Bug in JOIN Node?
I have a problem with the JOIN Node and the complete message.
Here a flow with the 2 examples.
        "id": "9b8e02cc37dcb236",
        "type": "split",
        "z": "a709bec85ce23ec9",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "arraySpltType": "len",
        "stream": false,
        "addname": "",
        "x": 430,
        "y": 2220,
                "2905751ca86149fe"
        "id": "2905751ca86149fe",
        "type": "json",
        "property": "payload.val",
        "action": "obj",
        "pretty": false,
        "x": 570,
        "y": 2220,
                "2c0e28f14e681cfd"
        "id": "f2877b240a1fc21f",
        "type": "switch",
        "name": "last Index?",
        "property": "parts.index",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "parts.count -1",
                "vt": "jsonata"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 750,
        "y": 2360,
                "022babe9323124dc"
        "id": "2c0e28f14e681cfd",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "[payload.val.lat,payload.val.lon]",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 750,
        "y": 2220,
                "851e03ea63234838"
        "id": "022babe9323124dc",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "complete",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 960,
        "y": 2360,
                "e27075061734811a"
        "id": "851e03ea63234838",
        "type": "join",
        "mode": "auto",
        "build": "array",
        "property": "payload",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "1",
        "count": "",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 950,
        "y": 2220,
                "c4041f685b6583c3"
        "id": "c54bc3f682f8c4ba",
        "type": "switch",
        "name": "only type=location",
        "property": "payload.val._type",
        "rules": [
                "t": "eq",
                "v": "location",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 750,
        "y": 2300,
                "816f52bdc597bed9"
        "id": "c4041f685b6583c3",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1110,
        "y": 2220,
        "id": "df5a25e85a2e7a7f",
        "type": "inject",
        "name": "Array",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "[{\"id\":10,\"ts\":1652943676271,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":40,\\\"alt\\\":559,\\\"batt\\\":100,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"lat\\\":51.056793,\\\"lon\\\":0.620149,\\\"m\\\":2,\\\"p\\\":95.763,\\\"t\\\":\\\"c\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652943675,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652945948484,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":40,\\\"alt\\\":559,\\\"batt\\\":100,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652945947,\\\"lat\\\":51.056807,\\\"lon\\\":0.620149,\\\"m\\\":2,\\\"p\\\":95.76,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652943675,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652945948537,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":100,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.76,\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946128185,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":99,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946128,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.815,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946308170,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":98,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946308,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.816,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946488296,\"val\":\"{\\\"_type\\\":\\\"dummy\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":97,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946488,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.815,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946668297,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":97,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946668,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.816,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946848279,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":97,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946848,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.818,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652947028272,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":97,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652947028,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.819,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652947208351,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":95,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652947208,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.819,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"}]",
        "payloadType": "json",
        "x": 270,
        "y": 2260,
                "2aeecd599694af82",
                "9b8e02cc37dcb236"
        "id": "2aeecd599694af82",
        "type": "split",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "stream": false,
        "addname": "",
        "x": 430,
        "y": 2300,
                "e4a9051a3defdbdd"
        "id": "e4a9051a3defdbdd",
        "type": "json",
        "action": "obj",
        "pretty": false,
        "x": 570,
        "y": 2300,
                "c54bc3f682f8c4ba",
                "f2877b240a1fc21f"
        "id": "816f52bdc597bed9",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 970,
        "y": 2300,
                "e27075061734811a"
        "id": "e27075061734811a",
        "type": "join",
        "mode": "auto",
        "build": "array",
        "key": "topic",
        "joiner": "\\n",
        "timeout": "1",
        "count": "",
        "reduceExp": "",
        "reduceInit": "",
        "reduceFixup": "",
        "x": 1170,
        "y": 2300,
                "d42c4b01e4e0106a"
        "id": "d42c4b01e4e0106a",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1330,
        "y": 2300,
I have an array that is splitted and then I rejoin the messages again. So in general no problem (example 1). However if I want to filter out some messages - automatic join does not work - as some messages are missing. Correct!!
So I will send a msg.complete to release the message already collected in the JOIN Node - however the last element is an object. Should this be the case? - How can I get rid off the last object element???
When I filter out some messages I should get fewer elements. So without filtering I get 9 array elements, when I filter one out and send a complete message, I expect to get 8 array elements without an object element.
Did the message containing complete have a payload?
No nothing.
That does not mean payload was empty (it just means you didnt add a payload)
Always check with a debug node!
Try adding another row to that change node to delete msg.payload
I have to check - you might have a point here. Wait I will check.
Ok there was an object - I deleted the payload in the lower part of the flow - and I got even more strange things. The last message and the filtered out message become undefined now.
If I delete the msg.part in the change node in the lower part - JOIN node complains, that it is missing the msg.part property.
I switch back the join node to manual it works. So not nice (I thought complete message could also work in automatic mode) - but so it is working.
So I deleted in the lower part the payload and the parts property and changed the JOIN Node to manual mode.
Many thanks!!
@mickym2 there is an option in the switch node to recreate message sequences this will allow you to use auto mode when you remove elements of the original array.
[{"id":"df5a25e85a2e7a7f","type":"inject","z":"bf9e1e33.030598","name":"Array","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"id\":10,\"ts\":1652943676271,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":40,\\\"alt\\\":559,\\\"batt\\\":100,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"lat\\\":51.056793,\\\"lon\\\":0.620149,\\\"m\\\":2,\\\"p\\\":95.763,\\\"t\\\":\\\"c\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652943675,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652945948484,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":40,\\\"alt\\\":559,\\\"batt\\\":100,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652945947,\\\"lat\\\":51.056807,\\\"lon\\\":0.620149,\\\"m\\\":2,\\\"p\\\":95.76,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652943675,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652945948537,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":100,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.76,\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946128185,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":99,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946128,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.815,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946308170,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":98,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946308,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.816,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946488296,\"val\":\"{\\\"_type\\\":\\\"dummy\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":97,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946488,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.815,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946668297,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":97,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946668,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.816,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652946848279,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":97,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652946848,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.818,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652947028272,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":97,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652947028,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.819,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"},{\"id\":10,\"ts\":1652947208351,\"val\":\"{\\\"_type\\\":\\\"location\\\",\\\"acc\\\":59,\\\"alt\\\":551,\\\"batt\\\":95,\\\"bs\\\":1,\\\"conn\\\":\\\"m\\\",\\\"created_at\\\":1652947208,\\\"lat\\\":51.073934,\\\"lon\\\":0.604433,\\\"m\\\":2,\\\"p\\\":95.819,\\\"t\\\":\\\"t\\\",\\\"tid\\\":\\\"MW\\\",\\\"tst\\\":1652945947,\\\"vac\\\":22}\"}]","payloadType":"json","x":70,"y":2220,"wires":[["2aeecd599694af82","9b8e02cc37dcb236"]]},{"id":"2aeecd599694af82","type":"split","z":"bf9e1e33.030598","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":230,"y":2260,"wires":[["e4a9051a3defdbdd"]]},{"id":"9b8e02cc37dcb236","type":"split","z":"bf9e1e33.030598","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":230,"y":2180,"wires":[["2905751ca86149fe"]]},{"id":"e4a9051a3defdbdd","type":"json","z":"bf9e1e33.030598","name":"","property":"payload.val","action":"obj","pretty":false,"x":370,"y":2260,"wires":[["c54bc3f682f8c4ba"]]},{"id":"2905751ca86149fe","type":"json","z":"bf9e1e33.030598","name":"","property":"payload.val","action":"obj","pretty":false,"x":370,"y":2180,"wires":[["2c0e28f14e681cfd"]]},{"id":"c54bc3f682f8c4ba","type":"switch","z":"bf9e1e33.030598","name":"only type=location","property":"payload.val._type","propertyType":"msg","rules":[{"t":"eq","v":"location","vt":"str"}],"checkall":"true","repair":true,"outputs":1,"x":550,"y":2260,"wires":[["816f52bdc597bed9"]]},{"id":"2c0e28f14e681cfd","type":"change","z":"bf9e1e33.030598","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[payload.val.lat,payload.val.lon]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":2180,"wires":[["851e03ea63234838"]]},{"id":"816f52bdc597bed9","type":"change","z":"bf9e1e33.030598","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[payload.val.lat,payload.val.lon]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":2260,"wires":[["e27075061734811a"]]},{"id":"851e03ea63234838","type":"join","z":"bf9e1e33.030598","name":"","mode":"auto","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"1","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":2180,"wires":[["c4041f685b6583c3"]]},{"id":"e27075061734811a","type":"join","z":"bf9e1e33.030598","name":"","mode":"auto","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"1","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":970,"y":2260,"wires":[["d42c4b01e4e0106a"]]},{"id":"c4041f685b6583c3","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":910,"y":2180,"wires":[]},{"id":"d42c4b01e4e0106a","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1130,"y":2260,"wires":[]}]
Wow - thanks very much! - You are the absolute master of NodeRed. Sometime I thought I would already know a lot - but you are my teacher and master of this tool. Sometimes you see the options, but you never used it. Great job you are doing here on board!!!
