Stacked Bars Chart with msg.ui_control
I need to have a bar chart with stacked columns. Unfortunately this is not an option you can find in the configuration window (why?, it's a super standard bar chart style ), so I followed HotNipi's Feb. 10th post suggesting to use msg.ui_control :
msg.ui_control = {
    options: {
        scales: {
            xAxes: [{
                stacked: true
            yAxes: [{
                stacked: true
It works, but it has some undesired side-effects, i.e. lettering is greyed, reference lines are black and so on, as you can see form the attached screenshot:
The problem is that, once you use msg.Ui_control even with "stacked:false" you have no way to revert to the default behaviour. To have a default bar chart never use the msg.ui_control in the setup function.
Where can I find the options to set the lettering colour and other "cosmetic" appearances?
Here is my testing flow:
[{"id":"6da19252.e0495c","type":"function","z":"461c9df1.6c1c94","name":"setup data","func":"\n\nvar dataseries1 =[10,15,20];\nvar dataseries2 =[5,8,13];\nvar data = [dataseries1,dataseries2];\nvar datalabels =[\"2018\",\"2019\",\"2020\"];\n\nvar chart = [{\n\"series\": [\"Production\", \"Consumption\"],\n\"data\": data,\n\"labels\": datalabels\n}];\n//msg.title = \"Side-By-Side Bars\";\n\nmsg.payload = chart;\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":200,"wires":[["f8f0c6c1.88afc8"]]},{"id":"f8f0c6c1.88afc8","type":"ui_chart","z":"461c9df1.6c1c94","name":"Bars","group":"6c744598.ccf8bc","order":3,"width":"7","height":"7","label":"","chartType":"bar","legend":"true","xformat":"HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"","removeOlder":"12","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":830,"y":160,"wires":[[]]},{"id":"6a3db5e0.92b2fc","type":"function","z":"461c9df1.6c1c94","name":"clear data","func":"\nmsg.payload = [];\nmsg.ui_control = {\n    options: {\n        scales: {\n            xAxes: [{\n                stacked: true\n            }],\n            yAxes: [{\n                tacked: true\n            }]\n        }\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":440,"y":60,"wires":[["f8f0c6c1.88afc8"]]},{"id":"62242a94.453e54","type":"ui_button","z":"461c9df1.6c1c94","name":"SidebySide Chart","group":"6c744598.ccf8bc","order":1,"width":0,"height":0,"passthru":false,"label":"Side-By-Side Bars","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":170,"y":200,"wires":[["8b9aa64b.6be378","cb05b3d9.de307"]]},{"id":"b48d6eb2.76c34","type":"function","z":"461c9df1.6c1c94","name":"setup data","func":"\n\nvar dataprod =[10,15,20];\nvar datacons =[5,8,13];\nvar data = [datacons,dataprod];\nvar datalabels =[\"2018\",\"2019\",\"2020\"];\n\nvar chart = [{\n\"series\": [\"Production\", \"Consumption\"],\n\"data\": data,\n\"labels\": datalabels\n}];\n\nmsg.payload = chart;\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":140,"wires":[["f8f0c6c1.88afc8"]]},{"id":"1f01b69.e40b449","type":"ui_button","z":"461c9df1.6c1c94","name":"Stacked Chart","group":"6c744598.ccf8bc","order":2,"width":0,"height":0,"passthru":false,"label":"Stacked Bars","tooltip":"","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":160,"y":140,"wires":[["f7d09dcf.54459","6a3db5e0.92b2fc"]]},{"id":"8b9aa64b.6be378","type":"function","z":"461c9df1.6c1c94","name":"clear data","func":"\nmsg.payload = [];\nmsg.ui_control = {\n    options: {\n        scales: {\n            xAxes: [{\n                stacked: false\n            }],\n            yAxes: [{\n                tacked: false\n            }]\n        }\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":280,"wires":[["f8f0c6c1.88afc8"]]},{"id":"cb05b3d9.de307","type":"delay","z":"461c9df1.6c1c94","name":"","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":370,"y":200,"wires":[["6da19252.e0495c"]]},{"id":"f7d09dcf.54459","type":"delay","z":"461c9df1.6c1c94","name":"","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":350,"y":140,"wires":[["b48d6eb2.76c34"]]},{"id":"bfa8d983.622a38","type":"ui_chart","z":"461c9df1.6c1c94","name":"Default Chart","group":"f2fbe3e0.a8092","order":2,"width":"7","height":"7","label":"default","chartType":"bar","legend":"true","xformat":"HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"auto","removeOlder":"12","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":830,"y":340,"wires":[[]]},{"id":"1302ca5b.df1b46","type":"function","z":"461c9df1.6c1c94","name":"setup data","func":"\n\nvar dataseries1 =[10,15,20];\nvar dataseries2 =[5,8,13];\nvar data = [dataseries1,dataseries2];\nvar datalabels =[\"2018\",\"2019\",\"2020\"];\n\nvar chart = [{\n\"series\": [\"Production\", \"Consumption\"],\n\"data\": data,\n\"labels\": datalabels\n}];\n//msg.title = \"Side-By-Side Bars\";\n\nmsg.payload = chart;\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":340,"wires":[["bfa8d983.622a38"]]},{"id":"64fd9c3c.28c4e4","type":"ui_button","z":"461c9df1.6c1c94","name":"Default","group":"f2fbe3e0.a8092","order":1,"width":0,"height":0,"passthru":false,"label":"Default","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":140,"y":340,"wires":[["1302ca5b.df1b46"]]},{"id":"6c744598.ccf8bc","type":"ui_group","z":"","name":"template1","tab":"5f806182.bf90a","order":1,"disp":false,"width":"7","collapse":false},{"id":"f2fbe3e0.a8092","type":"ui_group","z":"","name":"template2","tab":"5f806182.bf90a","order":2,"disp":false,"width":7,"collapse":false},{"id":"5f806182.bf90a","type":"ui_tab","z":"","name":"prova tavole-template","icon":"dashboard","order":6,"disabled":false,"hidden":false}]
You can change those colors easily.
msg.payload = [];
msg.ui_control = {
    options: {
        scales: {
            xAxes: [
                stacked: true,
                ticks: {
                    fontColor: '#00ff00'
                gridLines :{
                    zeroLineColor:'#00ff00',
                    color:'#00ff00',
                    lineWidth:0.5
            yAxes: [{
                stacked: true,
                ticks: {
                    fontColor: '#ffff00'
                gridLines :{
                    color:'#00ff00',
                    lineWidth:0.5
Do you need to stack both dimensions? I think you may only need x
Hi dceejay,
thank you for your post.
Conceptually you would need to stack Y axis only, but if you leave X axis stacked= false the series columns do not align perfectly vertically, but have a small weird horizontal shift, so you have to declare X axis stacked=true as well to get what you expect from a stacked bar chart.
Hi hotNiPi,
thank you very much for your useful post.
BTW can you please point me to the doc explaining all the features of the chart using msg.ui_control tecnique?
I'm using documents of the https://www.chartjs.org/docs/latest/ but thing to realize is that dashboard doesn't use the latest version so many things even are not supported or may work a little bit differently. Luckily the basics are same so the document helps a lot.
Ok, mano thanks
