Hello all,
I thought I could put a substring in a function but it doesn't work a priori, what is my mistake please?
I have this error => TypeError: Data.substr is not a function
Below my (simple) function :
let Data = msg.payload;
let totalLeaks = (Data.substr(6,6));
let lastleakduration = (Data.substr(12,6));
msg.payload = {
leaks : totalLeaks,
duration : lastleakduration
Hi @bpi2008
substr is a function only available on String objects.
This error suggests the msg.payload you are passing this function is not a String.
Can you wire in a Debug node in parallel to see exactly what msg.payload you are passing into the function?
Hi Knolleray,
decoded_payload: object
BAT_V: 3.144
LAST_WATER_LEAK_DURATION: 0
MOD: 2
WATER_LEAK_STATUS: 0
WATER_LEAK_TIMES: 92
I have changed simply my function and i's ok now by :
var duration = msg.payload.uplink_message.decoded_payload.WATER_LEAK_TIMES;
msg.payload = duration;
I'm very interesting to test "substr" for other functions.
Many thanks for all. Bernard
Colin
4
For the record, you should be using substring(), substr has been deprecated.
