SQLite and localtime operations
I have been trying to modify Pete Scargill's Track Broadband Outage in Node Red to report the results in my local time (zone), but I keep hitting a brick wall.
Primarily the problem appears to be in the section that generates the email
var a=msg.payload;
msg.payload=””;
if (a.length!==0)
for (var i in a)
msg.payload+=”\r\n”+ ((a[i].ping !== 0) ? “Regained” : “Lost”) +” connection ” + a[i].thetime;
return(msg);
I tried a few different Javascript calls to try to change "thetime" to local time, but they didn't work.
I was able to create a SQLite query to return the local time, but then I couldn't match this up with above code. This is the query that worked as a plan query.
SELECT datetime(thetime,'localtime'), ping FROM pings ORDER BY thetime DESC LIMIT 0, 30
However this was generating the result:
datetime(thetime,'localtime'): "2020-04-22 14:41:40"
thetime: "2020-04-22 14:41:40"
Any suggestions would be appreciated.
Ok I found a solution to this problem:
Change this to
SELECT datetime(thetime,'localtime') AS brisbanetime, ping FROM pings ORDER BY thetime DESC LIMIT 0, 30
Then in the generated result it will be brisbanetime: "2020-04-22 14:41:40"
Then in the Build Email String, just change "thetime" to "brisbanetime".
