Switch and setup Philips Hue RGB lamp
I would like to turn on a Philips Hue RGB lamp using the Hue Light Node, part of node-red-contrib-huemagic. When turning on the lamp, the brightness should be 50% and the HEX color should be FF8800.
I probably have to do that with a function node, am I right? Can someone help me with the correct setup for that node?
Found the solution, maybe helpfull for others too:
msg.payload={
"on":true,
"brightness":50,
hex:"ff8800"
