String to array - json.parse
More related to javascript, but am not able to find a working example (that works in NR).
I extract text from a website, the text is a string, but contains an (multidimensional) array.
Function used to extract the text:
const regex = /\[(.*?).*\]/gm;
let m;
m = regex.exec(msg.payload)
return {payload:m[0]}
Result:
19
a string.
Now I thought to use JSON.parse(m[0]) to parse it as an array, but it doesn't like it:
"SyntaxError: Unexpected token , in JSON at position 525"
What am I missing ?
Can you paste the full string output from debug node into a code section between backticks so we can see what might be happening?
(Your screen shot is cut off and not useful for someone who might try to recreate, copy/paste fix this for you)
Yeah it is a very long output, so I didn't bother.
But your comment triggered me to check the actual array (duh should have started there), ie. is it an array: and it wasn't, it was missing additional [ ... ] I was mislead by the initial [[, working now, thanks!
Glad I could help :laughing:
And looking my regex, I strip the [ ] off, I should have known :weary:
