Hi, I have a SWITCH node that's accepting a payload (boolean or numeric) and testing it against 2 rules
pin1 output: boolean value
pin2 output : number <= 100
When the payload is a number <= 100 everything is fine and the switch node only outputs on the pin2
When the payload is a boolean value, the node correctly outputs the true/false value on pin1 but also outputs the same true/false value on pin2.
seems strange behaviour and I cant see the logic behind it, I'm hoping someone can explain it
