Switch node "in between" not functioning correctly
I have a switch node that I am having trouble getting to work. The ">=" and "<=" are both working properly. The "is between" is not outputting anything. Anyone have any ideas?
[{"id":"e6a03d25.0cfb48","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"b9b39678.031938","type":"ui_switch","z":"e6a03d25.0cfb48","name":"","label":"","tooltip":"","group":"c123e7bd.857","order":1,"width":"6","height":"2","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","x":770,"y":180,"wires":[["448511b0.86237"]]},{"id":"448511b0.86237","type":"rbe","z":"e6a03d25.0cfb48","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":910,"y":180,"wires":[["fba482ac.b93038"]]},{"id":"c71efdec.0a0ae8","type":"change","z":"e6a03d25.0cfb48","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":140,"wires":[["b9b39678.031938"]]},{"id":"b7cd7744.e382b","type":"change","z":"e6a03d25.0cfb48","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":180,"wires":[["b9b39678.031938"]]},{"id":"ea2e0ebe.c0bfa8","type":"change","z":"e6a03d25.0cfb48","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":220,"wires":[["b9b39678.031938"]]},{"id":"4d4358d6.0430c","type":"switch","z":"e6a03d25.0cfb48","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"85","vt":"num"},{"t":"btwn","v":"85","vt":"num","v2":"65","v2t":"num"},{"t":"lte","v":"65","vt":"num"}],"checkall":"false","repair":false,"outputs":3,"x":290,"y":180,"wires":[["c71efdec.0a0ae8","c32a07d3.929848"],["c32a07d3.929848","b7cd7744.e382b"],["ea2e0ebe.c0bfa8","c32a07d3.929848"]]},{"id":"8ddff963.3c0aa8","type":"inject","z":"e6a03d25.0cfb48","name":"","topic":"","payload":"75","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":180,"wires":[["4d4358d6.0430c"]]},{"id":"c32a07d3.929848","type":"debug","z":"e6a03d25.0cfb48","name":"switch","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":460,"y":80,"wires":[]},{"id":"1c12c0a7.9b7647","type":"inject","z":"e6a03d25.0cfb48","name":"","topic":"","payload":"100","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":140,"wires":[["4d4358d6.0430c"]]},{"id":"fc07edac.10fda8","type":"inject","z":"e6a03d25.0cfb48","name":"","topic":"","payload":"50","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":220,"wires":[["4d4358d6.0430c"]]},{"id":"fba482ac.b93038","type":"debug","z":"e6a03d25.0cfb48","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1070,"y":180,"wires":[]},{"id":"c123e7bd.857","type":"ui_group","z":"","name":"Main","tab":"3c588071.0152c","disp":false,"width":"24","collapse":false},{"id":"3c588071.0152c","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
swap the between - currently you have "between 85 and 65" change it to "between 65 and 85"
Thank you!
The switch node ought to handle that... as "in between" does imply that it should... will fix.. thanks
Do you guys think of everything ? You guys think of everything!
