I'm using subflow in my node-red with one env-variable.
if i use the variable individually, then it works:
But when I use them inside another String, it doenst work anymore. is there a workaround or a solution for it?
You can set the to value to JSONata and use
"STRING" & $env("ENVIRA_VARIABLE_NAME") & "STRING"
ok nice to know.
but I was using change node just for testing, now with the firebase node, I cant use env as type of field:
Only env fields support having an env var in the middle.
All other field types can only replace the whole value with an env var, not just a part of it.
One work around is to add another subflow variable using the env type that sets that variable to the value you want (with the first env var embedded in the middle).
You can then use that new env var in the firebase node to replace the whole field.
yes that what I was thinking about. I found in the docu that it is possible to set the field with msg.firestore:
Firestore Write
Node performs write operations to the referenced collection, subCollection or document.
Configurations made from within the node or on the
msg.firestoreproperty:
operation: [string] Write operation to perform, eitheradd,set,updateordeletecollection: [string] collection or subCollection reference to write to.document: [string] document reference to write to (optional foraddoperations)options: [object] additional options passed to firebase (currently specific tosetoperations)
how to combine this msg.firestore with msg.payload??
Not quite sure what you mean. You can use a Change node to set msg.firestore to whatever you want it to be - including from an env value.
I have payload with the values:
and this I have to put into the collection wich I have to set with msg.firestore. Thats why I'm asking how to combine this payload with msg.firestore
Sorry - I have not used the firestore node, so cannot help.
As this topic is about subflow variables, you may want to start a new topic with a title related to firestore so users more familiar with it will see it.
