Hi everybody,
I am running node red on a raspberry pi 4 (8gb) as an instance of iobroker. That means Paths and so on are not as given in the usual installation way but different.
I noticed, that all my variables are lost after a restart, so currently I try to find a way to store them on the filesystem.
As written here I changed the settings.js file and commented-in the storage information. As mentioned, my node red installation was made by iobroker. Due to that fact there are several settings files in different paths than usual, so I searched the whole system for settings.js and changed the mentioned lines in every single of them.
Afterwards I created change nodes and entered: change->set->flow.myVar to msg.payload
This works as long as the system is running. But after a reboot, when I try: set->msg.payload to flow.myVar I receive "undefined". So the values still get lost during a reboot.
Is there any other setting that may need to be adjusted?
These are the lines that I have in my settings.js:
contextStorage: {
default: {
module:"localfilesystem"
pi@raspberrypi:~ $ sudo find / -name settings.js
/home/pi/.config/chromium/Default/Extensions/cjpalhdlnbpafiamejdnhcphjbkeiagm/1.35.2_0/js/settings.js
/opt/iobroker/node_modules/node-red/settings.js
/opt/iobroker/node_modules/luxon/src/settings.js
/opt/iobroker/node_modules/@node-red/runtime/lib/storage/localfilesystem/settings.js
/opt/iobroker/node_modules/@node-red/runtime/lib/api/settings.js
/opt/iobroker/node_modules/@node-red/runtime/lib/settings.js
/opt/iobroker/node_modules/@node-red/editor-api/lib/admin/settings.js
/opt/iobroker/node_modules/@node-red/editor-api/lib/editor/settings.js
/opt/iobroker/node_modules/iobroker.node-red/settings.js
/opt/iobroker/iobroker-data/node-red/settings.js
Every settings.js that fits the right fomat (has the storage-lines commented out in it) was edited by me
Any ideas?
Best regards,
Pinky
