Sub flows..... Dumb question
I have started using sub-flows and it is great.
My understanding is that I have a flow and because parts of it are repeated, rather than have the same nodes repeated, I can use a sub-flow and it acts like a "sub-routine" (from basic).
Yeah, as many of you may know: I'm not the best coder, and I have changed a couple of things in the sub-flow as I have found problems with their working/s.
To edit them I understand I can either double click on the icon and then "edit sub-flow" or double click on it from the left window.
Alas now I have 6 versions in the list.
Screenshot%20from%202019-07-03%2016-11-17
I get that I am using multiple occurrences of them, but that's the whole idea - isn't it?
What have I done "wrong"?
Yeah something is going wrong. I've always double-clicked the sub-flow in the flow and then clicked "edit sub-flow". Then I make changes and click "Save". I've never ended up with multiple versions, even though the sub-flow is used multiple times in flows. Can you detail the exact steps to the issue so others can replicate?
Alas I can't give an example of how I did it. I just noticed it today.
All the editing was done days ago.
Just on a thought: If the "nodes" aren't yet wired up would that cause this to happen?
I'll do some testing here on another machine. Testing on the machine shown, DEPLOY takes about 4 minutes.
That looks like you have imported a flow into the editor that includes the subflow... Which results in a copy of the subflow being added to the palette.
We have an item on the backlog to handle that better by detecting that you are importing a subflow you already have and then offering to either update the existing subflow, or add a copy.
Thanks. It isn't urgent.
Is there anything I can do to remove the extra entries?
Delete them.
Double click it, press delete button
Mia Culpa.
Thanks Steve.
You might want to check where they are used first, so you can replace them with the other version. Assuming they are used.
