Syntax error in Function node
I have dowloaded data from my Ewelink Thermostat (TRVZB), where the state of the thermostat stored in "thermostat-mode" object. Im unable to get or transfer this data to my global variable, because the hyphen in the name not accepted.
Any solution?
Peter
  1. Use a change node instead of a function node.
  2. Use square bracket notation instead of dot notation.
You can either quote it or place in between square brackets. For example:
obj = {
   "thermostat-mode": xyz
or
mode = obj["thermostat-mode"]
Thanks!
In the meantime I found the answer in "Use an object with a hyphen in a function" topic. Same like OMRID advice.
Thanks again your time and quick answer.
Peter
(You should make the thread as solved to show it has been answered.)
