Telegram bot to channel
Hi
I managed to post to telegram using telegram node but how to post in channel or group?
I tried adding bot to channel but nothing happens? Do i set to post to channel from nodered?
Thank you.
if you are posting a question about how to do something in a node, it’s always worth stating which node you are using. there are lots of different chatbot-nodes listed on flows.nodered.org
Each channel has an ID. You need to find that ID. Instructions are found in the docs for the node.
Thank you
