I am new to node red.. Completely. I have been working on a project and I've got everything working in the dashboards the way I want it at this time. Except for a page that allows me to edit database tables.
I really want just a standard table view That is clickable and editable. There are actually three or four different tables that I want to do this for. I have tried to watch videos, I have tried to find tutorials. I have read documents on tabulator and ui table. Checked the examples. and I can of course manually input the data and make them work but with database tables its messing with me.
Using an Inject node, then a postgresql node (returning an arra) then the ui table node I can get the data to show up. I have no idea how to make it editable. From this point. I dont see a way to change the field to "input" in the ui-table settings.
Using an inject then postresql node, then ui-tabulator, I can get it to show my column headers as I put them in the ui-tabulator initial settings, but no data at all.
If someone can direct me on a real tutorial. That goes through it step by step or help me understand. Once I have it I will have it but I feel like I am going in circles with the same videos and tutorials that never really get into the database.
Side note I am using the newer 2.0 dashboard if that helps anyone.
Once you have imported the flows, the function node after the "Create table" inject node shows the configuration of how to make a table editable (and also to map/update) data into the table,
Yeah. Ive imported it. I guess I should step back. On the ui-tabulator I cant even get the data into the table. The headers is all i can get to show. I need to get the data to show before I even worrying about editing. I have the data in an array, i have the columns in the initial table settings. But wvidentially I am not passing the array into the table properly.
I guess the correct question is what do I put in the Data area of the place you are pointing to. The array is from my msg.payload.
const station = flow.get("selectedStation");
if (!station) {
return null;
const field = msg.payload.field;
const allowed = [
"thrower1",
"thrower2",
"thrower3",
"thrower4",
"thrower5"
if (!allowed.includes(field)) {
return null;
msg.query = `
UPDATE stations
SET ${field} = $1
WHERE station = $2
msg.params = [
msg.payload.newValue,
station
Then that runs to a postgresql node with this inside.
msg.query
I think this is a dirty way to do it. I believe there should be a cleaner way. I am just not seeing it. The issue I had was the row id was not being passed. If anyone has a better way I am open to it.
Yeah, I am using cellEdited and rowClick the function to get the row by using row click just seemed like a long way around. Like why does the payload not already have the row id in it.?
Maybe that is the way that it is but it is working. Now I need to figure out how to add rows from the table. I am playing with it.
The table has six columns. station (being the id), thrower1, thrower2, thrower3, thrower4, thrower5
So when I pass the cellEdited. It only brings in the field, such as thrower2 and the new value and old value. The row ID is not passed for some reason.
Hence why I have to create a switch, one side with rowClick, the other with cellEdited. And call the rowClick information to get the row id of "station" to bring it into the query off of the cellEdited side. I hope that makes sense.
What version do you have installed? I have @omrid01/node-red-dashboard-2-table-tabulator
v0.8.2. Node-RED version: v4.1.0, Node.js version: v22.15.0. And I don't see the "oldValue" at all. @omrid - any thoughts?
UPDATE: I deleted the ui-tabulator example flow and re-imported it and now it seems to be working.
Do you have a column in your data called "id"? I believe that may be required if you are editing the data (not required if you are just displaying data) and is sent as part of the event. I think there is a way to specify which column is the unique identifier, but I am not sure how ui-tabulator does that.
Hi, the cellEdited notification should include the row Id, so you don't need to register for a rowClick (and definitely not store the row Id in a context var, as this can introduce concurrency & race condition issues).
Is there anything else which is not working for you, or need any guidance?
I tried to figure out why oldValue or id are sometime missing in the cellEdited notification.Turns out Tabulator omits them if the have no value (i.e. no row id field, or cell value was not initialized and did not have an old value).
I will consider forcing a null value into the above missing fields in the next ui-tabulator upgrade.
You need a row Id only if you need to identify rows uniquely. "id" is the default, but you can select any other field (column) as your unique row identifier, by using the index property in the table configuration. For example, in your case:
"index": "station",
"columns": [...],
Note that you need to ensure the uniqueness of the id. Alternatively, you can the set the node to auto-validate the uniqueness, but then there is some performance impact in huge tables.
Thank you I believe that will help.
If I PM a flow can you help fix what I've done to be better and more efficient. I would like them to be exportable. They work, sometimes they dont really work especially editing its like they get stuck and editing does nothing. I dont get any debugs or anything. If I restart the flows then they start working.
Right, the id should always be unique to the table. Unique across multiple tables is kind of overkill. A simple auto increment number should do fine for each table.
