Splitting and Assigning String Data
I am using the Serial Node to Read Data from a serial USB device, it returns the following string:
z+2.524+2.280+2.109+0.000
Can anyone point me int he right direction of how to:
Remove the 'z' and then split each value out and assign each value with a seperate 'channel' so I can distinguish between each channel from my device.
How about this as a starting point?
[{"id":"9948412e.7102c8","type":"inject","z":"b9924a74.4d98f8","name":"","topic":"","payload":"z+2.524+2.280+2.109+0.000","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":4470,"wires":[["8c09fe88.a41d4"]]},{"id":"8c09fe88.a41d4","type":"split","z":"b9924a74.4d98f8","name":"","splt":"+","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":260,"y":4470,"wires":[["d2512309.42fb8","63d52c69.73181c"]]},{"id":"d2512309.42fb8","type":"debug","z":"b9924a74.4d98f8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":260,"y":4420,"wires":[]},{"id":"63d52c69.73181c","type":"switch","z":"b9924a74.4d98f8","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"}],"checkall":"true","repair":false,"outputs":5,"x":410,"y":4470,"wires":[["8a6ffe84.0403b8"],["4f6ebec3.095e58"],["9d02e6fc.3ab27"],["af01a655.f963a"],["9173b25c.e3be4"]]},{"id":"8a6ffe84.0403b8","type":"debug","z":"b9924a74.4d98f8","name":"1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":560,"y":4390,"wires":[]},{"id":"4f6ebec3.095e58","type":"debug","z":"b9924a74.4d98f8","name":"2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":560,"y":4430,"wires":[]},{"id":"9d02e6fc.3ab27","type":"debug","z":"b9924a74.4d98f8","name":"3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":560,"y":4470,"wires":[]},{"id":"af01a655.f963a","type":"debug","z":"b9924a74.4d98f8","name":"4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":560,"y":4510,"wires":[]},{"id":"9173b25c.e3be4","type":"debug","z":"b9924a74.4d98f8","name":"5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":560,"y":4550,"wires":[]}]
I went over the top with outputs, but it will show you how to expand on things if you need more.
If you don't, just edit the switch node and delete the last output.
I would probably use a function node to convert it to a javascript object, something like this
const splitted = msg.payload.split("+")
msg.payload = {field1: splitted[1], field2: splitted[2], field3: splitted[3], field4: splitted[4]}
Obviously change field1 etc to appropriate names.
[{"id":"46ff6251.23cd64","type":"inject","z":"bdd7be38.d3b55","name":"","props":[{"p":"payload","v":"z+2.524+2.280+2.109+0.000","vt":"str"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"z+2.524+2.280+2.109+0.000","payloadType":"str","x":110,"y":1000,"wires":[["52cffe47.f91248"]]},{"id":"52cffe47.f91248","type":"function","z":"bdd7be38.d3b55","name":"","func":"const splitted = msg.payload.split(\"+\")\nmsg.payload = {field1: splitted[1], field2: splitted[2], field3: splitted[3], field4: splitted[4]}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":280,"y":1000,"wires":[["46b3ee82.308e88"]]},{"id":"46b3ee82.308e88","type":"debug","z":"bdd7be38.d3b55","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":470,"y":1000,"wires":[]}]
I would also do it in a function node.
msg.payload = msg.payload.split("+").slice(1);
edit/ did not catch the seperate channel part .
You could also try a csv node set to split on +
Cheers, I have implemented your solution and it works perfect!
Thanks for your time to write a response and flow.
Cheers Colin, much appreciated
