Sorry for the confusion.
Thanks for clearing up the confusion with the structure on building the name.
Just to reiterate the problem:
At the beginning a messages is sent to the sub-flow which sets the device name.
That is stored in sub-flow context( ) for that node.
Things happen and the device name is used to check/isolate/identify who is using the sub-flow.
Above the sub-flow I set a flow variable which indicates if the sub-flow has its debug active.
Obviously it is a flow variable as it needs to be accessed from the sub-flow.
When a message arrives in the sub-flow it checks if the flow variable (from the parent flow) is set to debug.
So I need to construct the name of the variable needed to check if the debug is active.
As in the flow/code I need to construct that name.
I need the device name with '_Button_Debug' for clarity.
So:
Correct. That is what I want.
So as an example:
The device is TimePi.
It needs to see if the flow variable named TimePi_Button_Debug is active. (True)
The original code is:
var debug = flow.get(device+'_Button_Debug') || false; // if active: true
That is what you (@knolleary) posted.
I am surprised that I got it correct.
Maybe I should have tested it first, before asking, but in light of other tests, it didn't seem to work.
Here is the flow I was using to establish if what I wrote is/was correct.
It doesn't work.
Walk through of this test flow:
Two inject nodes which set/change flow variable test to ONE or TWO.
The Test node invokes the sub-flow.
That reads the flow value of test and sends it out as the message.
Nothing comes out.
So I am confused why it should work, yet in testing, it doesn't seem to.
Flow here:
[{"id":"d03cee5c.debbf","type":"subflow","name":"Subflow 2","info":"","in":[{"x":220,"y":100,"wires":[{"id":"b6a05627.03a81"}]}],"out":[{"x":560,"y":100,"wires":[{"id":"b6a05627.03a81","port":0},{"id":"c320b7e7.d22ce","port":0}]}],"status":{"x":570,"y":190,"wires":[{"id":"16c3d7fc.e478","port":0}]}},{"id":"b6a05627.03a81","type":"function","z":"d03cee5c.debbf","name":"Get flow variable","func":"node.status({text:\"Message received\"});\nvar x;\nx = flow.get(test);\nmsg.payload = x;\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":100,"wires":[[]]},{"id":"16c3d7fc.e478","type":"status","z":"d03cee5c.debbf","name":"","scope":null,"x":380,"y":190,"wires":[[]]},{"id":"c320b7e7.d22ce","type":"change","z":"d03cee5c.debbf","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$test","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":50,"wires":[[]]},{"id":"9ea5acd.d1ad25","type":"debug","z":"accbdb61.d75918","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":580,"y":760,"wires":[]},{"id":"69a06ac9.813d24","type":"inject","z":"accbdb61.d75918","name":"Test","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":760,"wires":[["f6961980.dfd6d"]]},{"id":"f6961980.dfd6d","type":"subflow:d03cee5c.debbf","z":"accbdb61.d75918","name":"","x":340,"y":760,"wires":[["9ea5acd.d1ad25"]]},{"id":"26a16337.fdde04","type":"inject","z":"accbdb61.d75918","name":"One","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":620,"wires":[["37c662d1.dc05ae"]]},{"id":"37c662d1.dc05ae","type":"change","z":"accbdb61.d75918","name":"","rules":[{"t":"set","p":"test","pt":"flow","to":"ONE","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":620,"wires":[[]]},{"id":"f43ae422.a4c","type":"change","z":"accbdb61.d75918","name":"","rules":[{"t":"set","p":"test","pt":"flow","to":"TWO","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":670,"wires":[[]]},{"id":"79938c3d.d2cf7c","type":"inject","z":"accbdb61.d75918","name":"Two","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":670,"wires":[["f43ae422.a4c"]]}]
Sub flow:
[{"id":"b6a05627.03a81","type":"function","z":"d03cee5c.debbf","name":"Get flow variable","func":"node.status({text:\"Message received\"});\nvar x;\nx = flow.get(test);\nmsg.payload = x;\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":100,"wires":[[]]},{"id":"16c3d7fc.e478","type":"status","z":"d03cee5c.debbf","name":"","scope":null,"x":380,"y":190,"wires":[[]]}]
What am I missing?
(It will be something obvious or silly. But hey, I'm sorry. I can't see it.)
