There have been two posts in the last couple days where the technique suggested for sharing flows (How to share code or flow json) has not worked correctly.  The instructions say to select the text then click the Pre-  formatted Text button.  However in those two instances it seems that only single backticks were added (which is what happens correctly if only a portion of a line is selected).
I wonder whether it would be better if the instructions said to click the button then paste the text in. Or perhaps someone knows the underlying cause.
The problematic threads are Writing on PLC S7 node works only 25% of the times and Sanity check for NWS weather alert Flow.
          This topic was automatically closed after 30 days. New replies are no longer allowed.
