"
        "id": "546a302e8246b55b",
        "type": "change",
        "name": "SigPrep",
        "rules": [
                "t": "set",
                "p": "status",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
                "t": "delete",
                "p": "_msgid",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 360,
        "y": 480,
                "c6567136ac1ddd09"
        "id": "d6b239c1bfbf9120",
        "type": "change",
        "name": "SigPrep",
        "rules": [
                "t": "set",
                "p": "status",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
                "t": "delete",
                "p": "_msgid",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 360,
        "y": 320,
                "ab6cb3ca7d846838"
Show us what the incoming messages to the join node look like, and what output you want.
If you start with the desired joined message and run it through a split node, how do msg.parts differ from your hand built version?
this is the desired output;
but this only happens when i set the Join node to manual mode:
my (ocd) issue (but at this point i'd really like to understand the join node) is that;
"Value" should be on top, then Status, then the rest.
the input messages are generic msg.payload with a number in it, i even deleted the unnecessary messages with change nodes.
You are not setting the same parts.id
The last for switches need to be combined into one.
Each parts.key needs to be different except the last 4 connected to the combined switch
Example
[{"id":"6119dbbe08835516","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"16","payloadType":"num","x":70,"y":80,"wires":[["84bf6317bb615996"]]},{"id":"84bf6317bb615996","type":"change","z":"f5db42105a32fa69","name":"SigPrep","rules":[{"t":"set","p":"currentraw","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"delete","p":"topic","pt":"msg"},{"t":"delete","p":"_msgid","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":80,"wires":[["a8e1976c66f4a15f"]]},{"id":"a8e1976c66f4a15f","type":"change","z":"f5db42105a32fa69","name":"CurrentRaw","rules":[{"t":"set","p":"payload.Pressure01.CurrentRaw","pt":"msg","to":"currentraw","tot":"msg"},{"t":"delete","p":"currentraw","pt":"msg"},{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"Pressure01","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":80,"wires":[["ad466e7ee358d6eb"]]},{"id":"ad466e7ee358d6eb","type":"join","z":"f5db42105a32fa69","name":"SigJoin","mode":"auto","build":"merged","property":"payload.Pressure01","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"4","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":1320,"y":240,"wires":[["aa06e3d861b7d61f"]]},{"id":"c919b02f4fbda282","type":"change","z":"f5db42105a32fa69","name":"PressureGauge","rules":[{"t":"set","p":"payload.Pressure01.Value","pt":"msg","to":"pressureval","tot":"msg"},{"t":"delete","p":"pressureval","pt":"msg"},{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"Pressure03","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"2","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1060,"y":240,"wires":[["ad466e7ee358d6eb"]]},{"id":"25ab5b287455ad51","type":"change","z":"f5db42105a32fa69","name":"CurrentScaled","rules":[{"t":"set","p":"payload.Pressure01.CurrentScaled","pt":"msg","to":"currentscaled","tot":"msg"},{"t":"delete","p":"currentscaled","pt":"msg"},{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"Pressure02","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"1","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1060,"y":160,"wires":[["ad466e7ee358d6eb"]]},{"id":"1846f4b1544abffc","type":"change","z":"f5db42105a32fa69","name":"WireBreak","rules":[{"t":"set","p":"payload.Pressure01.Status","pt":"msg","to":"Wire Break","tot":"str"},{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"Pressure04","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"3","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":560,"wires":[["ad466e7ee358d6eb"]]},{"id":"ab2603bb0fddf316","type":"change","z":"f5db42105a32fa69","name":"UnderRange","rules":[{"t":"set","p":"payload.Pressure01.Status","pt":"msg","to":"Under Range","tot":"str"},{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"Pressure04","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"3","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":480,"wires":[["ad466e7ee358d6eb"]]},{"id":"49e70bcbdf12a386","type":"change","z":"f5db42105a32fa69","name":"OverRange","rules":[{"t":"set","p":"payload.Pressure01.Status","pt":"msg","to":"Over Range","tot":"str"},{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"Pressure04","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"3","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":400,"wires":[["ad466e7ee358d6eb"]]},{"id":"f59cf71a5a69f431","type":"change","z":"f5db42105a32fa69","name":"OK","rules":[{"t":"set","p":"payload.Pressure01.Status","pt":"msg","to":"OK","tot":"str"},{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"Pressure04","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"3","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":320,"wires":[["ad466e7ee358d6eb"]]},{"id":"aa06e3d861b7d61f","type":"debug","z":"f5db42105a32fa69","name":"debug 6","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1560,"y":240,"wires":[]},{"id":"5a0ca714aee31411","type":"change","z":"f5db42105a32fa69","name":"SigPrep","rules":[{"t":"set","p":"pressureval","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"delete","p":"topic","pt":"msg"},{"t":"delete","p":"_msgid","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":240,"wires":[["c919b02f4fbda282"]]},{"id":"a814a91eff79d8ec","type":"change","z":"f5db42105a32fa69","name":"SigPrep","rules":[{"t":"set","p":"currentscaled","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"delete","p":"topic","pt":"msg"},{"t":"delete","p":"_msgid","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":160,"wires":[["25ab5b287455ad51"]]},{"id":"2db243b5f34a2a08","type":"switch","z":"f5db42105a32fa69","name":"StsMsg","property":"payload.Pressure01.Status","propertyType":"msg","rules":[{"t":"btwn","v":"4.1","vt":"num","v2":"20.1","v2t":"num"},{"t":"gt","v":"20.2","vt":"num"},{"t":"btwn","v":"0.1","vt":"num","v2":"4","v2t":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"false","repair":false,"outputs":4,"x":780,"y":360,"wires":[["f59cf71a5a69f431"],["49e70bcbdf12a386"],["ab2603bb0fddf316"],["1846f4b1544abffc"]]},{"id":"41bd5f8f1fae0613","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"5","payloadType":"num","x":70,"y":240,"wires":[["5a0ca714aee31411"]]},{"id":"1d6d9a1c2fc546b5","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"13","payloadType":"num","x":70,"y":160,"wires":[["a814a91eff79d8ec"]]},{"id":"ab6cb3ca7d846838","type":"change","z":"f5db42105a32fa69","name":"SigPrep","rules":[{"t":"set","p":"payload.Pressure01.Status","pt":"msg","to":"status","tot":"msg"},{"t":"delete","p":"status","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":320,"wires":[["2db243b5f34a2a08"]]},{"id":"d6b239c1bfbf9120","type":"change","z":"f5db42105a32fa69","name":"SigPrep","rules":[{"t":"set","p":"status","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"delete","p":"topic","pt":"msg"},{"t":"delete","p":"_msgid","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":320,"wires":[["ab6cb3ca7d846838"]]},{"id":"7a0387b6fa84ea9e","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"9","payloadType":"num","x":70,"y":320,"wires":[["d6b239c1bfbf9120"]]}]
output
    "_msgid": "1c26d0e5f261d956",
    "payload": {
        "Pressure01": {
            "Pressure01": {
                "CurrentRaw": 16
            "Pressure02": {
                "CurrentScaled": 13
            "Pressure03": {
                "Value": 5
            "Pressure04": {
                "Status": "OK"
tried with identical id's too.
what do you mean by combining the last for? (edit: i see it now but still does not help the outcome)
the example behaves the same; no output (Join node in automatic mode)
Did you bother looking at the flow example and how i edited it to show you?
Anyway here is a clearer example removed all nodes not required to do what I think you want. Hope you look and study it this time, and it helps you understand how to join automatically.
[{"id":"6119dbbe08835516","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"16","payloadType":"num","x":730,"y":80,"wires":[["a8e1976c66f4a15f"]]},{"id":"a8e1976c66f4a15f","type":"change","z":"f5db42105a32fa69","name":"CurrentRaw","rules":[{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"currentraw","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1130,"y":80,"wires":[["ad466e7ee358d6eb","6306d4c550b8b1d4"]]},{"id":"ad466e7ee358d6eb","type":"join","z":"f5db42105a32fa69","name":"SigJoin","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"4","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":1320,"y":220,"wires":[["aa06e3d861b7d61f"]]},{"id":"6306d4c550b8b1d4","type":"debug","z":"f5db42105a32fa69","name":"debug 341","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1310,"y":60,"wires":[]},{"id":"c919b02f4fbda282","type":"change","z":"f5db42105a32fa69","name":"PressureGauge","rules":[{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"pressureval","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"2","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1120,"y":240,"wires":[["ad466e7ee358d6eb","6306d4c550b8b1d4"]]},{"id":"25ab5b287455ad51","type":"change","z":"f5db42105a32fa69","name":"CurrentScaled","rules":[{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"currentscaled","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"1","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1120,"y":160,"wires":[["ad466e7ee358d6eb","6306d4c550b8b1d4"]]},{"id":"85e442a631d8a8a3","type":"change","z":"f5db42105a32fa69","name":"Status","rules":[{"t":"set","p":"parts.id","pt":"msg","to":"Join04","tot":"str"},{"t":"set","p":"parts.type","pt":"msg","to":"object","tot":"str"},{"t":"set","p":"parts.key","pt":"msg","to":"Status","tot":"str"},{"t":"set","p":"parts.index","pt":"msg","to":"3","tot":"num"},{"t":"set","p":"parts.count","pt":"msg","to":"4","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1150,"y":320,"wires":[["ad466e7ee358d6eb","6306d4c550b8b1d4"]]},{"id":"aa06e3d861b7d61f","type":"debug","z":"f5db42105a32fa69","name":"debug 6","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1400,"y":180,"wires":[]},{"id":"41bd5f8f1fae0613","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"5","payloadType":"num","x":730,"y":220,"wires":[["c919b02f4fbda282"]]},{"id":"1d6d9a1c2fc546b5","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"13","payloadType":"num","x":730,"y":160,"wires":[["25ab5b287455ad51"]]},{"id":"f59cf71a5a69f431","type":"change","z":"f5db42105a32fa69","name":"OK","rules":[{"t":"set","p":"payload","pt":"msg","to":"OK","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":280,"wires":[["85e442a631d8a8a3"]]},{"id":"49e70bcbdf12a386","type":"change","z":"f5db42105a32fa69","name":"OverRange","rules":[{"t":"set","p":"payload","pt":"msg","to":"Over Range","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":320,"wires":[["85e442a631d8a8a3"]]},{"id":"ab2603bb0fddf316","type":"change","z":"f5db42105a32fa69","name":"UnderRange","rules":[{"t":"set","p":"payload","pt":"msg","to":"Under Range","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":360,"wires":[["85e442a631d8a8a3"]]},{"id":"1846f4b1544abffc","type":"change","z":"f5db42105a32fa69","name":"WireBreak","rules":[{"t":"set","p":"payload","pt":"msg","to":"Wire Break","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":400,"wires":[["85e442a631d8a8a3"]]},{"id":"2db243b5f34a2a08","type":"switch","z":"f5db42105a32fa69","name":"StsMsg","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"4.1","vt":"num","v2":"20.1","v2t":"num"},{"t":"gt","v":"20.2","vt":"num"},{"t":"btwn","v":"0.1","vt":"num","v2":"4","v2t":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"false","repair":true,"outputs":4,"x":820,"y":340,"wires":[["f59cf71a5a69f431"],["49e70bcbdf12a386"],["ab2603bb0fddf316"],["1846f4b1544abffc"]]},{"id":"7a0387b6fa84ea9e","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"9","payloadType":"num","x":730,"y":280,"wires":[["2db243b5f34a2a08"]]}]
output
    "_msgid": "3cbefb2c3e8c01da",
    "payload": {
        "currentraw": 16,
        "currentscaled": 13,
        "pressureval": 5,
        "Status": "OK"
[edit] cleaned up status section.
Here is same thing with manual join, as i think an auto join is not really required
[{"id":"6119dbbe08835516","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"16","payloadType":"num","x":690,"y":80,"wires":[["a8e1976c66f4a15f"]]},{"id":"a8e1976c66f4a15f","type":"change","z":"f5db42105a32fa69","name":"CurrentRaw","rules":[{"t":"set","p":"topic","pt":"msg","to":"currentraw","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":80,"wires":[["ad466e7ee358d6eb","6306d4c550b8b1d4"]]},{"id":"ad466e7ee358d6eb","type":"join","z":"f5db42105a32fa69","name":"SigJoin","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"4","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":1280,"y":220,"wires":[["aa06e3d861b7d61f"]]},{"id":"6306d4c550b8b1d4","type":"debug","z":"f5db42105a32fa69","name":"debug 341","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1270,"y":60,"wires":[]},{"id":"c919b02f4fbda282","type":"change","z":"f5db42105a32fa69","name":"PressureGauge","rules":[{"t":"set","p":"topic","pt":"msg","to":"pressureval","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":240,"wires":[["ad466e7ee358d6eb","6306d4c550b8b1d4"]]},{"id":"25ab5b287455ad51","type":"change","z":"f5db42105a32fa69","name":"CurrentScaled","rules":[{"t":"set","p":"topic","pt":"msg","to":"currentscaled","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":160,"wires":[["ad466e7ee358d6eb","6306d4c550b8b1d4"]]},{"id":"85e442a631d8a8a3","type":"change","z":"f5db42105a32fa69","name":"Status","rules":[{"t":"set","p":"topic","pt":"msg","to":"Status","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1110,"y":320,"wires":[["ad466e7ee358d6eb","6306d4c550b8b1d4"]]},{"id":"aa06e3d861b7d61f","type":"debug","z":"f5db42105a32fa69","name":"debug 6","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1360,"y":180,"wires":[]},{"id":"41bd5f8f1fae0613","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"5","payloadType":"num","x":690,"y":220,"wires":[["c919b02f4fbda282"]]},{"id":"1d6d9a1c2fc546b5","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"13","payloadType":"num","x":690,"y":160,"wires":[["25ab5b287455ad51"]]},{"id":"f59cf71a5a69f431","type":"change","z":"f5db42105a32fa69","name":"OK","rules":[{"t":"set","p":"payload","pt":"msg","to":"OK","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":280,"wires":[["85e442a631d8a8a3"]]},{"id":"49e70bcbdf12a386","type":"change","z":"f5db42105a32fa69","name":"OverRange","rules":[{"t":"set","p":"payload","pt":"msg","to":"Over Range","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":320,"wires":[["85e442a631d8a8a3"]]},{"id":"ab2603bb0fddf316","type":"change","z":"f5db42105a32fa69","name":"UnderRange","rules":[{"t":"set","p":"payload","pt":"msg","to":"Under Range","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":360,"wires":[["85e442a631d8a8a3"]]},{"id":"1846f4b1544abffc","type":"change","z":"f5db42105a32fa69","name":"WireBreak","rules":[{"t":"set","p":"payload","pt":"msg","to":"Wire Break","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":400,"wires":[["85e442a631d8a8a3"]]},{"id":"2db243b5f34a2a08","type":"switch","z":"f5db42105a32fa69","name":"StsMsg","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"4.1","vt":"num","v2":"20.1","v2t":"num"},{"t":"gt","v":"20.2","vt":"num"},{"t":"btwn","v":"0.1","vt":"num","v2":"4","v2t":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"false","repair":true,"outputs":4,"x":780,"y":340,"wires":[["f59cf71a5a69f431"],["49e70bcbdf12a386"],["ab2603bb0fddf316"],["1846f4b1544abffc"]]},{"id":"7a0387b6fa84ea9e","type":"inject","z":"f5db42105a32fa69","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"9","payloadType":"num","x":690,"y":280,"wires":[["2db243b5f34a2a08"]]}]
thank you very much, i'll try to adapt it;
when i imported your example i did not press ctr+i first, just ctrl+v which pasted my (problematic) flow from the clipboard.
but thanks again, it makes sense now.
