Split sensor readings
I am getting transmitter data as below.
Temperature Channel 1: C: 29.68Temperature Channel 2: C: 29.43Temperature Channel 3: C: 31.12
Can someone please guide me how can i separate these three readings? I want to create chart with three separate readings ( i.e. 29.68 , 29.43 , 31.12)? All three temperature readings are coming from one transmitter (NCD io).
I am collecting data locally on my laptop using NCD Mega modem & NCD 3 channel thermocouple sensors.
Welcome to the forum @PinPat.
Please feed the data you are receiving into a debug node and show us what you get. Then we will more exactly what is there.
If you are a complete beginner I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Also have a good look at the node red doc Working with Messages which should help to answer your specific question.
Thanks for your quick response. I will go through playlist now.
Meanwhile dedug is giving me below code.
sensor_data : msg.payload : Object
{ channel_1: 30.43, channel_2: 29.62, channel_3: 30.12 }
If it's an object, you should be able to use a 'change node' or a 'function node' to extract the data.
Here's an example for 'channel_1'.
Screen Shot 02-24-21 at 08.27 AM
Screen Shot 02-24-21 at 08.27 AM 001
Screen Shot 02-24-21 at 08.27 AM 002
Thanks @dynamicdave . Magic worked.
That was a simple, yet elegant solution. Thanks for sharing!
