Table node, best practice
I was wondering what is the best practice to build more advance tables.
You have dashboard 2.0 table node and ui-tabilator. I also find video's on template nodes.
I want to build some advance table nodes and what to get off on the best way.
Thank you
Filip
You can pretty much make any table, of any style you desire in the ui-template.
You can 100% DIY it or build on the examples here: All Vuetify Components — Vuetify including nesting of cards and sparkles and anything else you need.
There is no "best practice".
You haven't been explicit about what front-end you want to use for this. There are 4 current front ends, paired http-in/-response nodes, Dashboard 1 (which is no longer being updated), Dashboard 2 and UIBUILDER for Node-RED.
If you want to build something that accommodates all of them (and potentially web apps outside of node-red as well), I would strongly recommend looking at building a web component. Check out my example components if you want some ideas.
If you really want to build another node-red node, you will need to decide which front end you will target.
Also note that my uib-element node as a table output feature - though currently it is relatively simple in nature. The uibuilder front-end library has additional tools for building tables as well. A more complex output node for tables would be welcome (e.g. with column formatting, editing features, etc) and I would be happy to help you get going on in.
