Telegram and Email Alerts
Thanks to the awesome work by @Steve-Mcl I've managed to get my Telegram alerts running. Thanks Steve.
I am now attempting to add email alerting to the same flow... only, I cannot get the Subject to work? Node Red seems to be happy with the flow, but only shows the code in the subject and not the value?
Here's my code...
        "id": "c18d9ee81483eb22",
        "type": "debug",
        "z": "fda74e4b5bc38453",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 870,
        "y": 320,
        "id": "d7bc597446137a4e",
        "type": "inject",
        "name": "*** Setup devices to ping here ***",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "[{\"name\":\"gateway\",\"host\":\"192.168.4.5\"},{\"name\":\"Server 2\",\"host\":\"192.168.4.7\"},{\"name\":\"Server 1\",\"host\":\"192.168.4.29\"},{\"name\":\"Server 3\",\"host\":\"192.168.4.9\"},{\"name\":\"Server 5\",\"host\":\"192.168.4.14\"}]",
        "payloadType": "json",
        "x": 490,
        "y": 320,
                "88ed34f6f40208e6"
        "id": "88ed34f6f40208e6",
        "type": "ping",
        "mode": "triggered",
        "host": "",
        "timer": "20",
        "inputs": 1,
        "x": 710,
        "y": 320,
                "c18d9ee81483eb22",
                "ec850e934b4a3560"
        "id": "ec850e934b4a3560",
        "type": "function",
        "name": "Prepare telegram message (if bad)",
        "func": "if(msg.payload === false) {\n    msg.payload = {};\n    msg.payload.type = 'message';\n    msg.payload.content = `Ping to '${msg.ping.name}' (${msg.ping.host}) failed`;\n    msg.payload.chatId = 5612125043\n    return msg;\n}\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 360,
        "y": 400,
                "2146c727b359180b",
                "dbd882ec3cc0864e"
        "id": "305bafda3cfebc5c",
        "type": "debug",
        "name": "to Email node",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 940,
        "y": 400,
        "id": "2146c727b359180b",
        "type": "function",
        "name": "Server Down Email",
        "func": "msg.payload.content = `Ping to '${msg.ping.name}' (${msg.ping.host}) failed`;\nmsg.payload.topic = 'WARNING!! ${msg.ping.name} Server DOWN';\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 710,
        "y": 400,
                "305bafda3cfebc5c"
        "id": "dbd882ec3cc0864e",
        "type": "debug",
        "name": "to Telegram node",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 950,
        "y": 460,
I also want to add a time stamp to the email... I usually use +time but not sure where to add it?
Appreciate any advice. Thanks, Mark
This should do it for you -
[{"id":"c18d9ee81483eb22","type":"debug","z":"7e04343289f26daa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1030,"y":420,"wires":[]},{"id":"d7bc597446137a4e","type":"inject","z":"7e04343289f26daa","name":"*** Setup devices to ping here ***","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"name\":\"gateway\",\"host\":\"192.168.4.5\"},{\"name\":\"Server 2\",\"host\":\"192.168.4.7\"},{\"name\":\"Server 1\",\"host\":\"192.168.4.29\"},{\"name\":\"Server 3\",\"host\":\"192.168.4.9\"},{\"name\":\"Server 5\",\"host\":\"192.168.4.14\"}]","payloadType":"json","x":650,"y":420,"wires":[["88ed34f6f40208e6"]]},{"id":"88ed34f6f40208e6","type":"ping","z":"7e04343289f26daa","mode":"triggered","name":"","host":"","timer":"20","inputs":1,"x":870,"y":420,"wires":[["c18d9ee81483eb22","ec850e934b4a3560"]]},{"id":"ec850e934b4a3560","type":"function","z":"7e04343289f26daa","name":"Prepare telegram message (if bad)","func":"if(msg.payload === false) {\n    msg.payload = {};\n    msg.payload.type = 'message';\n    msg.payload.content = `Ping to '${msg.ping.name}' (${msg.ping.host}) failed`;\n    msg.payload.chatId = 5612125043\n    return msg;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":500,"wires":[["2146c727b359180b","dbd882ec3cc0864e"]]},{"id":"305bafda3cfebc5c","type":"debug","z":"7e04343289f26daa","name":"to Email node","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1100,"y":500,"wires":[]},{"id":"2146c727b359180b","type":"function","z":"7e04343289f26daa","name":"Server Down Email","func":"const timestamp = Date.now()\nconst dateTime = new Date(timestamp).toLocaleString()\n\nmsg.payload.content = `Ping to '${msg.ping.name}' (${msg.ping.host}) failed`;\nmsg.payload.topic = `${dateTime} WARNING!! '${msg.ping.name}' Server DOWN`;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":500,"wires":[["305bafda3cfebc5c"]]},{"id":"dbd882ec3cc0864e","type":"debug","z":"7e04343289f26daa","name":"to Telegram node","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1110,"y":560,"wires":[]}]
object
type: "message"
content: "Ping to 'Server 5' (192.168.4.14) failed"
chatId: 5612125043
topic: "20/09/2022, 00:36:27 WARNING!! 'Server 5' Server DOWN"
If you want the timestamp in the message instead then just move the ${dateTime} into the msg.payload.content
Are you using the core email node node-red-node-email?
The help for that node says
Sends the msg.payload as an email, with a subject of msg.topic.
But you seem to be using msg.payload.content and msg.payload.topic?
Hi @jbudd you are absolutely correct... excellent spot! Based on the issue you've highlighted I am thinking I need to somehow take the msg.payload.content and redirect it to msg.payload for the core email node? I figure I could use a change node? Or is there a programmatic approach I could use?
I also need to strip out the msg.payload.chatId as that isn't needed for the email, only the Telegram bot.
Thanks @Sean-McG that code is excellent and pointed me in the right direction. Thank you so much, really appreciate the help :+1:
Change function node as follows to set correct payload and remove "un-wanted" data -
msg.payload = `Ping to '${msg.ping.name}' (${msg.ping.host}) failed`;
msg.topic = `${dateTime} WARNING!! '${msg.ping.name}' Server DOWN`;
delete msg.ping
delete msg.payload.chatId
object
payload: "Ping to 'Server 5' (192.168.4.14) failed"
topic: "20/09/2022, 02:31:59 WARNING!! 'Server 5' Server DOWN"
_msgid: "d1262ac07cdcddcb"
Hi @Sean-McG tried the code... however it doesn't show the msg.topic for some reason? This is the result...
Ping to 'APOLLO' (192.168.0.14) failed
If I change msg.payload to msg.payload.content then this is the result...
{"type":"message","content":"Ping to 'APOLLO' (192.168.0.14) failed"}
So not sure why the...
Is not showing?
This code appears to work...
msg.payload.content = `${dateTime} Ping to '${msg.ping.name}' (${msg.ping.host}) failed`;
msg.payload.topic = `WARNING!! '${msg.ping.name}' Server DOWN`;
delete msg.payload.type
Here's what comes out...
9/20/2022, 1:05:51 PM Ping to 'APOLLO' (192.168.0.14) failed
WARNING!! 'APOLLO' Server DOWN
But if I change msg.payload.content to msg.payload it only shows...
9/20/2022, 1:04:42 PM Ping to 'APOLLO' (192.168.0.14) failed
20/09/2022, 08:19:30node: to Email node
20/09/2022, 08:19:32 WARNING!! 'Server 5' Server DOWN : msg.payload : string[40]
It works for me - try the full flow with debug set to complete msg.object
[{"id":"c18d9ee81483eb22","type":"debug","z":"de795c381afdf5b7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":710,"y":420,"wires":[]},{"id":"d7bc597446137a4e","type":"inject","z":"de795c381afdf5b7","name":"*** Setup devices to ping here ***","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"name\":\"gateway\",\"host\":\"192.168.4.5\"},{\"name\":\"Server 2\",\"host\":\"192.168.4.7\"},{\"name\":\"Server 1\",\"host\":\"192.168.4.29\"},{\"name\":\"Server 3\",\"host\":\"192.168.4.9\"},{\"name\":\"Server 5\",\"host\":\"192.168.4.14\"}]","payloadType":"json","x":330,"y":420,"wires":[["88ed34f6f40208e6"]]},{"id":"88ed34f6f40208e6","type":"ping","z":"de795c381afdf5b7","mode":"triggered","name":"","host":"","timer":"20","inputs":1,"x":550,"y":420,"wires":[["c18d9ee81483eb22","ec850e934b4a3560"]]},{"id":"ec850e934b4a3560","type":"function","z":"de795c381afdf5b7","name":"Prepare telegram message (if bad)","func":"if(msg.payload === false) {\n    msg.payload = {};\n    msg.payload.type = 'message';\n    msg.payload.content = `Ping to '${msg.ping.name}' (${msg.ping.host}) failed`;\n    msg.payload.chatId = 5612125043\n    return msg;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":200,"y":500,"wires":[["2146c727b359180b","dbd882ec3cc0864e"]]},{"id":"305bafda3cfebc5c","type":"debug","z":"de795c381afdf5b7","name":"to Email node","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":780,"y":500,"wires":[]},{"id":"2146c727b359180b","type":"function","z":"de795c381afdf5b7","name":"Server Down Email","func":"const timestamp = Date.now()\nconst dateTime = new Date(timestamp).toLocaleString()\nmsg.payload = `Ping to '${msg.ping.name}' (${msg.ping.host}) failed`;\nmsg.topic = `${dateTime} WARNING!! '${msg.ping.name}' Server DOWN`;\ndelete msg.ping\ndelete msg.payload.chatId\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":500,"wires":[["305bafda3cfebc5c"]]},{"id":"dbd882ec3cc0864e","type":"debug","z":"de795c381afdf5b7","name":"to Telegram node","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":560,"wires":[]}]
@smcgann99 Humble apology, you are correct. Thanks again for the help, much appreciated.
