Switch node - multiple values in same conditions
Hi can someone help me create a switch node with multiple values like
for example if msg.payload can push 1,2,5,10 then switch node should run two conditions with == for 1,2,5,10 and != for 1,2,5,10
how do i use multiple values in one condition
Have you tried...
or
thanks second example worked
I would also like to thank you. I would never have thought of using JSONata as the selection property, didn't even realise you could. :rofl:
It certainly makes things lot neater
