Table dashboard 2.0
Hi everybody,
In the checkboxes from the table (dashboard 2.0) when i select some checkbox is giving the last selection. I try to clean the last with a function node giving msg.payload ="" but dont work. How we can solve that?
Did you find a solution to this? I'm experiencing the same problem.
If anybody can provide me an example flow and some step-by-step description (which allows me to reproduce it quickly), I will have a look at this.
Hi Bart,
I simplified the flow to its essentials, making it as straightforward as possible.
This is a dashboard with a table node and two buttons: reset and delete. The example uses a JSON array from a change node (in my real environment I use sqlite with other info). In this case it displays a list of Dutch painters (as shown in this sample).
To reproduce the problem:
  1. Select 2 items by clicking their checkbox. This logs an array with 2 items
  2. Hit the delete key. The two items are deleted from the table
  3. Select 1 item in the table and note that the debug now contains 3 items. Expected 1 item.
Hope this helps you to find the cause.
Erik
PS. As I'm new to Dashboard any suggestions to improve my concept are welcome :wink:
dashboard2-table-multiselect.json (8.9 KB)
@evdheuvelUpl
It would help Bart if you could export your example flow, and post it in the forum, so that he can import it.
https://nodered.org/docs/user-guide/editor/workspace/import-export
To post any code, including flows in the forum, please take a look at this...
Here you go :
[{"id":"a0299ef1e4246bc6","type":"ui-table","z":"49d091cd63383185","group":"04ea239d7dc473d9","name":"","label":"text","order":3,"width":0,"height":0,"maxrows":"10","passthru":false,"autocols":true,"showSearch":true,"selectionType":"checkbox","columns":[],"mobileBreakpoint":"sm","mobileBreakpointType":"defaults","action":"replace","x":650,"y":540,"wires":[["3373efdd4859fedd"]]},{"id":"ebf5762287704b0b","type":"ui-button","z":"49d091cd63383185","group":"04ea239d7dc473d9","name":"reset","label":"Reset","order":2,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":150,"y":540,"wires":[["e01cde4b284cba50"]]},{"id":"e01cde4b284cba50","type":"change","z":"49d091cd63383185","name":"","rules":[{"t":"set","p":"painters","pt":"flow","to":"[{\"id\":1,\"name\":\"Rembrandt van Rijn\",\"birth_year\":1606,\"famous_for\":\"The Night Watch, Self-Portraits\"},{\"id\":2,\"name\":\"Vincent van Gogh\",\"birth_year\":1853,\"famous_for\":\"Starry Night, Sunflowers, Self-Portraits\"},{\"id\":3,\"name\":\"Johannes Vermeer\",\"birth_year\":1632,\"famous_for\":\"Girl with a Pearl Earring, The Milkmaid\"},{\"id\":4,\"name\":\"Frans Hals\",\"birth_year\":1582,\"famous_for\":\"The Laughing Cavalier, Portraits\"},{\"id\":5,\"name\":\"Piet Mondrian\",\"birth_year\":1872,\"famous_for\":\"Composition with Red, Blue, and Yellow, Abstract Art\"},{\"id\":6,\"name\":\"Hieronymus Bosch\",\"birth_year\":1450,\"famous_for\":\"The Garden of Earthly Delights, The Haywain Triptych\"},{\"id\":7,\"name\":\"Jan Steen\",\"birth_year\":1626,\"famous_for\":\"The Merry Family, The Feast of Saint Nicholas\"},{\"id\":8,\"name\":\"Gerrit Dou\",\"birth_year\":1613,\"famous_for\":\"The Glass of Water, Old Woman with a Glove\"},{\"id\":9,\"name\":\"Karel Appel\",\"birth_year\":1921,\"famous_for\":\"Abstract Expressionism, the CoBrA movement\"},{\"id\":10,\"name\":\"Anton Mauve\",\"birth_year\":1838,\"famous_for\":\"Landscapes, Rural Scenes, and Pastoral Life\"}]","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"painters","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":540,"wires":[["a0299ef1e4246bc6"]]},{"id":"5518cc5c37b37e01","type":"ui-button","z":"49d091cd63383185","group":"04ea239d7dc473d9","name":"delete","label":"","order":1,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"delete","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":150,"y":600,"wires":[["bbb0408a642697bb"]]},{"id":"3373efdd4859fedd","type":"change","z":"49d091cd63383185","name":"","rules":[{"t":"set","p":"selected","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":540,"wires":[["78d72d0dfbe7b510"]]},{"id":"bbb0408a642697bb","type":"change","z":"49d091cd63383185","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"selected","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":600,"wires":[["5e54195972e417e1"]]},{"id":"78d72d0dfbe7b510","type":"debug","z":"49d091cd63383185","name":"debug 273","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":970,"y":540,"wires":[]},{"id":"5e54195972e417e1","type":"function","z":"49d091cd63383185","name":"delete entries","func":"const selected = msg.payload\nconst selectedIds = selected.map(painter => painter.id);\n\nlet painters = flow.get('painters')\n\nconst removePaintersByIds = (painters, selectedIds) => {\n    return painters.filter(painter => !selectedIds.includes(painter.id));\n};\n\nconst updatedPainters = removePaintersByIds(painters, selectedIds);\n\nflow.set('painters',updatedPainters)\n\nmsg.payload = flow.get('painters')\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":600,"wires":[["a0299ef1e4246bc6"]]},{"id":"8ee80be53d8cc74b","type":"comment","z":"49d091cd63383185","name":"Painters","info":"","x":160,"y":500,"wires":[]},{"id":"04ea239d7dc473d9","type":"ui-group","name":"Group 2","page":"ac93a3ab7d1a425c","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"ac93a3ab7d1a425c","type":"ui-page","name":"Painters","ui":"f728a7a2258a7a5d","path":"/page2","icon":"brush","layout":"grid","theme":"7ceb0649e7d1666c","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":"true","disabled":"false"},{"id":"f728a7a2258a7a5d","type":"ui-base","name":"OL Connect Automate","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"showPageTitle":true,"navigationStyle":"icon","titleBarStyle":"default"},{"id":"7ceb0649e7d1666c","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094CE","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
@evdheuvelUpl
Thanks for doing your homework!
Will try to find some time this evening to have a look at.
Please give me a reminder in a couple of days, in case I should have forgotten this :innocent:
Good homework will be rewarded (usually)...
Here you go:
Thanks, that was quick... much appreciated... glad it was a one-liner!
Dankjewel (or should I say Merciekes :)),
Erik
You are welcome!
