Hello!
I have projector D-Ila. I use a node "TCP request" (as here TCP/IP 3 way handshake) I'm trying to set up a connection. I manage to send the first command, but the connection remains open. This means that I can't start the pairing process again.
Tried all the return options, messages are sent in the desired format only with setup "keep the connection open".
But when I disable the node and deploy again, the process can start. Is it possible to start each command with the pairing process?
This is a part of original manual. Thank you!
The connection should be closed as soon as it has received the reply (unless set not to close - or not to wait for reply) - so either on timeout or after a certain number of characters.
unfortunately, if I close the connection, I will have to go through the pairing procedure again. After connecting, the projector asks "PJ_OK", I answer" PJREQ", the projector answers" PJACK", then I send any command. Each response contains a different number of characters, and there are no other characteristics that would allow you to close by character. When I close by time, I get a response in the buffer only after closing the connection and it is unreadable
It would be great if you could immediately open a new connection through the same node.
sorry - I'm not quite understanding the problem... you want to close the connection ? The spec says it will close automatically after 5 secs doesn't it ? Or you just need to keep sending some (maybe dummy) command every 4 secs to keep it alive ?
Or maybe look at the tcp in and out pair of nodes instead.
What does the timed out buffer look like ? It may just have some extra control characters in that can be removed.
Is this by any chance about the same thing as topic TCP/IP 3 way handshake?
