TCP In node does not like environment variables
When writing a variable name on the TCP In node port, it works as expected but the node shows the little red triangle and a warning is displayed when deploying the flow.
Is this expected behaviour or can I open an issue in Github?
For information, the TCP Out node behaves graciously when adding an environment variable.
Please open an issue.
Done,
Thank you
Issue fixed and confirmed working in version 3.1.6
