Hello
I'm trying to do a droplist from data of a sql query. I saw on this forum that we must change the data after the SQL node (with the msg.options) but I don't how to do that. The SQL column name come in my droplist and not my data.
If anyone can help me
My droplist:
Data from my sql node :
My JSON code :
"id": "a363ca24a2531546",
"type": "tab",
"label": "Update Ordre",
"disabled": false,
"info": ""
"id": "c8a90569939aa916",
"type": "ui_dropdown",
"z": "a363ca24a2531546",
"label": "Selectionner Nom Ordre",
"tooltip": "",
"place": "",
"group": "77a6a8681bbac499",
"order": 1,
"width": 0,
"height": 0,
"passthru": false,
"multiple": true,
"options": [
"label": "",
"value": "",
"type": "str"
"payload": "",
"topic": "topic",
"topicType": "msg",
"x": 1290,
"y": 240,
"id": "17c8979555a460a0",
"type": "mysql",
"mydb": "b6ea25d4ebdbea0f",
"name": "Base de données",
"x": 670,
"y": 240,
"d2d29ab7b018de03"
"id": "4b5bd92e91346cb3",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "0.5",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payloadType": "date",
"x": 180,
"y": 240,
"id": "bdd120e7d0880d8d",
"type": "function",
"name": "SELECT",
"func": "var query\n\nquery = \"SELECT ORD_Identifiant FROM ordre ORDER by ORD_Date DESC \"\n\n\nmsg.topic = query\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 400,
"y": 240,
"17c8979555a460a0"
"id": "6d16b45ef8f3b2a6",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "options",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1250,
"y": 180,
"id": "d2d29ab7b018de03",
"type": "function",
"name": "Change data",
"func": "msg.options = msg.payload\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 950,
"y": 240,
"c8a90569939aa916",
"6d16b45ef8f3b2a6"
"id": "77a6a8681bbac499",
"type": "ui_group",
"name": "Update",
"tab": "3702ac9912314511",
"order": 1,
"disp": false,
"width": "12",
"collapse": false
"id": "b6ea25d4ebdbea0f",
"type": "MySQLdatabase",
"host": "127.0.0.1",
"port": "3306",
"db": "ordresmartfactory",
"tz": "",
"charset": "UTF8"
"id": "3702ac9912314511",
"type": "ui_tab",
"name": "Update",
"icon": "dashboard",
"disabled": false,
"hidden": false
