Just recently starting to look at the subflow and the environment variables, quite a sophisticated setup with a grander vision to create nodes from subflow nodes (?)
I understand that the variables are expanded upon deploying after which they are read-only, no issue there.
Is there some background thought going on to have some kind initialize routine available before variable expansion in future releases ?
Example; I am using homekit mqtt. I can query all devices from mqtt, I would like to populate a select with the data returned from the query and expand those, instead of hardcoding.
