Switch node to show group
Hi all,
I'm trying to show a group in a tab, once an option in the dropdown node is selected, but I'm not able to do this task.
This is my flow:
[{"id":"9d2ecefb774604a5","type":"debug","z":"f03ae4b40058fc36","name":"Outp Cerca","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":900,"y":700,"wires":[]}]
The tab name is: Inserimento Date Controllo
The group name is: Inserimento data controllo
So, if the field of the dopdown node is not empty I would like to show the group Inserimento data controllo (tre dropdown node and the group are in the same tab).
COuld you help me?
Many thanks
Your flow above only include a debug node
You are probably missed the copy/paste
Oh, sorry
[{"id":"91f420e50c0ad42e","type":"ui_dropdown","z":"f03ae4b40058fc36","name":"","label":"Cerca Strumento","tooltip":"","place":"","group":"aef9f72e2ef95f2a","order":3,"width":4,"height":1,"passthru":true,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"options","topicType":"msg","className":"","x":570,"y":660,"wires":[["d5c51376a53351aa","9d2ecefb774604a5"]]},{"id":"12ddffc39e65911f","type":"MSSQL","z":"f03ae4b40058fc36","mssqlCN":"6fb70e68d89e36c4","name":"","outField":"payload","returnType":"0","throwErrors":"0","query":"SELECT CODIFICA FROM [DB_Strumentazione].[dbo].[StrumentazioneAttrezzature]","modeOpt":"","modeOptType":"query","queryOpt":"","queryOptType":"editor","paramsOpt":"queryParams","paramsOptType":"msg","rows":"","rowsType":"msg","params":[{"output":true,"name":"CODIFICA","type":"VarChar","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}}],"x":660,"y":440,"wires":[["298e52eb6cd1c44f","9f0d81814cbde772"]]},{"id":"298e52eb6cd1c44f","type":"debug","z":"f03ae4b40058fc36","name":"Out DB","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":880,"y":460,"wires":[]},{"id":"7912d6cf7ee0e4b6","type":"inject","z":"f03ae4b40058fc36","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"Inserimento Date Controllo","payloadType":"date","x":510,"y":500,"wires":[["12ddffc39e65911f"]]},{"id":"b3c4ee77f3cfb55a","type":"ui_button","z":"f03ae4b40058fc36","name":"","group":"aef9f72e2ef95f2a","order":1,"width":6,"height":1,"passthru":false,"label":"Refresh Data","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":550,"y":340,"wires":[["12ddffc39e65911f"]]},{"id":"9f0d81814cbde772","type":"change","z":"f03ae4b40058fc36","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"$.payload.CODIFICA","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":520,"wires":[["91f420e50c0ad42e"]]},{"id":"68ea2f985b97320f","type":"function","z":"f03ae4b40058fc36","name":"Set msg payload","func":"\n \n msg.payload = {\"group\":{ \"show\" : [\"Inserimento_Date_Controllo_Inserimento_data_controllo\"]}} // hide Group_1 on tab2\n node.send(msg)\n\n\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1170,"y":580,"wires":[["5797d396cb1cd011"]]},{"id":"597168c2a2a09fcd","type":"change","z":"f03ae4b40058fc36","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"topic","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":960,"y":580,"wires":[["68ea2f985b97320f"]]},{"id":"d5c51376a53351aa","type":"switch","z":"f03ae4b40058fc36","name":"","property":"payload","propertyType":"msg","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":790,"y":600,"wires":[["597168c2a2a09fcd"]]},{"id":"5797d396cb1cd011","type":"debug","z":"f03ae4b40058fc36","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1380,"y":560,"wires":[]},{"id":"9d2ecefb774604a5","type":"debug","z":"f03ae4b40058fc36","name":"Outp Cerca","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":900,"y":700,"wires":[]},{"id":"aef9f72e2ef95f2a","type":"ui_group","name":"Ricerca Strumento","tab":"21286fd2ee7bdc0c","order":3,"disp":false,"width":"20","collapse":false,"className":""},{"id":"6fb70e68d89e36c4","type":"MSSQL-CN","name":"DB_Strumentazione","server":"XXX\\SQLEXPRESS","port":"","encyption":true,"trustServerCertificate":true,"database":"DB_Strumentazione","useUTC":true,"connectTimeout":"30000","requestTimeout":"","cancelTimeout":"","pool":"","parseJSON":false,"enableArithAbort":true},{"id":"21286fd2ee7bdc0c","type":"ui_tab","name":"Inserimento Date Controllo","icon":"assignment","order":5,"disabled":false,"hidden":true}]
I think it's still missing things like the "Inserimento data controllo" group
Also I don't have your SQL data base
But roughly the modified sample here below shows how to hide the "Inserimento data controllo" group when you click on the "Refresh" button and then show it when you select something from the droplist.
I hope it will give you enough hints
[{"id":"9cc560d769ae0576","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"298e52eb6cd1c44f","type":"debug","z":"9cc560d769ae0576","name":"Out DB","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":200,"wires":[]},{"id":"7912d6cf7ee0e4b6","type":"inject","z":"9cc560d769ae0576","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"Inserimento Date Controllo","payloadType":"date","x":140,"y":260,"wires":[["12ddffc39e65911f"]]},{"id":"9f0d81814cbde772","type":"change","z":"9cc560d769ae0576","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"$.payload.CODIFICA","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":240,"wires":[["91f420e50c0ad42e"]]},{"id":"d5c51376a53351aa","type":"switch","z":"9cc560d769ae0576","name":"","property":"payload","propertyType":"msg","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":360,"wires":[["ed5045df2c61ea2d","597168c2a2a09fcd"]]},{"id":"5797d396cb1cd011","type":"debug","z":"9cc560d769ae0576","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1010,"y":260,"wires":[]},{"id":"9d2ecefb774604a5","type":"debug","z":"9cc560d769ae0576","name":"Outp Cerca","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":520,"y":520,"wires":[]},{"id":"b3c4ee77f3cfb55a","type":"ui_button","z":"9cc560d769ae0576","name":"","group":"aef9f72e2ef95f2a","order":1,"width":6,"height":1,"passthru":false,"label":"Refresh Data","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"Some data to be displayed","topicType":"str","x":180,"y":100,"wires":[["12ddffc39e65911f","fe8eb1b49e87e926"]]},{"id":"91f420e50c0ad42e","type":"ui_dropdown","z":"9cc560d769ae0576","name":"","label":"Cerca Strumento","tooltip":"","place":"","group":"aef9f72e2ef95f2a","order":2,"width":4,"height":1,"passthru":true,"multiple":false,"options":[{"label":"aaa","value":"AAA","type":"str"},{"label":"bbb","value":"BBB","type":"str"}],"payload":"","topic":"options","topicType":"msg","className":"","x":200,"y":420,"wires":[["d5c51376a53351aa","9d2ecefb774604a5"]]},{"id":"12ddffc39e65911f","type":"MSSQL","z":"9cc560d769ae0576","mssqlCN":"6fb70e68d89e36c4","name":"","query":"SELECT CODIFICA FROM [DB_Strumentazione].[dbo].[StrumentazioneAttrezzature]","outField":"payload","x":290,"y":200,"wires":[["298e52eb6cd1c44f","9f0d81814cbde772"]]},{"id":"e2e48888980797cf","type":"ui_text","z":"9cc560d769ae0576","group":"8e201ebdc2415f17","order":1,"width":0,"height":0,"name":"Display","label":"","format":"{{msg.payload}}","layout":"row-spread","className":"","x":940,"y":340,"wires":[]},{"id":"4e7070bf968ed897","type":"ui_ui_control","z":"9cc560d769ae0576","name":"","x":940,"y":400,"wires":[[]]},{"id":"ed5045df2c61ea2d","type":"change","z":"9cc560d769ae0576","name":"Show Inserimento data controllo","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"group\":{\"show\":[\"Inserimento_Date_Controllo_Inserimento_data_controllo\"]}}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":400,"wires":[["4e7070bf968ed897"]]},{"id":"597168c2a2a09fcd","type":"change","z":"9cc560d769ae0576","name":"Set text content","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":340,"wires":[["e2e48888980797cf"]]},{"id":"fe8eb1b49e87e926","type":"change","z":"9cc560d769ae0576","name":"Hide Inserimento data controllo","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"group\":{\"hide\":[\"Inserimento_Date_Controllo_Inserimento_data_controllo\"]}}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":440,"wires":[["4e7070bf968ed897"]]},{"id":"f914546e0e070f1f","type":"ui_spacer","z":"9cc560d769ae0576","name":"spacer","group":"aef9f72e2ef95f2a","order":3,"width":10,"height":1},{"id":"aef9f72e2ef95f2a","type":"ui_group","name":"Ricerca Strumento","tab":"21286fd2ee7bdc0c","order":1,"disp":false,"width":"20","collapse":false,"className":""},{"id":"6fb70e68d89e36c4","type":"MSSQL-CN","name":"DB_Strumentazione","server":"XXX\\SQLEXPRESS","encyption":true,"database":"DB_Strumentazione"},{"id":"8e201ebdc2415f17","type":"ui_group","name":"Inserimento data controllo","tab":"21286fd2ee7bdc0c","order":2,"disp":true,"width":"20","collapse":false,"className":""},{"id":"21286fd2ee7bdc0c","type":"ui_tab","name":"Inserimento Date Controllo","icon":"assignment","order":5,"disabled":false,"hidden":false}]
Thanks a lot, I made some changes according to my needs and it works!
