Seems after hours and days of scouring the web on this topic for both the Zero-2W and Zero1.x, there’s mixed info as to what is best setup to support GPIO as of 2025. Lots of web info from past year or so indicate possible conflicts with recent Node-Red versions and various Pi hardware, 64 vs 32 bit OS, Python3, etc.
For now, I’m simply interested to know if starting fresh on a Pi Zero-2W with Node-Red reading GPIO, what is the preferred mix of Raspberry Pi OS (Bookworm or Trixie) as well as Node-RED and Node.js versions. Seems there should be a website or page dedicated to that unless by chance I missed it.
If the Pi ecosystem is moving away from Node-Red to a simpler or better way to get a simple or more complex project off the ground, I would be interested to know that too.
I started my Node-Red project with the version-1 “Pi Zero W” 4 years ago with “Buster”, updated it 2 years ago (no problem) to “Bullseye”, but latest update of that a few months ago to “Bookworm” ran into serious high-cpu problems with Python3 and GPIO. I resolved that by changing all GPIO input nodes to using “node-red-node-pi-gpiod” with "Remote GPIO" enabled and daemon running at startup (instead of standard “node-red-node-pi-gpio”). Also limiting that setup to Node-Red version 3.1.11 and NodeJS version 20.19.5.
So now I’m migrating the project to the latest Pi Zero 2W, install "Raspberry Pi OS Lite (64-bit)" (Debian version-13 "Trixie"), then proceed to setup the "Remote GPIO". But the Remote-GPIO seems of question and is not even in the “raspi-config” menu anymore.
In short, I appreciate any help or direction/links for suggested setup of Pi Zero 2W supporting Node-Red and GPIO. Right now I’m thinking the Trixie environment needs to evolve a bit more.
Hmmm, seems back in 2021 and years since the Node-RED and Pi ecosystem were such a perfect match it seemed from my 40+ years in IT to be such a perfect fit as if joined-at-the-hip so to say. I wrote code in many languages over the years but really like the simplicity & visual aspect of the "flows" to see the project code in a simple view while burying the nitty gritty in function nodes.
That aside, @TotallyInformation and @dceejay I've read thru lots of your posts and seems you guys have a deep knowledge of the Node-RED stuff. Saying that, I'm interested of any recommendation you have on best option to support GPIO on Pi Zero 2W.
To note, I just tried a simple flow setup using the default installed "node-red-node-pi-gpio" on the 2W "Trixie" 64bit install and suggested "bash <(curl..." install of Node-RED and I still get the roughly 5% CPU from "python3..." task per each of the 6 pins monitored. I know a 4-core Zero 2W can easily accommodate that for all available GPIO but it seems to be too much CPU%. For my project start on the Zero W, that drove me to the Remote-GPIO option which reduced the load for 14 pins monitored to roughly 17% (from pigpiod) instead of always slammed at 100%.
Also, @dceejay I tried setting up for using "node-red-node-pi-gpiod" after seeing no Remote-GPIO in the raspi-config menu per the script in Pigpiod not installing under new official trixie release · Issue #632 · joan2937/pigpio · GitHub (see near end for script starting with DOLLAR="$"). Going thru all that and run of "sudo systemctl enable --now pigpiod.service" resulted in a failed start error. So, I thought I'm either missing something or pushing into uncharted waters, maybe going about it wrong, so here I am.
If the node-red-node-pi-gpiod is still good for Trixie and will be for a few more years, that would be great. Saying that, the nodered.org site should update their info on this for Trixie and later per it relying on Remote-GPIO setup in the raspi-config and deamon running.
But I'm also open to anything better or more preferred from the new design perspective. But also see what I tried per previous post on the only thing I found in trying to setup node-red-node-pi-gpiod on my Trixie Zero 2W.
Weeellll, if you really want advice from me on this, it would be - don't use a Pi0w! I'm more of an ESP fan myself. I'd rather run Node-RED and other helpful services on a server - whether a full-fat Pi or something else (I use an old laptop personally) - and then do the IoT stuff on an ESP with a Wi-Fi connection (though of course, serial/usb or other wired connections absolutely possible).
In fact, I've NEVER done anything with the GPIO on a Pi other than plugging in a daughter board and using a pre-made driver library. So not much help from me I'm afraid.
Tried a few different avenues of setting up Remote-GPIO with node-red-node-pi-gpiod but for some reason ran into dead-ends in getting the daemon setup and operating. Same with the libpigpiod option which seems to be pre-installed to Trixie (checked pre-installed gpio options via "apt list | grep pigpiod"). I was able to test libpigpiod type inputs on my Zero-2W to show rising and falling edge reporting via the gpioinfo/gpiomon CLI-commands (per Command-line tools — libgpiod -devel documentation).
For now, I decided to move the Zero-2W input detail back to standard GPIO to continue on to add camera support and finish the project out (are they ever finished tho) as the project can use either method. Maybe in a few months I'll reconsider the Remote-GPIO option which for now I'll keep on any of the Zero-1 units to prevent the 100% CPU on those from all the python3-nrgpio.py tasks per each GPIO input. The Zero-2W still has up to 5% CPU per the python3-nrgpio.py tasks using standard GPIO but running HTOP with all available inputs monitored has the 4 cores each at 20% or less CPU. OK, for now but still seems excess CPU compared to only up to 20% with all the inputs monitored in Remote-GPIO on the Zero-1 with a single core.
Thanx for any previous help and suggestions, and any others on Remote-GPIO setup using the the node-red-node-pi-gpiod or other. Hopefully this might help anyone else with Trixie and Remote-GPIO setup. For now, per all the web-searching, it seems RPi GPIO handling is in a state of transition in how best to support the new changes per "gpiochipN" in newer RPi units vs older, more specifically the OS supporting newer vs older RPi units.
