I've had this working for years but something has changed with a recent update where my dimming buttons no longer dim lights.
When I press a button I pass the button action through to a "switch" which then routes based on the input. This works fine based on the button press type present in "payload.action".
The problem is "payload.action" is then passed through to the next node "api-call-service" which says it doesn't understand the payload.action and throws this error
"InputError: Invalid action format: brightness_down_click"
This is the data passed through from switch
{"topic":"zigbee2mqtt/bedroom_buttons","payload":{"action":"brightness_down_click","battery":20,"last_seen":"2024-09-08T09:14:48+10:00","linkquality":25,"update":{"installed_version":604241925,"latest_version":604241925,"state":"idle"},"update_available":null},"qos":0,"retain":false,"_msgid":"839ebdb5c100c484"}
How can I stop the switch from passing this data through?
"id": "ad08df176725d5c3",
"type": "mqtt in",
"z": "898fbae0f3586e7c",
"topic": "zigbee2mqtt/bedroom_buttons",
"qos": "2",
"datatype": "json",
"broker": "cc06606981aaf0a9",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 220,
"y": 760,
"16ad3d0d74c5983c"
"id": "16ad3d0d74c5983c",
"type": "switch",
"property": "payload.action",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "toggle",
"vt": "str"
"t": "eq",
"v": "brightness_up_click",
"vt": "str"
"t": "eq",
"v": "brightness_down_click",
"vt": "str"
"t": "eq",
"v": "arrow_left_hold",
"vt": "str"
"t": "eq",
"v": "arrow_right_hold",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 5,
"x": 510,
"y": 760,
"c4f6b5696c253458",
"3d3fcde6213ad06b"
"d27251e8c55c2df7"
"bcc45c48056685ed",
"954d1934afefda3f"
"id": "c4f6b5696c253458",
"type": "api-call-service",
"name": "All Bedroom Toggle",
"server": "33d171f4d54f205e",
"version": 6,
"debugenabled": true,
"action": "light.toggle",
"floorId": [],
"areaId": [
"bedroom"
"deviceId": [],
"entityId": [],
"labelId": [],
"data": "",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"domain": "light",
"service": "toggle",
"x": 670,
"y": 640,
"id": "d27251e8c55c2df7",
"name": "Lights Brighter",
"version": 6,
"debugenabled": false,
"action": "light.turn_on",
"floorId": [],
"areaId": [
"bedroom"
"deviceId": [],
"entityId": [],
"labelId": [],
"data": "{\"brightness_step_pct\":5,\"transition\":2}",
"dataType": "json",
"mergeContext": "",
"queue": "none",
"domain": "light",
"service": "turn_on",
"x": 720,
"y": 740,
"id": "bcc45c48056685ed",
"name": "Lights Dimmer",
"version": 6,
"action": "homeassistant.turn_on",
"floorId": [],
"areaId": [],
"deviceId": [],
"entityId": [
"light.bedroom_all"
"labelId": [],
"data": "",
"mergeContext": "",
"property": "payload",
"value": "{\"brightness_step_pct\":10}",
"valueType": "jsonata"
"queue": "none",
"domain": "homeassistant",
"x": 740,
"y": 820,
"id": "cc06606981aaf0a9",
"type": "mqtt-broker",
"name": "Stafford MQTT",
"broker": "192.168.64.64",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
"id": "33d171f4d54f205e",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": false,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": true,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
