Splitting payload from serial
Hi :slight_smile: first time on forum, got a question:
Trying to split a payload into several outputs:
{"payload":"6434,-1.50,kg,26.50,25.50,\r\n","port":"/dev/ttyUSB0","_msgid":"870aa08d.f4a58"}
Im betting I need to use a split function, but how? I can't comma seperate. I want one output for "-1,5" , one output for 26,50, and one for 25,50.
Can anyone point me in the right direction?
PS this is a sparkfun openscale board with an external temp sensor, connected to a raspberry pi.
I don't understand. In the string you have shown -1.50 not -1,50 so splitting on comma would seem to be what you want.
its because if I comma split, I will get one message with "kg" in it :slight_smile:
Why is that a problem?
Use the CSV node. That way you can re-add the property names you want
hm, maybe its my noobishness that is the cause of me not seing the solution here.
My goal with splitting the numbers in this payload into 3 seperate outputs, to be put into influxDB and from there into Grafana.
Having split it you will get an array (assuming you do it in a function node). You can simply ignore the third element when you build the message to send to influx.
As @dceejay suggested, the CSV node may well be the simplest way, using that you can allocate the influx topic names to the values automatically.
I just tried it, the \r\n are causing javascript issues. Can't split it into an array, at least I couldn't.
simple csv example
[{"id":"2297eb8e.63fa74","type":"inject","z":"b5ae4792.3b8598","name":"","topic":"","payload":"6434,-1.50,kg,26.50,25.50,\\r\\n","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":1220,"wires":[["fdfe718f.714d4"]]},{"id":"fdfe718f.714d4","type":"csv","z":"b5ae4792.3b8598","name":"","sep":",","hdrin":"","hdrout":"","multi":"one","ret":"\\n","temp":",kg,,temp1,temp2","skip":"0","x":270,"y":1220,"wires":[["b0b29c1b.1f12e"]]},{"id":"b0b29c1b.1f12e","type":"debug","z":"b5ae4792.3b8598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":430,"y":1220,"wires":[]}]
Thank you for pointing me in the right directoin. Im gonna need to read up on the CSV nodeto understand it better, cause I am not quite sure how to implement the example in a flow :slight_smile:
Edit: I gotta say though, that the ca day and a half I've been spending with node-red, has got me impressed! Its a very powerful and versatile piece of software, and I cant help to wonder about all the other projects I could use it for.
I'd feed the serialport direct into the csv above.
You could also use a function to split them into individual messages if you want.
I'm not sure what the influx node needs though so...
[{"id":"2297eb8e.63fa74","type":"inject","z":"b5ae4792.3b8598","name":"","topic":"","payload":"6434,-1.50,kg,26.50,25.50,\\r\\n","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":1220,"wires":[["fdfe718f.714d4"]]},{"id":"fdfe718f.714d4","type":"csv","z":"b5ae4792.3b8598","name":"","sep":",","hdrin":"","hdrout":"","multi":"one","ret":"\\n","temp":",kg,,temp1,temp2","skip":"0","x":270,"y":1220,"wires":[["b0b29c1b.1f12e","20896c5.bce1f94"]]},{"id":"b0b29c1b.1f12e","type":"debug","z":"b5ae4792.3b8598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":450,"y":1200,"wires":[]},{"id":"20896c5.bce1f94","type":"function","z":"b5ae4792.3b8598","name":"","func":"\nvar msg1 = {topic:\"kg\", payload:msg.payload.kg};\nvar msg2 = {topic:\"temp1\", payload:msg.payload.temp1};\nvar msg3 = {topic:\"temp2\", payload:msg.payload.temp2};\nreturn [msg1,msg2,msg3];","outputs":3,"noerr":0,"x":400,"y":1260,"wires":[["5d20a53f.0d7abc"],["5d20a53f.0d7abc"],["5d20a53f.0d7abc"]]},{"id":"5d20a53f.0d7abc","type":"debug","z":"b5ae4792.3b8598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":570,"y":1260,"wires":[]}]
or to do same with just core nodes (no function node)
[{"id":"2297eb8e.63fa74","type":"inject","z":"b5ae4792.3b8598","name":"","topic":"","payload":"6434,-1.50,kg,26.50,25.50,\\r\\n","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":1220,"wires":[["fdfe718f.714d4"]]},{"id":"fdfe718f.714d4","type":"csv","z":"b5ae4792.3b8598","name":"","sep":",","hdrin":"","hdrout":"","multi":"one","ret":"\\n","temp":",kg,,temp1,temp2","skip":"0","x":270,"y":1220,"wires":[["2b77b16e.df18be","b0b29c1b.1f12e"]]},{"id":"2b77b16e.df18be","type":"split","z":"b5ae4792.3b8598","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":390,"y":1220,"wires":[["f2059d22.9ea2b"]]},{"id":"b0b29c1b.1f12e","type":"debug","z":"b5ae4792.3b8598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":1160,"wires":[]},{"id":"f2059d22.9ea2b","type":"switch","z":"b5ae4792.3b8598","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"kg","vt":"str"},{"t":"eq","v":"temp1","vt":"str"},{"t":"eq","v":"temp2","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":510,"y":1220,"wires":[["5d20a53f.0d7abc"],["5d20a53f.0d7abc"],["5d20a53f.0d7abc"]]},{"id":"5d20a53f.0d7abc","type":"debug","z":"b5ae4792.3b8598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":670,"y":1220,"wires":[]}]
Ive been looking into the csv doc and some youtube vids, without really getting a grasp on how I should configure the CSV node.
When I use it at default config, I do however see that the output is perhaps easier to use than straight from a serial out, in the form that the payload now is indexed with col1 col2 col3 col4 col5.
node-red-openscale%20flow-csv1
Can I ask where I should input the code example you write?
Go to an empty area in your flow (or create a new tab) then copy the example (Ctrl+C or similar) then in node-red click on the hamburger menu in the top right and select Import > Clipboard then paste it into the window and click Import. Then use the mouse to position the flow where you want, and click to drop it.
That worked beautifully :slight_smile: Im going to play around with this a while, experimenting with InfluxDb (which is also new to me) and Grafana.
This is going to end up being a weight for one of my beehives, if anyone wondered:-)
Nice ! :honeybee:
Please post the results in "share your projects" when done (including a picture from the :honeybee:beehive :honeybee:)
Ofc I will :wink:
Update
Like I said Colin, your code suggestion worked very well. This is what I am currently at. Working on a problem with what I believe is the adding of data to influx. Whereas I cant seem to get anything to show up in grafana. But when checking the database itself there seems to be data there.
node-red-openscale%20flow-csv3
Editadded a screenshot of the perfect printout of 3 temperatures, 1 humidity and i kg.
Edit
2* fixed the grafana problem too :slight_smile: Ty all for the good help.
[{"id":"e232e416.406958","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"d8f2a3b8.a5513","type":"serial in","z":"e232e416.406958","name":"OpenScale","serial":"ccdd97ab.3693a8","x":240,"y":720,"wires":[["9a70f63c.189ad8"]]},{"id":"b841e4cb.b41898","type":"rpi-dht22","z":"e232e416.406958","name":"","topic":"rpi-dht22","dht":22,"pintype":"0","pin":4,"x":520,"y":300,"wires":[["96013ecd.27ab1","9b2624cd.0c0d28"]]},{"id":"4f3518ef.2226c8","type":"inject","z":"e232e416.406958","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":300,"wires":[["b841e4cb.b41898"]]},{"id":"96013ecd.27ab1","type":"function","z":"e232e416.406958","name":"tempread","func":"msg.payload = msg.payload\nreturn msg;","outputs":1,"noerr":0,"x":720,"y":260,"wires":[["d506efdb.82ddc","95d372b7.dcfc2","d1f2d47.88b5628"]]},{"id":"9b2624cd.0c0d28","type":"function","z":"e232e416.406958","name":"humread","func":"msg.payload = msg.humidity\nreturn msg;","outputs":1,"noerr":0,"x":720,"y":340,"wires":[["b6ad82bb.8abdb","79a460a4.ae748","d1fcc6e2.667538"]]},{"id":"d506efdb.82ddc","type":"debug","z":"e232e416.406958","name":"dht22-temp","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":930,"y":220,"wires":[]},{"id":"b6ad82bb.8abdb","type":"debug","z":"e232e416.406958","name":"dht22-hum","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":930,"y":360,"wires":[]},{"id":"95d372b7.dcfc2","type":"ui_gauge","z":"e232e416.406958","name":"dht22-temp","group":"b7a43d33.940bb","order":0,"width":"6","height":"4","gtype":"compass","title":"dht22-temp","label":"c","format":"{{value}}","min":"10","max":"40","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":930,"y":300,"wires":[]},{"id":"79a460a4.ae748","type":"ui_gauge","z":"e232e416.406958","name":"dht22-hum","group":"f146c9c2.9a4b08","order":0,"width":0,"height":0,"gtype":"gage","title":"dht22-hum","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":930,"y":440,"wires":[]},{"id":"d1fcc6e2.667538","type":"influxdb out","z":"e232e416.406958","influxdb":"37636a80.ee4ca6","name":"dht22-hum","measurement":"dht22-hum","precision":"","retentionPolicy":"","x":930,"y":400,"wires":[]},{"id":"9a70f63c.189ad8","type":"csv","z":"e232e416.406958","name":"","sep":",","hdrin":"","hdrout":"","multi":"one","ret":"\\n","temp":",kg,,temp1,temp2","skip":"0","x":410,"y":720,"wires":[["9b6a450b.c07308","527ff6a7.780a78"]]},{"id":"9b6a450b.c07308","type":"split","z":"e232e416.406958","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":530,"y":720,"wires":[["8fe60e8e.57cd6"]]},{"id":"527ff6a7.780a78","type":"debug","z":"e232e416.406958","name":"csv output payload","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":570,"y":660,"wires":[]},{"id":"8fe60e8e.57cd6","type":"switch","z":"e232e416.406958","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"kg","vt":"str"},{"t":"eq","v":"temp1","vt":"str"},{"t":"eq","v":"temp2","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":650,"y":720,"wires":[["9562fa92.6175a8","7dff7bcf.fb9614","6a2ece8e.cd605"],["febbde8e.1c211","33595486.a31c9c","f904bbab.25b9d8"],["223fd5b6.5b020a","c0da5e7d.d845b","5b3dbc7d.ff1b14"]]},{"id":"9562fa92.6175a8","type":"debug","z":"e232e416.406958","name":"OpenScale-kg","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":940,"y":500,"wires":[]},{"id":"febbde8e.1c211","type":"debug","z":"e232e416.406958","name":"temp-onboardOS","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":950,"y":640,"wires":[]},{"id":"223fd5b6.5b020a","type":"debug","z":"e232e416.406958","name":"temp-ds18B20","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":940,"y":780,"wires":[]},{"id":"d1f2d47.88b5628","type":"influxdb out","z":"e232e416.406958","influxdb":"37636a80.ee4ca6","name":"dht22-temp","measurement":"dht22-temp","precision":"","retentionPolicy":"","x":930,"y":260,"wires":[]},{"id":"7dff7bcf.fb9614","type":"influxdb out","z":"e232e416.406958","influxdb":"37636a80.ee4ca6","name":"OpenScale-kg","measurement":"kg","precision":"","retentionPolicy":"","x":940,"y":540,"wires":[]},{"id":"33595486.a31c9c","type":"influxdb out","z":"e232e416.406958","influxdb":"37636a80.ee4ca6","name":"temp-onboardOS","measurement":"temp-onboardOS","precision":"","retentionPolicy":"","x":950,"y":680,"wires":[]},{"id":"c0da5e7d.d845b","type":"influxdb out","z":"e232e416.406958","influxdb":"37636a80.ee4ca6","name":"temp-ds18B20","measurement":"temp-ds18B20","precision":"","retentionPolicy":"","x":940,"y":820,"wires":[]},{"id":"6a2ece8e.cd605","type":"ui_gauge","z":"e232e416.406958","name":"","group":"f146c9c2.9a4b08","order":0,"width":0,"height":0,"gtype":"gage","title":"OpenScale-kg","label":"OpenScale-kg","format":"{{value}}","min":"-1","max":"5","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":940,"y":580,"wires":[]},{"id":"f904bbab.25b9d8","type":"ui_gauge","z":"e232e416.406958","name":"temp-onboardOS","group":"f146c9c2.9a4b08","order":0,"width":0,"height":0,"gtype":"gage","title":"temp-onboardOS","label":"C","format":"{{value}}","min":"-1","max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":950,"y":720,"wires":[]},{"id":"5b3dbc7d.ff1b14","type":"ui_gauge","z":"e232e416.406958","name":"temp-ds18B20","group":"f146c9c2.9a4b08","order":0,"width":0,"height":0,"gtype":"gage","title":"temp-ds18B20","label":"C","format":"{{value}}","min":"-1","max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":940,"y":860,"wires":[]},{"id":"ccdd97ab.3693a8","type":"serial-port","z":"","serialport":"/dev/ttyUSB0","serialbaud":"9600","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":false,"responsetimeout":"10000"},{"id":"b7a43d33.940bb","type":"ui_group","z":"","name":"Default","tab":"32e61df0.efb002","disp":true,"width":"6","collapse":false},{"id":"f146c9c2.9a4b08","type":"ui_group","z":"","name":"Default","tab":"32e61df0.efb002","disp":true,"width":"6","collapse":false},{"id":"37636a80.ee4ca6","type":"influxdb","z":"","hostname":"127.0.0.1","port":"8086","protocol":"http","database":"TEMPERATURER","name":"influxDBimport","usetls":false,"tls":""},{"id":"32e61df0.efb002","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
The example flow was actually from @dceejay, not me, but I am happy to receive some of the reflected glory :slight_smile:
Hi guys, been tinkering with this, specifically with Grafana.
My problem now is that in grafana the measurements from DHT22 sensor (hum% and temp) arent displaying its numbers in grafana. Grafana does however draw the graph, strangely enough.
See screenshot
At first I thought it might be something wrong with my querries in Grafana. But when I look at the output from debug log in node-red, I suspect its the format that is the problem.
Look at this screenshot:
node-red1
The measurements I have problems with are of the payload type String. While the measurements I do not have problems with, are of a payload type number.
My current flow:
[{"id":"e232e416.406958","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"d8f2a3b8.a5513","type":"serial in","z":"e232e416.406958","name":"OpenScale","serial":"ccdd97ab.3693a8","x":240,"y":720,"wires":[["9a70f63c.189ad8"]]},{"id":"b841e4cb.b41898","type":"rpi-dht22","z":"e232e416.406958","name":"","topic":"rpi-dht22","dht":22,"pintype":"0","pin":4,"x":520,"y":300,"wires":[["96013ecd.27ab1","9b2624cd.0c0d28"]]},{"id":"4f3518ef.2226c8","type":"inject","z":"e232e416.406958","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":300,"wires":[["b841e4cb.b41898"]]},{"id":"96013ecd.27ab1","type":"function","z":"e232e416.406958","name":"tempread","func":"msg.payload = msg.payload\nreturn msg;","outputs":1,"noerr":0,"x":720,"y":260,"wires":[["d506efdb.82ddc","95d372b7.dcfc2","d1f2d47.88b5628"]]},{"id":"9b2624cd.0c0d28","type":"function","z":"e232e416.406958","name":"humread","func":"msg.payload = msg.humidity\nreturn msg;","outputs":1,"noerr":0,"x":720,"y":340,"wires":[["b6ad82bb.8abdb","79a460a4.ae748","d1fcc6e2.667538"]]},{"id":"d506efdb.82ddc","type":"debug","z":"e232e416.406958","name":"dht22temp","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":930,"y":220,"wires":[]},{"id":"b6ad82bb.8abdb","type":"debug","z":"e232e416.406958","name":"dht22hum","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":920,"y":360,"wires":[]},{"id":"95d372b7.dcfc2","type":"ui_gauge","z":"e232e416.406958","name":"dht22temp","group":"b7a43d33.940bb","order":0,"width":"6","height":"4","gtype":"compass","title":"dht22temp","label":"c","format":"{{value}}","min":"10","max":"40","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":930,"y":300,"wires":[]},{"id":"79a460a4.ae748","type":"ui_gauge","z":"e232e416.406958","name":"dht22hum","group":"f146c9c2.9a4b08","order":0,"width":0,"height":0,"gtype":"gage","title":"dht22hum","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":920,"y":440,"wires":[]},{"id":"d1fcc6e2.667538","type":"influxdb out","z":"e232e416.406958","influxdb":"cf48165c.d593b8","name":"dht22hum","measurement":"dht22hum","precision":"","retentionPolicy":"","x":920,"y":400,"wires":[]},{"id":"9a70f63c.189ad8","type":"csv","z":"e232e416.406958","name":"","sep":",","hdrin":"","hdrout":"","multi":"one","ret":"\\n","temp":",kg,,temp1,temp2","skip":"0","x":410,"y":720,"wires":[["9b6a450b.c07308"]]},{"id":"9b6a450b.c07308","type":"split","z":"e232e416.406958","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":530,"y":720,"wires":[["8fe60e8e.57cd6"]]},{"id":"8fe60e8e.57cd6","type":"switch","z":"e232e416.406958","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"kg","vt":"str"},{"t":"eq","v":"temp1","vt":"str"},{"t":"eq","v":"temp2","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":650,"y":720,"wires":[["9562fa92.6175a8","7dff7bcf.fb9614","6a2ece8e.cd605"],["febbde8e.1c211","33595486.a31c9c","f904bbab.25b9d8"],["223fd5b6.5b020a","5b3dbc7d.ff1b14","c0da5e7d.d845b"]]},{"id":"9562fa92.6175a8","type":"debug","z":"e232e416.406958","name":"OpenScalekg","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":940,"y":500,"wires":[]},{"id":"febbde8e.1c211","type":"debug","z":"e232e416.406958","name":"onboardOStemp","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":940,"y":640,"wires":[]},{"id":"223fd5b6.5b020a","type":"debug","z":"e232e416.406958","name":"ds18B20","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":920,"y":780,"wires":[]},{"id":"d1f2d47.88b5628","type":"influxdb out","z":"e232e416.406958","influxdb":"cf48165c.d593b8","name":"dht22temp","measurement":"dht22temp","precision":"","retentionPolicy":"","x":930,"y":260,"wires":[]},{"id":"7dff7bcf.fb9614","type":"influxdb out","z":"e232e416.406958","influxdb":"cf48165c.d593b8","name":"OpenScalekg","measurement":"kg","precision":"","retentionPolicy":"","x":940,"y":540,"wires":[]},{"id":"33595486.a31c9c","type":"influxdb out","z":"e232e416.406958","influxdb":"cf48165c.d593b8","name":"onboardOStemp","measurement":"temp-onboardOS","precision":"","retentionPolicy":"","x":940,"y":680,"wires":[]},{"id":"c0da5e7d.d845b","type":"influxdb out","z":"e232e416.406958","influxdb":"cf48165c.d593b8","name":"ds18B20","measurement":"ds18B20","precision":"","retentionPolicy":"","x":920,"y":820,"wires":[]},{"id":"6a2ece8e.cd605","type":"ui_gauge","z":"e232e416.406958","name":"","group":"f146c9c2.9a4b08","order":0,"width":0,"height":0,"gtype":"gage","title":"OpenScalekg","label":"OpenScalekg","format":"{{value}}","min":"-1","max":"5","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":940,"y":580,"wires":[]},{"id":"f904bbab.25b9d8","type":"ui_gauge","z":"e232e416.406958","name":"temp-onboardOS","group":"f146c9c2.9a4b08","order":0,"width":0,"height":0,"gtype":"gage","title":"onboardOStemp","label":"C","format":"{{value}}","min":"-1","max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":950,"y":720,"wires":[]},{"id":"5b3dbc7d.ff1b14","type":"ui_gauge","z":"e232e416.406958","name":"ds18B20","group":"f146c9c2.9a4b08","order":0,"width":0,"height":0,"gtype":"gage","title":"ds18B20","label":"C","format":"{{value}}","min":"-1","max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":920,"y":860,"wires":[]},{"id":"ccdd97ab.3693a8","type":"serial-port","z":"","serialport":"/dev/ttyUSB0","serialbaud":"9600","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":false,"responsetimeout":"10000"},{"id":"b7a43d33.940bb","type":"ui_group","z":"","name":"Default","tab":"32e61df0.efb002","disp":true,"width":"6","collapse":false},{"id":"f146c9c2.9a4b08","type":"ui_group","z":"","name":"Default","tab":"32e61df0.efb002","disp":true,"width":"6","collapse":false},{"id":"cf48165c.d593b8","type":"influxdb","z":"","hostname":"192.168.1.17","port":"8086","protocol":"http","database":"beehive","name":"","usetls":false,"tls":""},{"id":"32e61df0.efb002","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
