Splitting a string after space
I have a incoming msg.payload.Name, which I want to split.
The msg.payload.Name always starts with Watts , which is what I want to split.
Examples for msg.payload.Name are
Watts Power TV
Watts Kitchen TV
So if I have 'Watts Power TV' in msg.payload.Name, I want to have msg.payload.Name 'Power TV'
I have tried this in a function node but it doesnt work
const n = msg.payload.Name;
msg.payload.name = n.slice(msg.payload.Name, 5)
First split it, then slice the array, then you can rejoin the array.
msg.payload.name = n.split(" ").slice(1).join(" ")
Or you could use string.replace("Watts ", "")
But why call a function you could just use a change node and search for Watts and replace with nothing
If msg.payload.Name ALWAYS starts with "Watts " then your code should be
msg.payload.name = n.slice(6)
Or you could use
msg.payload.name = n.substr(6)
NB you are creating msg.payload.name, not the same thing as msg.payload.Name that you started off with.
It is actually msg.payload.nodeName
so I changed it to
const n = msg.payload.nodeName;
msg.payload.nodeName = n.slice(6)
But I am getting a error
TypeError: Cannot read properties of undefined (reading 'slice')
If you use the built in helper tools you will avoid the guess work...
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
Basically it is NOT msg.payload.name nor is it msg.payload.nodeName - so use the copy path button :slight_smile:
You are correct ! I did see the copy but never used it (I am still a newbie)
This is from the copy:
{"topic":"sync","_msgid":"64525d3a941a3005","nodeName":"Watts Lounge TV","payload":{"ref":3137,"name":"Watts Lounge TV","location":"Lounge","location2":"AV","value":0,"status":"0 Watts","device_type_string":"Z-Wave Electric Meter","last_change":"/Date(1667909087397+0000)/","relationship":4,"hide_from_view":false,"associated_devices":[3135],"device_type":{"Device_API":256,"Device_API_Description":"Energy API","Device_Type":1,"Device_Type_Description":"Watts","Device_SubType":50,"Device_SubType_Description":""},"device_type_values":null,"UserNote":"","UserAccess":"Any","status_image":"/images/HomeSeer/status/electricity.gif","voice_command":"","misc":4352,"interface_name":"Z-Wave"}}
So I changed the function to
const n = msg.topic.nodeName;
msg.topic.nodeName = n.slice(6);
But I still have the same error
It's easier to provide support if you don't keep moving the goalposts. :wink:
Edit - I think you might find it's msg.nodeName. At least it was at one time.
Sorry I find this debug info a bit confusing, as Watts Loung TV is there twice.
If you play a bit with the buttons that SteveMcl showed you, you will see that this particular message has:
msg.topic (equals "sync")
msg.nodeName (equals "Watts Lounge TV")
msg.payload (an object comprising msg.payload.ref, msg.payload.name [ equals "Watts Lounge TV" ], msg.payload.location, etc)
So it's up to you if you operate on msg.nodeName or msg.payload.name. But whichever you pick, stick to your choice and pay attention to precise naming and upper/lower case.
Personally I'd stick with msg.payload.name but no very good reason for that choice.
Looked at the debug info again. I thought it should be msg.payload.name, but it isnt, same error. But I tried
const n = msg.nodeName;
msg.nodeName = n.slice(6);
Thats working. Great. But dont really understand why msg.payload.name did not work.
But copying from the debug node does help me for the future, I thought I had it worked out how to get to message data. Obviously still have to learn !
Yoyr help is much appreciated !
