Switch node icons color problem
More or less...
"Ci vediamo" is correct...
I looked at the flow I posted and there is a slight bit of confusion.
Why?
Well, I just grabbed that from some working stuff and I forgot to include some extra stuff - which you either may or not like/want.
It also allows the icon to have varying background colours also.
So this is some code to better show you what is happening, as you may be confused by the button node also having msg.background used.
[{"id":"8f2f7d28.395dc","type":"inject","z":"8bb4de19.f72c88","name":"ON","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":550,"wires":[["48274cad.781644"]]},{"id":"48274cad.781644","type":"change","z":"8bb4de19.f72c88","name":"","rules":[{"t":"set","p":"icon","pt":"msg","to":"<font color = \"lime\"><i class=\"fa fa-lightbulb-o fa-3x\"></i></font>","tot":"str"},{"t":"set","p":"background","pt":"msg","to":"blue","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":550,"wires":[["b113db7b.098b18","870b0886.1619b8"]]},{"id":"870b0886.1619b8","type":"ui_button","z":"8bb4de19.f72c88","name":"BULB#2","group":"53792891.774238","order":2,"width":"3","height":"2","passthru":false,"label":"{{msg.icon}}","tooltip":"","color":"","bgcolor":"{{msg.background}}","icon":"","payload":"X","payloadType":"str","topic":"","x":550,"y":550,"wires":[[]]},{"id":"8bce1c43.e97bf8","type":"change","z":"8bb4de19.f72c88","name":"","rules":[{"t":"set","p":"icon","pt":"msg","to":"<font color = \"red\"><i class=\"fa fa-lightbulb-o fa-3x\"></i></font>","tot":"str"},{"t":"set","p":"background","pt":"msg","to":"white","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":600,"wires":[["870b0886.1619b8"]]},{"id":"1f5fd410.d19cc4","type":"inject","z":"8bb4de19.f72c88","name":"OFF","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":600,"wires":[["8bce1c43.e97bf8"]]},{"id":"53792891.774238","type":"ui_group","name":"Group 7","tab":"de5134a7.f0a0d","order":4,"disp":true,"width":6},{"id":"de5134a7.f0a0d","type":"ui_tab","name":"Tab 6","icon":"dashboard","order":5}]
This is only to show you what is happening and what you can do with the button node as opposed to the switch node.
I think that it is better as allows both the colour of the icon and the background to be changed and a lot easier.
(Don't worry, I am curious and now I have an interesting question to answer)
How about this easy bit of code:
[{"id":"c91511f4.2ef35","type":"ui_switch","z":"8bb4de19.f72c88","name":"","label":"switch","tooltip":"","group":"53792891.774238","order":13,"width":"3","height":"2","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-4x fa-lightbulb-o","oncolor":"dimgrey","offvalue":"false","offvalueType":"bool","officon":"fa-4x fa-lightbulb-o","offcolor":"gold","x":330,"y":790,"wires":[[]]},{"id":"149838c3.dc8217","type":"inject","z":"8bb4de19.f72c88","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":770,"wires":[["c91511f4.2ef35"]]},{"id":"3f440eaf.b0f65a","type":"inject","z":"8bb4de19.f72c88","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":810,"wires":[["c91511f4.2ef35"]]},{"id":"53792891.774238","type":"ui_group","name":"Group 7","tab":"de5134a7.f0a0d","order":4,"disp":true,"width":6},{"id":"de5134a7.f0a0d","type":"ui_tab","name":"Tab 6","icon":"dashboard","order":5}]
Finally I'm back...
After three night of work, changes and various attempts (and with your help), I managed to get it to work!!!
Now I can turn on or off the lights from NodeRed, from Shelly Apps or from original wall switch and in every case icon on NodeRed dashboard change (Yellow for ON status, Grey for OFF status)
Thanks to all...
I attach my code:
        "id": "69103026.a212b",
        "type": "comment",
        "z": "4f28d205.05afcc",
        "name": "Luci Esterne",
        "info": "",
        "x": 110,
        "y": 40,
        "id": "33d06843.6dce88",
        "type": "ui_audio",
        "name": "Messaggio Vocale",
        "group": "3b49ec8e.cf4144",
        "voice": "it-IT",
        "always": true,
        "x": 600,
        "y": 40,
        "id": "34fc0755.d3c048",
        "type": "http request",
        "name": "Switch Shelly",
        "method": "GET",
        "ret": "txt",
        "paytoqs": false,
        "url": "http://admin:XXXX@192.168.1.213/relay/0?turn=toggle",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 380,
        "y": 80,
        "id": "8539e1f.f79182",
        "type": "change",
        "name": "Setta Messaggio",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "true",
                "fromt": "bool",
                "to": "Luci Esterne Accese",
                "tot": "str"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "false",
                "fromt": "bool",
                "to": "Luci Esterne Spente",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 400,
        "y": 40,
                "33d06843.6dce88"
        "id": "cac6dfed.07eb",
        "type": "ui_switch",
        "label": "Accendi / Spegni",
        "tooltip": "",
        "group": "a4049c44.5b032",
        "order": 1,
        "width": 6,
        "height": "2",
        "passthru": false,
        "decouple": "true",
        "topic": "",
        "style": "",
        "onvalue": "true",
        "onvalueType": "str",
        "onicon": "onicon",
        "oncolor": "oncolor",
        "offvalue": "false",
        "offvalueType": "str",
        "officon": "officon",
        "offcolor": "offcolor",
        "x": 130,
        "y": 80,
                "8539e1f.f79182",
                "34fc0755.d3c048"
        "id": "9ebebda1.5024a",
        "type": "function",
        "name": "Luci ON",
        "func": "msg.ui_control = {  onicon:\"fa-4x fa-lightbulb-o\",oncolor:\"yellow\"}\nmsg.payload=\"true\"\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 810,
        "y": 130,
                "cac6dfed.07eb"
        "id": "a7e417f4.f4d768",
        "name": "Status Shelly",
        "method": "GET",
        "ret": "txt",
        "paytoqs": false,
        "url": "http://admin:XXXX@192.168.1.213/relay/0?status",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 230,
        "y": 150,
                "e502c6f.06e5438"
        "id": "e502c6f.06e5438",
        "type": "json",
        "name": "Trasforma in JSON",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 410,
        "y": 150,
                "14b6bd7a.f0edb3"
        "id": "14b6bd7a.f0edb3",
        "type": "switch",
        "name": "Controllo se ON o OFF",
        "property": "payload.ison",
        "propertyType": "msg",
        "rules": [
                "t": "true"
                "t": "false"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 620,
        "y": 150,
                "9ebebda1.5024a"
                "f1ebdbd6.28a388"
        "id": "f1ebdbd6.28a388",
        "type": "function",
        "name": "Luci OFF",
        "func": "msg.ui_control = {  officon:\"fa-3x fa-lightbulb-o\",offcolor:\"grey\"}\nmsg.payload=\"false\"\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 810,
        "y": 170,
                "cac6dfed.07eb"
        "id": "5c103573.3e325c",
        "type": "inject",
        "name": "Avvio",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "1",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 90,
        "y": 150,
                "a7e417f4.f4d768"
        "id": "3b49ec8e.cf4144",
        "type": "ui_group",
        "z": "",
        "name": "Gestione Cancello",
        "tab": "be3b686.c1d7998",
        "order": 1,
        "disp": true,
        "width": 6,
        "collapse": true
        "id": "a4049c44.5b032",
        "type": "ui_group",
        "z": "",
        "tab": "59b63931.02dec8",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "be3b686.c1d7998",
        "type": "ui_tab",
        "z": "",
        "name": "Cancello",
        "icon": "account_balance",
        "order": 5,
        "disabled": false,
        "hidden": false
        "id": "59b63931.02dec8",
        "type": "ui_tab",
        "z": "",
        "name": "Luci",
        "icon": "lightbulb_outline",
        "order": 6,
        "disabled": false,
        "hidden": false
Good to hear.
