Switch node icons color problem
Hi folks,
I've this problem.
I need to change icons color in a Switch Node, depending from a "msg" retrieved from a function node:
Function node example:
"{msg.colour = '#e6d00b';}
return msg;"
These are my switch node settings: (but it doesn't work)
immagine
Thank you
Mario
(I'm not seeing a question)
I need to change icons color in a Switch Node, depending from a "msg" retrieved from a function node, but I don't known how to do it. This is the question.
As a base line:
[{"id":"3354cba4.823424","type":"function","z":"26262ba1.62dcbc","name":"","func":"msg.payload = \"what ever you want\";\nmsg.colour = \"blue\";\nreturn msg;","outputs":1,"noerr":0,"x":2660,"y":2090,"wires":[[]]}]
And points for spelling colour correctly. :wink:
Or going a bit further on the depending on payload which I missed (sorry)
[{"id":"b09952c0.3b0ff8","type":"function","z":"26262ba1.62dcbc","name":"","func":"if (msg.payload == \"ONE\")\n{\n    msg.colour = \"blue\";\n} else\nif (msg.payload == \"TWO\")\n{\n    msg.colour = \"red\";\n}\nreturn msg;","outputs":1,"noerr":0,"x":2660,"y":2080,"wires":[[]]}]
I've try on th fly!!!
The problem is not in "Function node" but in "Switch Node". How or where can I specify the "variable" colour?
If you want the switch node to change colour depending on the payload: the second flow I posted does that.
The switch node isn't smart enough to detect different payloads and adjust the colour in accordance.
So I did it with the function node.
Granted you need to edit the code in the node to what you want. The bit I posted was only as an example.
Does that make it clearer?
I've posted this image in my first message
immagine
Is correct? In my project it is NOT working.
What must I write in "switch node" in the "Colour" field?
Sorry, but I've understand how "function node" works, but not the "switch node"...
You haven't post any "switch node", don't you?
Try this :
[{"id":"ef8314d8.430358","type":"debug","z":"c5966c3d.677f3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":610,"y":1090,"wires":[]},{"id":"47462941.153fe8","type":"inject","z":"c5966c3d.677f3","name":"on","props":[{"p":"bulb","v":"on","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":1240,"wires":[["440a6a15.f3a5c4"]]},{"id":"440a6a15.f3a5c4","type":"switch","z":"c5966c3d.677f3","name":"","property":"bulb","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":1260,"wires":[["1172ac25.6c6ad4"],["93c6ad8d.e8bb5"]]},{"id":"1172ac25.6c6ad4","type":"function","z":"c5966c3d.677f3","name":"on","func":"msg.color = \"#e6d00b\";\nmsg.background = \"#454545\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":490,"y":1240,"wires":[["70e99c79.cc27c4"]]},{"id":"93c6ad8d.e8bb5","type":"function","z":"c5966c3d.677f3","name":"off","func":"msg.color = \"grey\";\nmsg.background = \"#454545\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":490,"y":1280,"wires":[["70e99c79.cc27c4"]]},{"id":"66fbbdbf.fc8bd4","type":"inject","z":"c5966c3d.677f3","name":"off","props":[{"p":"bulb","v":"off","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":1280,"wires":[["440a6a15.f3a5c4"]]},{"id":"70e99c79.cc27c4","type":"ui_button","z":"c5966c3d.677f3","name":"","group":"f90f3cdb.aa35b","order":37,"width":"2","height":"1","passthru":false,"label":"","tooltip":"","color":"{{msg.color}}","bgcolor":"{{msg.background}}","icon":"fa-3x fa-lightbulb-o","payload":"","payloadType":"str","topic":"","x":630,"y":1260,"wires":[[]]},{"id":"bb3f92ba.469b1","type":"function","z":"c5966c3d.677f3","name":"Gate","func":"let oncolor = msg.oncolor;\nmsg.ui_control = {onicon:\"fa-3x fa-lightbulb-o\",oncolor:oncolor,officon:\"fa-3x fa-lightbulb-o\",offcolor:\"grey\"}\nreturn msg;\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":370,"y":1090,"wires":[["c749f1f9.5a5ca"]]},{"id":"c749f1f9.5a5ca","type":"ui_switch","z":"c5966c3d.677f3","name":"","label":"","tooltip":"","group":"f90f3cdb.aa35b","order":1,"width":"2","height":1,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"onicon","oncolor":"oncolor","offvalue":"false","offvalueType":"bool","officon":"officon","offcolor":"offcolor","x":490,"y":1090,"wires":[["ef8314d8.430358"]]},{"id":"3a0a9cc3.a3b8b4","type":"inject","z":"c5966c3d.677f3","name":"#e6d00b","props":[{"p":"oncolor","v":"#e6d00b","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","x":210,"y":1060,"wires":[["bb3f92ba.469b1"]]},{"id":"1970e6e5.2e5219","type":"inject","z":"c5966c3d.677f3","name":"#33ccff","props":[{"p":"oncolor","v":"#33ccff","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","x":210,"y":1110,"wires":[["bb3f92ba.469b1"]]},{"id":"ac154135.26ec8","type":"inject","z":"c5966c3d.677f3","name":"on","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":360,"y":1010,"wires":[["c749f1f9.5a5ca"]]},{"id":"ce31ec5a.ad80a","type":"inject","z":"c5966c3d.677f3","name":"off","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":360,"y":1050,"wires":[["c749f1f9.5a5ca"]]},{"id":"295af012.d358b","type":"comment","z":"c5966c3d.677f3","name":"========== push button ==========","info":"","x":360,"y":1320,"wires":[]},{"id":"5788a357.bc37ac","type":"comment","z":"c5966c3d.677f3","name":"inject color first","info":"","x":190,"y":1030,"wires":[]},{"id":"969fd1b0.45332","type":"comment","z":"c5966c3d.677f3","name":"play on or off","info":"","x":350,"y":980,"wires":[]},{"id":"4612bd83.7e3134","type":"comment","z":"c5966c3d.677f3","name":"color and background color here","info":"","x":500,"y":1210,"wires":[]},{"id":"4f80caf3.b87a14","type":"comment","z":"c5966c3d.677f3","name":"play on or off","info":"","x":200,"y":1210,"wires":[]},{"id":"7ccd2793.b1b528","type":"comment","z":"c5966c3d.677f3","name":"========== switch button ==========","info":"","x":370,"y":1140,"wires":[]},{"id":"f90f3cdb.aa35b","type":"ui_group","z":"","name":"forrage","tab":"f1dcd1e8.54e1","order":1,"disp":true,"width":"10","collapse":true},{"id":"f1dcd1e8.54e1","type":"ui_tab","z":"","name":"ESP12","icon":"home","order":17,"disabled":false,"hidden":false}]
here are 2 examples:
  • at the top using a ui-switch: first inject the color, then play with on and off or click on the icon to see the color change from on to off
  • at the bottom the ui-button : the color is defined in the on , off Functions nodes. Play with on and off to see it turn on and off
I've try you're flows, but in all two, I see only a grey or a white lamp. No one color. It is the same problem that I have whith my original flows.
I don't understand... :thinking:
i use node-red-dashboard v2.22.0 and you ?
:shushing_face: :grimacing:
Probably the problem is this!!!
Probably : update your Node-red and node-red-dashboard in your palette manager
Not yet...
Node-Red version 1.1.4 and Node-red-dashboard version 2.23.4, but also same problem...
:sob:
Can you please post the node code?
(You may want to edit that post and put the code in correctly.)
Use the </> button.
No. Not quite.
See the </> button in the top of the edit screen (when you are posing)?
Click it and then paste the code.
If done correctly, you should see one line of text only with your code.
My code
        "id": "c49ce89e.f6b4f8",
        "type": "comment",
        "z": "d8c1672b.eeadc8",
        "name": "Luci Esterne",
        "info": "",
        "x": 110,
        "y": 40,
        "id": "33409cd2.9de114",
        "type": "ui_audio",
        "name": "Messaggio Vocale",
        "group": "3b49ec8e.cf4144",
        "voice": "it-IT",
        "always": true,
        "x": 550,
        "y": 40,
        "id": "8f8f9600.1368c8",
        "type": "http request",
        "name": "Switch Shelly",
        "method": "GET",
        "ret": "txt",
        "paytoqs": false,
        "url": "http://admin:XXXX@192.168.1.213/relay/0?turn=toggle",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 330,
        "y": 80,
        "id": "782334ba.4354ac",
        "type": "change",
        "name": "Setta Messaggio",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "true",
                "fromt": "bool",
                "to": "Luci Esterne Accese",
                "tot": "str"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "false",
                "fromt": "bool",
                "to": "Luci Esterne Spente",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 350,
        "y": 40,
                "33409cd2.9de114"
        "id": "a4087e62.a39b7",
        "type": "ui_switch",
        "label": "Accendi / Spegni",
        "tooltip": "",
        "group": "a4049c44.5b032",
        "order": 1,
        "width": 6,
        "height": "2",
        "passthru": false,
        "decouple": "false",
        "topic": "",
        "style": "",
        "onvalue": "true",
        "onvalueType": "bool",
        "onicon": "fa-4x fa-lightbulb-o",
        "oncolor": "msg.colour",
        "offvalue": "false",
        "offvalueType": "bool",
        "officon": "fa-3x fa-lightbulb-o",
        "offcolor": "msg.colour",
        "x": 130,
        "y": 80,
                "782334ba.4354ac",
                "8f8f9600.1368c8"
        "id": "ef1f0c25.7f79f",
        "name": "Status Shelly",
        "method": "GET",
        "ret": "txt",
        "paytoqs": false,
        "url": "http://admin:XXXX@192.168.1.213/relay/0?status",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 410,
        "y": 180,
                "389146f4.1f2a1a"
        "id": "59479048.87118",
        "type": "inject",
        "name": "Controllo se ON oppure OFF",
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 190,
        "y": 180,
                "ef1f0c25.7f79f"
        "id": "3967dd9e.082552",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "colour",
        "targetType": "msg",
        "x": 1350,
        "y": 180,
        "id": "389146f4.1f2a1a",
        "type": "json",
        "name": "Trasforma in JSON",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 610,
        "y": 180,
                "d22c7c90.cf656"
        "id": "12753da.33fc5c2",
        "type": "function",
        "name": "Setta colore ICONA (Accesa)",
        "func": "{msg.colour = '#e6d00b';}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1080,
        "y": 160,
                "3967dd9e.082552",
                "a4087e62.a39b7"
        "id": "d22c7c90.cf656",
        "type": "switch",
        "name": "Controllo se ON o OFF",
        "property": "payload.ison",
        "propertyType": "msg",
        "rules": [
                "t": "true"
                "t": "false"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 820,
        "y": 180,
                "12753da.33fc5c2"
                "b516a5b5.43cae8"
        "id": "b516a5b5.43cae8",
        "type": "function",
        "name": "Setta colore ICONA (Spenta)",
        "func": "{msg.colour = '#919191';}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 1080,
        "y": 200,
                "3967dd9e.082552",
                "a4087e62.a39b7"
        "id": "3b49ec8e.cf4144",
        "type": "ui_group",
        "z": "",
        "name": "Gestione Cancello",
        "tab": "be3b686.c1d7998",
        "order": 1,
        "disp": true,
        "width": 6,
        "collapse": true
        "id": "a4049c44.5b032",
        "type": "ui_group",
        "z": "",
        "tab": "59b63931.02dec8",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "be3b686.c1d7998",
        "type": "ui_tab",
        "z": "",
        "name": "Cancello",
        "icon": "account_balance",
        "order": 5,
        "disabled": false,
        "hidden": false
        "id": "59b63931.02dec8",
        "type": "ui_tab",
        "z": "",
        "name": "Luci",
        "icon": "lightbulb_outline",
        "order": 6,
        "disabled": false,
        "hidden": false
Thanks.
Now, I do understand your frustration. I am still learning how to use Node-Red and I have been playing with it for a few years.
I also get that sometimes people get stuck in a thought pattern, and as good as it seems: it doesn't always work, or isn't right, for what ever reason.
So, as an alternative to what you are wanting to do - and it still has the same end result - how about this bit of code:
[{"id":"1f5fd410.d19cc4","type":"inject","z":"8bb4de19.f72c88","name":"OFF","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":600,"wires":[["8bce1c43.e97bf8"]]},{"id":"8bce1c43.e97bf8","type":"change","z":"8bb4de19.f72c88","name":"","rules":[{"t":"set","p":"icon","pt":"msg","to":"<font color = \"red\"><i class=\"fa fa-lightbulb-o fa-3x\"></i></font>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":600,"wires":[["870b0886.1619b8"]]},{"id":"870b0886.1619b8","type":"ui_button","z":"8bb4de19.f72c88","name":"BULB#2","group":"53792891.774238","order":2,"width":"1","height":"3","passthru":false,"label":"{{msg.icon}}","tooltip":"","color":"","bgcolor":"{{msg.background}}","icon":"","payload":"X","payloadType":"str","topic":"","x":490,"y":550,"wires":[[]]},{"id":"48274cad.781644","type":"change","z":"8bb4de19.f72c88","name":"","rules":[{"t":"set","p":"icon","pt":"msg","to":"<font color = \"lime\"><i class=\"fa fa-lightbulb-o fa-3x\"></i></font>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":550,"wires":[["b113db7b.098b18","870b0886.1619b8"]]},{"id":"b113db7b.098b18","type":"debug","z":"8bb4de19.f72c88","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":490,"y":630,"wires":[]},{"id":"8f2f7d28.395dc","type":"inject","z":"8bb4de19.f72c88","name":"ON","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":550,"wires":[["48274cad.781644"]]},{"id":"53792891.774238","type":"ui_group","name":"Group 7","tab":"de5134a7.f0a0d","order":4,"disp":true,"width":6},{"id":"de5134a7.f0a0d","type":"ui_tab","name":"Tab 6","icon":"dashboard","order":5}]
Move to the right end of the text and you will see a little icon pop up which allows you to copy the code to the clicpboard by simply clicking it icon.
Going over and having another look at the switch node.
The On/Off Color and On/Off Icon are optional fields. If they are all present, the default toggle switch will be replaced with the relevant icons and their respective colors.
Alas I suspect it doesn't allow the colour to be set in the message. It only accepts names entered directly.
So: you could simply put the colour names in the node something like:
[{"id":"ed4fc378.1c239","type":"ui_switch","z":"8bb4de19.f72c88","name":"","label":"switch","tooltip":"","group":"53792891.774238","order":13,"width":"3","height":"2","passthru":false,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-4x fa-lightbulb-o","oncolor":"green","offvalue":"false","offvalueType":"bool","officon":"fa-4x fa-lightbulbfa-4x fa-lightbulb-o","offcolor":"red","x":460,"y":470,"wires":[[]]},{"id":"53792891.774238","type":"ui_group","name":"Group 7","tab":"de5134a7.f0a0d","order":4,"disp":true,"width":6},{"id":"de5134a7.f0a0d","type":"ui_tab","name":"Tab 6","icon":"dashboard","order":5}]
But I am not sure they accept RGB values like you are using.
So really the alternate way I posted should be a better solution.
Now I go to bed. Tomorrow I try your code.
Thank you for now. You are very kind
Bye bye. Good night
ci vidiamo (I think it is - yes?)
