I'm creating a project in which I want to be able to check/uncheck a checkbox manually (by clicking) and also by an external source such as MQTT input etc. In my test I simulate the external source by an inject node currently.
I managed to find actually do this, although an issue sometimes occurs in which I have to refresh the page to see the updated checkbox. I found out it happens when I first toggle the checkbox manually and then afterwards with the inject node.
Does anyone know what may cause this issue? The problem does not occur if I only trigger it manually or only with the inject node.
When I had this issue it had something to do with the digest loop of angularjs. You can trigger the loop manually by
scope.$applyAsync(function(){
An example would be:
<md-input-container>
<md-checkbox ng-model="data">
Checkbox in an md-input-container
</md-checkbox>
</md-input-container>
<script>
(function(scope) {
scope.data = false;
//handle arriving messages
if(msg !== undefined && msg !== null){
try{
switch(msg.topic) {
case "cbx setting":
scope.data = msg.payload;
break;
default:
break;
}catch(err){
console.error(err);
})(scope);
</script>
Where you can check the checkbox by this message:
{payload:true, topic:"cbx setting"}
